118
6,911
XCMG Hydraulic Excavator XE35U Parts Manual EN
Brand: XCMG
Model: XCMG XE35U Hydraulic Excavator
PIN: XUGF035UCNKA03201
Number of Pages: 298 Pages
310202358 HYDRAULIC EXCAVATOR
REVOLVING FRAME ASSEMBLY
310204046 REVOLVING FRAME ASSEMBLY
310202307 BULKHEAD ASSEMBLY
SWING MECHANISM
310201849 SWING MECHANISM
800556906 SWING BEARING
804008999 SWING MOTOR
COUNTERWEIGHT ASSEMBLY
310201723 COUNTERWEIGHT ASSEMBLY
CAB ASSEMBLY
310202420 CAB ASSEMBLY
310201648 TURNOVER MECHANISM
803091077 ELEVATION CYLINDER
803091076 MANUAL PUMP
310201946 COVER PLATE ASSEMBLY
310202479 LEFT ROD ASSEMBLY
310202483 LEFT TRAVEL PILOT VALVE ASSEMBLY
310202489 RIGHT ROD ASSEMBLY
310202491 RIGHT FOOT PEDAL ASSEMBLY
310202421 CAB WELDING ASSEMBLY
803587418 SEAT ASSEMBLY
HOOD ASSEMBLY
310201724 HOOD ASSEMBLY
310201728 LEFT FRONT HOOD ASSEMBLY
310201729 RIGHT REAR HOOD ASSEMBLY
310201730 LOCK BRACKET ASSEMBLY
310201731 HOOD ASSEMBLY
310201733 REAR HOOD ASSEMBLY
310202165 RIGHT REAR HOOD LOCK
HYDRAULIC PILOT CONTROL SYSTEM
310202285 HYDRAULIC PILOT CONTROL SYSTEM
310202286 PILOT LINE ASSEMBLY
310201793 TRAVEL PILOT VALVE ASSEMBLY
310201795 GREASE BANK ASSEMBLY
310201796 BOOM RUNOUT PILOT VALVE ASSEMBLY
310202381 PILOT VALVE ASSEMBLY
310201973 PILOT VALVE ASSEMBLY
310202288 FILTER VALVE ASSEMBLY
310202289 PILOT VALVE GROUP ASSEMBLY
310202290 GREASE BANK ASSEMBLY
310101787 VALVE ASSEMBLY
310202287 PILOT CONTROL LINE ASSEMBLY
UPPERSTRUCTURE HYDRAULIC SYSTEM
310202293 UPPERSTRUCTURE HYDRAULIC SYSTEM
310201976 EQUIPMENT LINE ASSEMBLY
803073883 BUCKET CYLINDER
803073881 ARM CYLINDER
803073882 BOOM CYLINDER
310200887 PIPE CLIP ASSEMBLY
803073884 BOOM SWING CYLINDER
310200891 PIPE CLIP ASSEMBLY
310201516 PIPE CLIP ASSEMBLY
310201514 PIPE CLIP ASSEMBLY
310202294 PILE DRIVER REVOLVING FRAME LINE ASSEMBLY
310200907 U-PIPE CLIP ASSEMBLY
310201898 SWING MOTOR JOINT ASSEMBLY
310202295 JOINT ASSEMBLY
310202298 MAIN CONTROL VALVE FITTING ASSEMBLY
HYDRAULIC OIL TANK ASSEMBLY
310202272 HYDRAULIC OIL TANK ASSEMBLY
803369805 AIR CLEANER ASSEMBLY
ENGINE ASSEMBLY
310200922 ENGINE ASSEMBLY
310200923 ENGINE MOUNTING ASSEMBLY
800155088 ENGINE
310202205 AIR INLET SYSTEM
800172106 AIR CLEANER ASSEMBLY
310202213 RADIATOR ASSEMBLY
800159702 RADIATOR ASSEMBLY
800151833 FUEL WATER SEPARATOR
FUEL TANK
310201806 FUEL TANK
ELECTRICAL CONTROL SYSTEM
310204890 ELECTRICAL CONTROL SYSTEM
310201635 BATTERY ASSEMBLY
310202503 RIGHT ARMREST BOX ASSEMBLY
310204891 LEFT ARMREST BOX
310202517 ELEMENT PLATE MOUNTING ASSEMBLY
AIR CONDITIONER
310204175 AIR CONDITIONER
310201326 TENSIONER ASSEMBLY
UNDERCARRIAGE ASSEMBLY
310201967 UNDERCARRIAGE ASSEMBLY
800374914 TENSIONER
HYDRAULIC SYSTEM - UNDERCARRIAGE
310201981 HYDRAULIC SYSTEM - UNDERCARRIAGE
310200912 SWIVEL JOINT ASSEMBLY
800305417 SWIVEL
804013316 TRAVEL MOTOR
804008939 DOZER BLADE CYLINDER
EQUIPMENT
310202373 EQUIPMENT
310203928 BUCKET
310203938 BUCKET BODY
310202525 BOOM
310203718 ARM
LUBRICATION SYSTEM
310201173 LUBRICATION SYSTEM
SIGN
310202364 SIGN
