118
6,911
XCMG Truck Crane QY50K Parts Manual EN ZH
Language: English, Chinese
Brand: XCMG
Type of Machine: Truck Crane
Model: XCMG QY50K Truck Crane
List of Files:
XCMG Crane QY50K Parts Manual EN ZH Parts 1.pdf (78 Pages)
QY50K.00 汽车起重机 – Truck Crane
QY50K.01 起重钩 – Hook
QY50K.02Ⅱ 起重臂 – Boom
QY16K.03C 操纵室 – Manipulate Ventriculus (Control Cab)
QY50K.05 转台 – Rotation Table
QY50K.06 回转支承 – Slewing Bearing
QY50K.07 回转机构 – Slewing Movement
QY50K.08 起升机构 – Lifting Movement
QY16K.11.1A 操纵室电气 – Operating Cabs Electric System
QY50K.11.1A 转台电气 – Turn Table Appliance
QY50K.11.2B 起重臂电气 – Boom Electric System
QY35K.11.3B 副臂电气 – The Jib Boom Electric System
QY35K.11.4A 臂端滑轮电气 – Boom End Single Pulley Electric System
QY16K.11.6 配重电气 – Balance Electric System
QY50K.13 上车液压系统管路 – Hydraulic System Pipeline of Crane
QY50K.14C 副起重臂 – Jib Boom
QAY50.18 臂端单滑轮 – Boom End Single Chain Wheel
QY50K.20Ⅱ 平衡重 – Balance
QY35K.29 副起重钩 – Sub-hook
QY50K.90 钢丝绳及索具 – Steel Cable & Ringing
XCMG Crane QY50K Parts Manual EN ZH Parts 2.pdf (108 Pages)
XCMG Crane QY50K Parts Manual EN ZH Parts 3.pdf (109 Pages)
JSQ 驾驶室 – Cab
XZ16K.25A 底盘照明系统 – Lighting System
XZ50K.26 大梁线束安装 – Beam Wires (用于匹配 WD615.46 发动机)
XZ50K.26Ⅱ 大梁线束安装 – Beam Wires (用于匹配 ISLE+350 及 QSL325 发动机)
XZ16K.74A 电瓶箱安装 – Battery Box
XZ35K.39A 贮气筒安装 – Air Reservoir Assembly
XZ16K.41A 气路阀安装 – Air Valve Assembly
XZ50K.41Ⅱ 气路阀安装 – Air Valve Assembly (用于 ISLE+350 及 QSL325 发动机配 ABS 系统)
XZ50K.42 气路布管 – Air Circuit Pipe Assembly
XZ50K.42Ⅱ 气路系统布管 – Pneumatic Circuit Pipe Assembly (用于 ISLE+350 及 QSL325 发动机配 ABS 系统)
XZ50K.45 发动机安装 – Engine Install (WD615.46)
XZ50K.45Ⅱ 发动机安装 – Engine Install (ISLE+350)
XZ50K.45Ⅲ 发动机安装 – Engine Install (QSL325)
XZ35K.46 燃油箱 – Fuel Tank (WD615.46)
XZ50K.46 燃油箱 – Fuel Tank (ISLE+350 / QSL325)
XZ50K.47 消声器安装 – Muffler Assembly (ISLE+350 / WD615.46)
XZ25K.47 消声器安装 – Muffler Assembly (QSL325)
XZ16K.47Ⅱ 消声器安装 – Muffler Assembly (出口车型选装)
XZ50K.48 散热器安装 – Radiator Assembly (WD615.46)
XZ25K.48 散热器安装 – Radiator Assembly (ISLE+350 / QSL325)
XZ50K.50A 变速箱 – Gear-box
XZ50K.51 油泵装置 – Oil Pump Assembly (安装单联泵)
XZ50K.51Ⅱ 油泵装置 – Oil Pump Assembly (安装三联泵)
XZ50K.53B 传动轴 – Transmission Shaft (WD615.46)
XZ50K.53Ⅱ 传动轴 – Transmission Shaft (ISLE+350 / QSL325)
XZ50K.54A 前桥 – Front Axle (WD615.46)
XZ35K.55A 前悬架 – Front Suspension
XZ50K.56B 中桥 – Middle Axle (WD615.46)
XZ50K.57B 后桥 – Rear Axle (WD615.46)
XZ50K.54Ⅱ 前桥 – Front Axle (ISLE+350 / QSL325)
XZ50K.56Ⅱ 中桥 – Middle Axle (ISLE+350 / QSL325)
XZ50K.57Ⅱ 后桥 – Rear Axle (ISLE+350 / QSL325)
XZ16K.58A 后悬架(拉杆安装) – Rear Suspension (Pull Rod Fixing)
XZ50K.38 转向液压系统 – Steering Hydraulic System
XZ50K.65 转向系统 – Steering System
XZ50K.67 空滤器安装 – Air Filter Assembly
XZ50K.70A 变速操纵 – Transmission Operation
XZ16K.83A 空调装置 – Air Conditioning Unit (ISLE+350 / QSL325)
XZ25K.83A 空调装置 – Air Conditioning Unit (WD615.46)
QY50K.65A 下车配管总成 – Carrier Pipe Assembly
QY35K.66 液压油箱 – Hydraulic Oil Tank
QY35K.67 液压油箱支架 – Hydraulic Oil Tank Support
QY50K.68 水平油缸 – Level Cylinder
QY50K.69.1 前垂直油缸 – The Front Vertical Cylinder
QY50K.69.2 后垂直油缸 – The Rear Vertical Cylinder
QY16K.70B 中心回转体安装 – Center Revolving Body (WD615.46)
QY16K.70Ⅱ 中心回转体安装 – Center Revolving Body (ISLE+350 / QSL325)
QY50K.72A 支腿操纵系统 – Outrigger Operation System
