Momed80
152
37,162
XCMG Light-Duty Mining Truck XDR80T Parts Manual XUG00803PNWB36398
Brand: XCMG
Type of Machine: Light-Duty Mining Truck
Model: XCMG XDR80T Light-Duty Mining Truck
PIN: XUG00803PNWB36398
Number of Pages: 354 Pages
Three-Axle Rigid Mining Truck
Power System
Suspension System
Gearbox Pull Rod Assembly
Intake Support Assembly
Intake And Exhaust System
Conversion Device
Fuel System
Fuel Tank Assembly
Frame Assembly
Lift Base Assembly
Stone Breaking Plate Assembly
Accumulator Support Assembly
Tail Support Assembly
Safety Protection
Rear Handrail Assembly
Right Handrail Assembly
Get-On Handrail Assembly I
Get-On Handrail Assembly Iii
Access Door Assembly
Right Rearview Mirror Assembly
Cargo Compartment Assembly
Shock Pad
Drive System
Middle Axle Assembly
Outer Wheel Assembly
Inner Wheel Assembly
Middle Axle
Braking System
Air Brake Pipeline
Air Inlet Assembly
Brake Assembly
Gearbox Control System
Transmission Shaft Final Assembly
Transmission Shaft Assembly
Clutch Operating System
Rear Axle Assembly
Rear Axle
Front Axle Assembly
Front Wheel Rim Assembly
Left Front Wheel Assembly
Right Front Wheel Assembly
Steering Tie Rod
Centralized Lubricating System
Lubricating System
Deck Assembly
Left Deck Assembly
Mudguard Assembly
Front Wheel Mudguard Ii
Front Wheel Mudguard Iii
Front Deck Assembly
Get-On Pedal Assembly
Right Deck Assembly
Engine Cover Assembly
Fire Extinguisher Cylinder Assembly
System
Battery Harness Assembly
Driver’s Cab
Glass Assembly
Console Ii
Wiper Assembly
Interior Assembly
Car Door Assembly
Left-Side Rear-View Mirror Bracket (Extended By 100mm)
Lifting System Assembly
Lifting System Hydraulic Assembly
Lifting System Air Control Assembly
Lifting Cylinder Assembly
Steering Gear Component
Steering Cylinder Oil Circuit Assembly
Steering Control Assembly
Fuel Tank Component
Rear Suspension Cylinder
Air Conditioning System
Air Conditioning Assembly
Shock Pad Assembly
Evaporator-Compressor Hose
Accessory
Fire Extinguisher Components
Logo (35m3)
