Momed80
150
35,046
XCMG Road Grader GR215 Parts Catalog
Brand: XCMG
Type of Machine: Road Grader
Model: XCMG GR215 Road Grader
Number of Pages: 348 Pages
380900013 Gr215diiimotor Grader
Engine System
380904402 Engine System
800152100 Engine
803010881 Radiator Assembly
800105955 Air Filter
Engine Hood
380902560 Engine Hood
380905564 Hood Hydraulic Lift System
Tank Assy
380902563 Tank Assy
803190351 Air Filter With Lock
803190287 Filter
803112558 Suction Filter
380602021 Cab
380602023 Glass Assy
380602022 Cab Door Assembly
380602035 Assembly Of Right Door
380602034 Assembly Of Left Door
380602320 Cab Assembly Assy
380602063 Door Lock Installation
380602060 Rearview Installation
380602062 Rearview Installation
380602061 Abat Vent Installation
380602066 Cab Backplate Installation
380602510 Seat
Console
380904654 Console
Control Box
380601993 Control Box
380904403 Hydraulic System
380905605 Brake Hydraulic System
803011203 Brake Valve
380905561 Working Hydraulic System
803044374 Multi-Way Reversing Valve
803010911 Cycloid Motor
803087365 Tilting Cylinder Of Front Wheel
803094764 Swing Cylinder Of Shovel
803090548 Right Blade Angle Change Cylinder
803090546 Left Blade Angle Change Cylinder
803087969 Extraction Cylinder Of Shovel
803090544 Left Articulated Steering Cylinder
803090545 Right Hinged Steering Cylinder
803094763 Left Blade Hoist Cylinder
803094762 Right Blade Hoist Cylinder
380905606 Steering Hydraulic System
803011053 Steering Gear
803087366 Front Wheel Steering Cylinder
Swing Chassis
380902141 Swing Chassis
380903571 Hydro-Cylinder Keyway
Rack
380902562 Rack
380905152 Front Rack
380905589 Rear Rack
380902076 Left Accumulator Box
380902077 Right Accumulator Box
380902431 Toolbox Assy
380602836 Support Assy
380501080 Ladder
380902078 Telescopic Tube
Front Blade
380900335 Front Blade
380902203 Front Blade Htdraulic Tube
Front Counterweight
380905595 Front Counterweight
380902532 Front Counterweight
Front Axle Assembly
380906170 Front Axle Assembly
380906184 Steering Pull Rod
Working Device
380601591 Working Device
380700424 Assembly Of Rotary Circle
Blade Assy
380602901 Blade Assy
380601488 Angular Position Device(Left)
380602903 Blade
380601504 Angular Position Device(Right)
Ac System
380904655 Ac System
380904647 Air Flue Cover
380904761 Right Back Overlay
380904760 Left Back Overlay
803592243 Air Conditioner Assembly
Hand Brake Control
380602357 Hand Brake Control
Engine Control
380601401 Engine Control
Transmission System
380905784 Transmission System
380800400 Grease Filling On Rear Axle
800355590 Fluid Power Gear-Box
860546151 Engine Connection
860546152 Torque Convertor
860537971 Actuator
860546153 Transfer Case Housing
860546154 Transfer Case Housing
860546016 Idler Gear
860546022 Clutchkv+K1
860546155 Clutch
860546024 Clutchkr+K2
860546156 Clutch
860546157 Clutch
860546026 Clutchk3+K4
860546158 Output Device
860546015 Output Device
860537638 Parking Braking
860546017 Parking Brake
860537984 Power Output Device
860546159 Power Take-Off
860537988 Power Output Device 3
860546160 Power Take-Off
860537991 Shifting System 1
800107860 Speed Control System
860537993 Filter Asm
860537996 Pressure Regulator
860546161 Induction Transmitter
860546162 Induction Transmitter
860546163 Emergency Steering Pump Assy
860546164 Water Filler Neck
860538007 Tube 2
860546165 Oil Pipe
860546166 Scattered Parts
860546167 Scattered Parts
380902497 Assembly Of Oil Filling Pipe
380601396 Grease Filling On Rear Axle
Electric System
380904673 Electric System
380904676 Operating Plate
380904677 Relay Plate
380905593 Instrumentation Console Assy
Rear Counterweight
380905596 Rear Counterweight
Rear Ripper
380600223 Rear Ripper
380605022 Rear Ripper Hydraulic System
803011223 Lift Cylinder Of Rear Scarifier
380902192 Rake Teeth
