Momed80
150
35,046
XCMG Road Grader GR2205T Parts Catalog
Brand: XCMG
Type of Machine: Road Grader
Model: XCMG GR2205T Road Grader
Number of Pages: 324 Pages
382301662 Motor Grader
Engine System
382301589 Engine System
803400571 Fuel Filter
803400570 Fuel Filter
800153497 Oil-Water Separator
860532537 Exhaust Pipe Assy
800368709 Radiator Assembly
Assembly Of Engine Hood
382301598 Assembly Of Engine Hood
382301603 Assembly Of Engine Hood
382301599 Middle Cover Assembly
Seat Assembly
380605051 Seat Assembly
Cab Assembly
382301585 Cab Assembly
380605191 Cab
380605049 Console System
382301467 Operation Station Air Outlet System Assembly
382301212 The Door Total
382301268 Cab Glass Assembly
380605277 Assembly Of Assembly Parts
380401590 Ladder
382301591 Hydraulic System
382301597 Hydraulic Oil Tank
813407429 Oil Return Filter
803190351 Air Filter With Lock
382301594 Steering Hydraulic System
803084381 Priority Valve
803087366 Front Wheel Steering Cylinder
382301596 Brake Hydraulic System
804009799 Double-Circuit Brake Valve
801504498 Park Valve
380605355 Working Hydraulic System
803090546 Left Blade Angle Change Cylinder
803090548 Right Blade Angle Change Cylinder
803099045 Cylinder For Blade Lift
803099048 Swing Cylinder Of Shovel
804002849 Tilting Cylinder Of Front Wheel
804009980 Hinged Steering Cylinder
804001643 Muti Way Directional Valve
Pull Pin Hydraulic System
381101289 Pull Pin Hydraulic System
Blade Assy
380605101 Blade Assy
380400855 Angular Position Device(Right)
380605097 Blade
380400869 Angular Position Device(Left)
Working Device
382301605 Working Device
380605291 Swing Frame Assembly
380401121 Fork Assembly
382301607 Working Device
380605306 Assembly Of Rotary Circle
Rack
382301631 Rack
380402729 Overlay
382301874 Grease Filling
382301628 Front Rack
382301625 Rear Rack
Electric System
382301573 Electric System
382301566 Instrumentation Console Assy
382301569 Cab Electrical Assembly
382301572 Assembly Of Cab Rear Compartment
382301567 Control Box
Front Axle Assembly
380906170 Front Axle Assembly
380906184 Steering Pull Rod
381204599 Fuel Tank
Transmission System
382301590 Transmission System
380800400 Grease Filling On Rear Axle
382301197 Oil Filling Device
800360659 Fluid Power Gear-Box
860546151 Engine Connection
860546152 Torque Convertor
860537971 Actuator
860546153 Transfer Case Housing
860546154 Transfer Case Housing
860546016 Idler Gear
860546022 Clutchkv+K1
860546155 Clutch
860546024 Clutchkr+K2
860546156 Clutch
860546157 Clutch
860546026 Clutchk3+K4
860546158 Output Device
860546015 Output Device
860546017 Parking Brake
860537984 Power Output Device
860546159 Power Take-Off
860537988 Power Output Device 3
860546160 Power Take-Off
860537991 Shifting System 1
800107860 Speed Control System
860537993 Filter Asm
860537996 Pressure Regulator
860546161 Induction Transmitter
860546162 Induction Transmitter
860546163 Emergency Steering Pump Assy
860546164 Water Filler Neck
860538007 Tube 2
860546165 Oil Pipe
860546166 Scattered Parts
860546167 Scattered Parts
382300247 Assembly Of Oil Filling Pipe
Control Box
382300282 Control Box
382301601 Control Box
Ac System
382301204 Ac System
803597418 Air Conditioning System Assembly
Assembly Of Rear Scarifier
382103909 Assembly Of Rear Scarifier
381204592 Back Ripper Hydraulic System
803011223 Lift Cylinder Of Rear Scarifier
382300130 Rabble Blade Assembly
381203194 Preloaded Rod
Front Bulldozer
381100904 Front Bulldozer
381100362 Blade Assy
381101204 Front Blade Htdraulic Tube
Front Counterweight
382301612 Front Counterweight
Rear Counterweight
382301613 Rear Counterweight
