Momed80
150
35,046
XCMG Motor Grader GR5505 Parts Catalog
Brand: XCMG
Type of Machine: Motor Grader
Model: XCMG GR5505 Motor Grader
Pin Number: XUG55T32EMDB00021
Number of Pages: 752 Pages
382204510 Motor Grader
Front Axle Assembly
382204039 Front Axle Assembly
382202452 Steering Pull Rod
382202449 Tilting Pull Rod
Front Counterweight
382203661 Front Counterweight
Centralized Lubrication System
382204101 Centralized Lubrication System
381204605 Front Axle Lubrication System
381204603 Lubrication System Of Working Device
381204606 Layout Plan Of Main Pipelines
381204602 Rear Vehicle Lubrication System
Rack
382204260 Rack
382204327 Front Rack
382203186 Fork Assembly
200203443 Rear Rack
382205228 Bottom Plate Assembly
Working Device
382204356 Working Device
382103923 Hydraulic System
382103924 Working Hydraulic System
382204397 Pipe Clip Assembly
382204604 Pipe Clamp50
382204405 Pipe Clip Assembly
380201921 Right Multitandem Installation
380201890 Left Multitandem Installation
380201876 Pipe Clip Assembly
380201857 Installation Of Rotary Joint Assembly
382204439 Pipe Clamp41
380201946 Balancing Valve Joint
380201863 Accumulator Assembly Installation
380201867 Valve Block Joint Installation
382204390 Pipe Clip Assembly
380201862 Plunger Pump
382204373 Pipe Clamp31
380201889 Balancing Valve Joint
382204433 Pipe Clamp43
382103926 Front Wheel Tilt Cylinder Assembly Installation
380201944 Balancing Valve Joint
380201892 Lift/Hoist Cylinder Assembly
380201919 Circle Drive Assembly
382204443 Pipe Clamp40
382204610 Pipe Clamp52
380201922 Combined Block
382204420 Pipe Clamp42
380201794 Balancing Valve Joint Installation 2
380201884 Blade Centreshift Cylinder
380201785 Balancing Valve Joint Installation 3
804019521 Extraction Cylinder Of Shovel
804019522 Change Cylinder Of Shovel Angle
380201886 Right Hinged Cylinder Assembly Installation
380201789 Left Hinged Cylinder Assembly Installation
382204380 Pipe Clamp27
382204609 Pipe Clamp55
382204462 Pipe Clamp35
382204367 Pipe Clamp34
382204455 Pipe Clamp33
382204451 Pipe Clamp32
382204408 Pipe Clamp30
382204600 Pipe Clamp56
382204382 Pipe Clamp26
382204430 Pipe Clamp38
382103925 Steering Hydraulic System
380201881 Steering Pump Assembly Installation
380201869 Installation Of Safety Valve Assembly Joint
380201877 Emergency Steering Pump Assembly Installation
380201879 Steering Assembly
380201925 Steering Pump Assembly Installation
380201888 Left Front Steering Cylinder Assembly Installed
380201887 Right Steering Cylinder Assy
380201882 Brake Hydraulic System
380201880 Brake Valve Assy
380201878 Installation Of Filling Valve Connector
380201874 Relay Valve Connector Installation 2
380201872 Relay Valve Connector Installation 1
380201883 Accumulator Assembly2
380201891 Accumulator Assembly1
382204387 Pipe Clip Assembly
382204395 Pipe Clip Assembly
382204459 Pressure Relief Valve
380201870 Gear Pump Assy
380201865 Hydraulic Power Unit Installation
380201861 Installation Of Safety Valve Assembly Joint
382204411 Pipe Clip Assembly
380201885 Independent Cooling Hydraulic System
380201871 Fan Motor
380201873 Fan Pump
382204421 Pipe Clamp37
380201866 Reversing Valve
382104012 Hydraulic Oil Tank
380201923 Oil Return Block Assy
803272894 Filter
803080468 Air Filter
803190351 Air Filter With Lock
380201920 Steering Pump Suction Assy
803100089 Oil Filter
380201924 Working Pump Oil Suction Block Assy
382103927 Pressure Measurement System
Cab Assembly
382203612 Cab Assembly
382203611 Cab
382205428 Assembly Of Assembly Parts
382205399 Control Panel Assembly
382205339 Interior Trim Assembly
382205391 Cab Glass Assembly
382205379 Cab Door Assembly
382203850 Fuel Tank
382203853 Diesel Oil Tank
381204601 Rapid Fuel Filling
Engine System
382204115 Engine System
800166699 Engine
382204127 Fixing Bracket
800157353 Oil Filter (Main Engine)
800172092 Radiator Assembly
Shield For Diesel Engine
382203646 Shield For Diesel Engine
382203647 Rear Hood
382203648 Front Cover
Mustercentralized Extinguishing System
382204480 Mustercentralized Extinguishing System
Assembly Of Rear Scarifier
382204055 Assembly Of Rear Scarifier
382204091 Back Ripper Hydraulic System
382203407 Balancing Valve Joint Mounting Kit
Centralized Filling System And Sampling System
382204497 Centralized Filling System And Sampling System
Electric System
382203620 Electric System
382203629 Main Power Switch Box
381304055 Electrical Assembly Of Handrail Cabinet
382203619 Instrumentation Console Assy
382203625 Cab Electrical Assembly
382203633 Assembly Of Cab Rear Compartment
Ac System
382205352 Ac System
382203822 Air Conditioning System Assembly
Transmission System
382203790 Transmission System
382203924 Brake Cooling Oil Tank
382205205 Pipe Clip Assembly
382203777 Oil Filler Port Assembly
803306820 Filter Series
382203782 Connector
382203793 Shift Valve Group
382203789 Drive Axle Cooling System
382203778 Valve Block Joint Installation
800362245 Torque Convertor
860567792 Pump Assy
860567793 Hub
860553132 Supporting Plate
860553127 Installation Plate Component
860553138 Torque Converter Housing
860553146 Propulsion Pump Assembly
860567794 Turbine Shaft Assembly
860553148 Bearing Cover Assembly
860553149 Gear Housing Assembly
860567795 Bushing
860527871 Pressure Regulating Valve Assembly
860567796 Oil Pump Assembly
860567798 Drive Plate Assembly
860553154 Lock Valve Assembly
860553155 Regulating Valve Bank
860567727 Filter
800362246 Transmission
800354475 Rear Axle
860508500 Main Reducer Assembly
860508501 Slewing Gear
860508502 Balancing Box
860508503 Balancing Box
382205019 Fixing Groupⅱ
382205021 Fixing Group
Platform Assembly
382204471 Platform Assembly
382204822 Left Fence
382204903 Pole
382204864 Escape Ladder
382204699 Left Walking Aisle
382204698 Passageway
382204732 Passageway
382204983 Left Body Assembly
382203312 Rear Ladder Assembly
382204777 Passageway
382204981 Battery Box
382205281 Guard Board
382205152 Case Body
Seat Assembly
382203832 Seat Assembly
Blade Assy
382203951 Blade Assy
382203966 Blade
382203979 Assembly Of Angular Displacement Sensor
