Hyundai
86
176,834
XCMG Rough Terrain Crane XCR90 Parts Catalog XUG0900RKSAC00980
Brand: XCMG
Type of Machine: Rough Terrain Crane
Model: XCMG XCR90 Rough Terrain Crane
PIN: XUG0900RKSAC00980
Publication Date: 2025
Number of Pages: 658 Pages
127402854 ROUGH TERRAIN CRANE
HOOK BLOCK
127400266 HOOK BLOCK
127400272 7 T HOOK BLOCK
116002086 7 T HOOK BLOCK
127404237 80 T HOOK BLOCK
130003823 SHEAVE ASSEMBLY
JIB
127400136 JIB
127400116 JIB MOUNTING ASSEMBLY
116000570 CONNECTING BRACKET ASSEMBLY
116000565 FIRST SECTION JIB ASSEMBLY
116000661 2ND JIB SECTION ASSEMBLY
116400387 MIDDLE BRACKET
116000926 BRACKET ASSEMBLY
BOOM
127405744 BOOM
127400679 BASE BOOM ASSEMBLY
127400598 ROPE GUARD ROLLER
127400361 2ND BOOM SECTION ASSEMBLY
127400470 3RD BOOM SECTION ASSEMBLY
127100523 SHEAVE ASSEMBLY
127405756 4TH BOOM SECTION ASSEMBLY
116000369 SHEAVE ASSEMBLY
127100619 SHEAVE ASSEMBLY
127405752 5TH BOOM SECTION ASSEMBLY
127400398 SHEAVE ASSEMBLY
127405743 TELESCOPING SYSTEM
127400586 GUIDE SHEAVE
127100752 SHEAVE
116000088 GUIDE BRACKET
127400623 ROPE SEAT
TELESCOPING CYLINDER ASSEMBLY
127400135 TELESCOPING CYLINDER ASSEMBLY
127403054 TELESCOPING CYLINDER I
116000008 TELESCOPING CYLINDER II
LUFFING CYLINDER
127400132 LUFFING CYLINDER
ELECTRIC SYSTEM INSTALLATION
127402851 ELECTRIC SYSTEM INSTALLATION
127103574 BATTERY ASSEMBLY
127402845 SUPERSTRUCTURE ELECTRICAL SYSTEM INSTALLATION
127402850 LMI SYSTEM ASSEMBLY
127402531 CAB ELECTRIC SYSTEM
127405304 TURNTABLE ELECTRICS
127405708 BOOM ELECTRICAL SYSTEM
127400014 JIB ELECTRICAL SYSTEM
127402507 INSTALLATION OF TRAVELING OPERATION ELECTRICAL SYSTEM
127402528 INSTALLATION OF THE TRAVELING OPERATION BEAM WIRING HARNESS
127402524 BATTERY BOX ASSEMBLY
127400003 TRAVELING LIGHTING SYSTEM
127500010 LEVEL GAUGE INSTALLATION
OIL PUMP DEVICE
127402843 OIL PUMP DEVICE
DRIVER'S CAB
127200375 DRIVER'S CAB
803589820 HUMAN-MACHINE INTERACTION CONTROL PANEL
802149602 OPERATOR'S CAB ASSEMBLY
860502302 EXTERIOR DECORATION AND ITS ACCESSORY SYSTEM
860502000 INTERIOR TRIM AND ACCESSORY SYSTEM
860502294 SLIDING DOOR ASSEMBLY
860502232 A/C ACCESSORY SYSTEM
860501988 WIPER ASSEMBLY
860502321 ELECTRICAL SYSTEM IN THE OPERATOR’S CAB
BRAKING SYSTEM
127400176 BRAKING SYSTEM
127402545 TURNTABLE BRAKING SYSTEM PIPE
127101584 ACCUMULATOR ASSEMBLY II
127104667 TURNTABLE BRAKE VALVE INSTALLATION
127901495 DRIVER'S CAB BRAKING SYSTEM PIPING
127101585 ACCUMULATOR ASSEMBLY I
127402547 PIPE FOR FRAME BRAKE SYSTEM
TURNTABLE
127402960 TURNTABLE
127401427 PIN
WINCH SYSTEM
127400096 WINCH SYSTEM
803092077 HYDRAULIC MOTOR
800357944 WINCH REDUCER
860640988 SWING REDUCTION GEAR
HYDRAULIC SYSTEM INSTALLATION
127403316 HYDRAULIC SYSTEM INSTALLATION
127400005 OIL INLET AND RETURN PIPING
127102000 MAIN VALVE INSTALLATION ASSEMBLY
127400143 OIL COOLER INSTALLATION ASSEMBLY
127102083 RADIATOR CONTROL VALVE INSTALLATION ASSEMBLY
127402927 PIPE FOR CHASSIS HYDRAULIC SYSTEM
127402569 OIL INLET AND OUTLET PIPING FOR PUMP
127402561 HYDRAULIC PIPING FOR OUTRIGGERS
127405255 TRAVEL HYDRAULIC PIPING
127402924 PRESSURE DETECTION POINT ARRANGEMENT
127400761 OUTRIGGER INTERNAL PIPING
127402570 OIL RETURN LEAKAGE PIPING
127402922 PILOT PIPING
127102071 PILOT VALVE INSTALLATION ASSEMBLY
127402929 TELESCOPING/AUXILIARY WINCH SELECTOR VALVE
127102070 FOOT PEDAL VALVE ASSEMBLY
127405205 TELESCOPING AND LUFFING PIPING
127401761 TELESCOPIC SWITCH VALVE ASSEMBLY
127102073 LUFFING COUNTERBALANCE VALVE INSTALLATION ASSEMBLY
127402082 MAIN WINCH PIPING
127403168 MAIN WINCH MOTOR INSTALLATION ASSEMBLY
127102078 BRAKE CONTROL VALVE ASSEMBLY
127401791 SLEWING PIPE
127401795 SLEWING BUFFERING VALVE ASSEMBLY
127402931 AUXILIARY PIPING
127402926 INSTALLATION ASSEMBLY OF AUXILIARY VALVE
127201861 COUNTERBALANCE VALVE INSTALLATION ASSEMBLY FOR OPERATOR’S CAB TILTING
127102108 PILOT LEVER INSTALLATION ASSEMBLY
127104090 LEFT LEVER ASSEMBLY
127104091 RIGHT LEVER ASSEMBLY
AUXILIARY WINCH
127401366 AUXILIARY WINCH
127400069 AUXILIARY WINCH ELECTRICAL SYSTEM
803087190 HYDRAULIC MOTOR
127405735 WIRE ROPE AND RIGGING
127400041 AUXILIARY WINCH PIPING
127400106 AUXILIARY WINCH MOTOR ASSEMBLY
127400148 QUICK CONNECTOR SEAT INSTALLATION ASSEMBLY
COUNTERWEIGHT
127402866 COUNTERWEIGHT
ENGINE HOOD
127400720 ENGINE HOOD
AIR FILTER
127402432 AIR FILTER
800176627 AIR FILTER
RADIATOR
127402506 RADIATOR
800363054 RADIATOR ASSEMBLY
800158687 EXPANSION TANK
ENGINE INSTALLATION
127402462 ENGINE INSTALLATION
800201580 DIESEL ENGINE
860563064 OIL COOLER
860509084 FUEL PUMP
860509107 WATER PUMP SYSTEM
860563046 GENERATOR COMPONENT
800164673 FLYWHEEL HOUSING 2
800164710 FLYWHEEL2
860563069 OIL SUMP
127402460 FUEL FILTER INSTALLATION
TIRES
127401561 TIRES
AXLE ASSEMBLY
127401560 AXLE ASSEMBLY
127405245 AXLE 2 ASSEMBLY
800387443 AXLE 2
127402321 STEERING CYLINDER ASSEMBLY
127100007 SUSPENSION CYLINDER
127102271 CONNECTING ROD MECHANISM
127405246 AXLE 1 ASSEMBLY
800387442 AXLE 1
COVERING
127402862 COVERING
127401323 RIGHT COVERING
127101731 LEFT MACHINE SHED
127101703 LEFT LOWER HOOD DOOR
DECK ASSEMBLY
127402912 DECK ASSEMBLY
127401227 TOOLBOX
127401226 TOOLBOX
127401225 OUTRIGGER COVER PLATE DOOR
127401103 OUTRIGGER COVER PLATE DOOR
DRIVER'S CAB TILTING MECHANISM
127100403 DRIVER'S CAB TILTING MECHANISM
TRANSMISSION INSTALLATION
127401047 TRANSMISSION INSTALLATION
800357714 OIL COOLER
127401044 TRANSMISSION PRE-INSTALLATION
800372034 TRANSMISSION
127402601 FILLING PIPE AND DIP STICK ASSEMBLY
DRIVE SHAFT
127400724 DRIVE SHAFT
FUEL TANK
127101484 FUEL TANK
819983852 FUEL TANK
STEERING SYSTEM
127400251 STEERING SYSTEM
127402546 HYDRAULIC PIPING FOR TURNTABLE STEERING SYSTEM
127403325 DRIVER'S CAB STEERING SYSTEM PIPING
127101513 PRIORITY VALVE MOUNTING ASSEMBLY
127104668 LOW PRESSURE RELIEF VALVE INSTALLATION ASSEMBLY
127402548 FRAME STEERING SYSTEM PIPING
127600910 MULTI-MODE STEERING VALVE ASSEMBLY
OUTRIGGER BEAM ASSEMBLY
127400783 OUTRIGGER BEAM ASSEMBLY
127402175 PIN I
127403399 LOCKING PIN
127400784 OUTRIGGER BEAM
127603203 OUTRIGGER FLOAT ASSEMBLY
127405734 EXTENSION CYLINDER
127400115 JACK CYLINDER
127405738 WIRE ROPE AND RIGGING
AUXILIARY SHEAVE
127400873 AUXILIARY SHEAVE
SLEWING SYSTEM
127400159 SLEWING SYSTEM
803000179 MOTOR
800362296 SLEWING REDUCER
TURNTABLE LOCKING MECHANISM
127100459 TURNTABLE LOCKING MECHANISM
CONNECTOR OF CENTRAL ROTARY JOINT
127101922 CONNECTOR OF CENTRAL ROTARY JOINT
A/C DEVICE
127401740 A/C DEVICE
860503371 OUTDOOR UNIT ASSEMBLY
860503370 EVAPORATOR ASSEMBLY
MUFFLER
127402497 MUFFLER
SLEWING BEARING
127400711 SLEWING BEARING
HYDRAULIC OIL TANK ASSEMBLY
127400259 HYDRAULIC OIL TANK ASSEMBLY
803100038 RETURN FILTER
803100027 AIR FILTER
GAS SOURCE ASSEMBLY
127405700 GAS SOURCE ASSEMBLY
GPS INSTALLATION
127100272 GPS INSTALLATION
