XCMG Motor Grader GR3005T Pro Parts Catalog
Brand: XCMG
Type of Machine: Motor Grader
Model: XCMG GR3005T Pro Motor Grader
Number of Pages: 628 Pages
381304100 Gr3005t3road Grader
Engine System
381303574 Engine System
800164462 Engine
800164462 Engine
800164235 Radiator
800164235 Radiator
803374076 Filter Of Air
800152353 Water Separator
Engine Hood
381303635 Engine Hood
381303652 Hood
Seat Assy
381303480 Seat Assy
381201567 Handrail Box Assembly
381303584 Cab
381303579 Driver Cab
381303940 Cab Door Assy
381303588 Assembly Parts Assembly
381303941 Cab Glass Assembly
381303847 The Ladder
381303611 Hydraulic System
381303617 Working Hydraulic System
803092273 Front Wheel Tilt Cylinder
382101649 Left Multitandem Installation
382100845 Right Multitandem Installation
381303601 Confluence Block 3 Installation
381303592 Pipe Clamp Assembly1
381303597 Confluence Block 1 Installation
381303604 Plunger Pump Installation
381303594 Confluence Block 2 Installation
382103846 Confluence Block 4 Installation
382103849 Priority Valve Assembly Installation
803164428 Solenoid Valve
803092375 Valve
803092278 Right Articulated Steering Cylinder
803011164 Counterbalance Valve
803092279 Left Articulated Steering Cylinder
803092280 Rticulated Steering Cylinder
382103086 Rotary Jiont Installation
381303616 Steering Hydraulic System
381303593 Gear Pump Installation Assembly
382103240 Pipe Clamp Assembly
382103845 Emergency Steering System
381303600 Steering Gear Mounting Subassembly
381303614 Brake Hydraulic System
381303591 Brake Valve Installation
382101617 Prefill Valve Installing
381303607 Parking Brake Valve Assembly
381303613 Radiator Fan System
803080503 Reversing Valve Block
382100898 Scattered Heat Pump
381303612 Hydraulic Oil Tank Assembly
803406639 Oil-Filter
803190351 Lockable Breather Filter
803112558 Suction Filter
382103238 Central Pressure Measurement System
Swing Frame Pull Pin Hydraulic System
381303191 Swing Frame Pull Pin Hydraulic System
Control Panel Assembly
381203616 Control Panel Assembly
381202487 Movable Table Frame
381203617 Assembly Parts
381203615 Instrument Panel Housing
Blade Assy
381304019 Blade Assy
381304026 Blade
382103315 Angular Position Device Gp
Blade Assy
382103363 Blade Assy
382103359 Blade
Work Equipment
381303692 Work Equipment
381303684 Working Set
381303666 Rotary Ring Assy
381302996 Rotary Gear Lubrication Assembly
800369153 Turbine Box
381303685 Swing Chassis Ass’y
Framework Body
381304118 Framework Body
381304120 Front Frame
381304112 Front Frame Cover Plate Assembly
381304117 Rear Frame
381304137 Transmission Guard Plate
381303169 Frame Hinged Lubrication Draw-Out Filling
Ladder
381302883 Ladder
Electric System
381303460 Electric System
381303466 Cab Electrical Assembly
381303462 Cab Rear Cabin Assembly
381303458 Main Power Switch Box
381303468 On-Board Maintenance Control Box
381304055 Handrail Box Electrical Assembly
381303467 Electric Control Cabinet Assembly
Front Axle Assy
381303752 Front Axle Assy
381303516 Fuel Tank
381303529 Battery Box Cover
Transmission System
381303577 Transmission System
381304060 Rear Alxe Grease Filling
381303539 Oiling Tube Assy
800357216 Wet Drive Axle—Naf
860160800 Main Reducer Assembly
860507732 Bridge Body
860507733 Bridge Body
860508011 Balancing Box
860160804 Wheel Reducer Assembly
Ac System
381303483 Ac System
381201516 Turbocharger Assembly
382101567 Bridge Supercharger
381201521 Air Intake
381201554 Air-Comditioner Ventilator
381303900 Air Conditioning Assembly
Rear Ripper
382103544 Rear Ripper
382101761 Rear Ripper Hydraulic System
382300130 Rabble Blade Assembly
Bob-Weight
381303545 Bob-Weight
Rear Counterweight
381303535 Rear Counterweight
Lubricating System
381303495 Lubricating System
381303491 Front Axle Lubrication System
381303489 Working Device Lubrication System
381303486 Rear Car Lubrication System With Rear Loose
381303492 Main Pipeline Layout Drawing
381303488 Rear Car Lubrication System Without Rear Scarifier
Ansul Dry Powder Automatic Fire Extinguishing System
381304095 Ansul Dry Powder Automatic Fire Extinguishing System
Fast Fuel Filling System
381303621 Fast Fuel Filling System
Brand: XCMG
Engine System
800164462 Engine
800164462 Engine
800164235 Radiator
800164235 Radiator
Engine Hood
381303652 Hood
Seat Assy
381303480 Seat Assy
381303584 Cab
803092375 Valve
Blade Assy
381304026 Blade
Blade Assy
382103359 Blade
Work Equipment
Framework Body
Ladder
381302883 Ladder
Electric System
Front Axle Assy
381303516 Fuel Tank
Transmission System
Ac System
381303483 Ac System
Rear Ripper
Bob-Weight
Rear Counterweight
Lubricating System
- XCMG Wheel loader ZL50G service manual
- XCMG Road Grader Parts Handbook GR215A
- XCMG ZL50G Wheel Loader Parts Manual
- XCMG ZL30G Wheel Loader Parts List
- XCMG LW420F Wheel Loader Instruction Manual
- XCMG Excavator Loader WZ30-25 Parts Catalog EN ZH
- XCMG LW500F Wheel Loader Parts Manual part 1
- XCMG GR215 Parts Manual
- XCMG YL16 YL 20 Types Pneumatic Tyre Roller Parts List
- XCMG YZ 16 JC YZ 18JC Vibratory Roller Operation and Maintenace Manual
- XCMG ZL50A.2 Spare Parts
- XCMG LW500F Wheel Loader Parts Manual part 2
- XCMG XS 160 XS 190 Parts List of Vibratory Roller
- XCMG LW330F Wheel Loader Parts Manual
- XCMG PAT DS 380 Parts Manual
