118
6,911
XCMG Hydraulic Excavator XE27U Parts Manual EN
Brand: XCMG
Model: XCMG XE27U Hydraulic Excavator
PIN: XUGA0275CNKA02097
Number of Pages: 314 Pages
310203888 HYDRAULIC EXCAVATOR
REVOLVING FRAME ASSEMBLY
310203056 REVOLVING FRAME ASSEMBLY
SWING MECHANISM
310203856 SWING MECHANISM
800557481 SWING BEARING
804017152 SWING MOTOR
COUNTERWEIGHT ASSEMBLY
310203096 COUNTERWEIGHT ASSEMBLY
CAB ASSEMBLY
310204082 CAB ASSEMBLY
802155617 CAB
310203184 FRONT DOOR
310203234 BASE PLATE ASSEMBLY
310203222 BASE PLATE
310203179 BASE PLATE
310104218 LEFT ROD ASSEMBLY
310202483 LEFT TRAVEL PILOT VALVE ASSEMBLY
310104216 RIGHT ROD ASSEMBLY
310202491 RIGHT FOOT PEDAL ASSEMBLY
801975312 SEAT
HOOD ASSEMBLY
310203446 HOOD ASSEMBLY
310203513 PLATE ASSEMBLY
310203486 ENGINE HOOD ASSEMBLY
310203466 RIGHT HOOD ASSEMBLY
310203485 GUARD ASSEMBLY
310203493 REAR HOOD ASSEMBLY
310203488 LEFT REAR HOOD ASSEMBLY
310203535 GUARD ASSEMBLY
310203527 ENGINE COMPARTMENT BULKHEAD ASSEMBLY
310203565 BRACKET
310203520 LOCATING DEVICE
310204674 HINGE ASSEMBLY
310203567 ENGINE HOOD CONNECTING FRAME ASSEMBLY
HYDRAULIC PILOT CONTROL SYSTEM
310203847 HYDRAULIC PILOT CONTROL SYSTEM
310204717 PILOT CONTROL LINE ASSEMBLY
310203848 PILOT LINE ASSEMBLY
310202858 FILTER ASSEMBLY
310203834 QUADRUPLE PROPORTIONAL SOLENOID VALVE ASSEMBLY
310204216 TRAVEL PILOT VALVE ASSEMBLY
310101787 VALVE ASSEMBLY
310204274 PILOT VALVE ASSEMBLY
310203835 DOZER JOYSTICK ASSEMBLY
310203833 GREASE BANK ASSEMBLY
310202816 BIGEMINAL SOLENOID VALVE ASSEMBLY
UPPERSTRUCTURE HYDRAULIC SYSTEM
310203850 UPPERSTRUCTURE HYDRAULIC SYSTEM
310204151 EQUIPMENT LINE ASSEMBLY
804009838 DEFLECTION CYLINDER
804009837 BOOM CYLINDER
804009839 ARM CYLINDER
804009841 BUCKET CYLINDER
310203849 PILE DRIVER REVOLVING FRAME LINE ASSEMBLY
310202827 JOINT ASSEMBLY
310204215 MAIN CONTROL VALVE CONNECTION ASSEMBLY
310203839 BLOCK ASSEMBLY
310203837 SWING MOTOR JOINT ASSEMBLY
310204592 PIPE CLIP ASSEMBLY
HYDRAULIC OIL TANK ASSEMBLY
310203167 HYDRAULIC OIL TANK ASSEMBLY
ENGINE ASSEMBLY
310202948 ENGINE ASSEMBLY
310202981 AIR INLET SYSTEM
800166462 AIR CLEANER ASSEMBLY
310204699 RADIATOR ASSEMBLY
310204702 RADIATOR ASSEMBLY
310202973 EXHAUST SYSTEM
310202957 ENGINE MOUNTING ASSEMBLY
800164503 ENGINE
310203707 BELT TENSION ASSEMBLY
310202954 FUEL SYSTEM
800159454 FUEL WATER SEPARATOR ASSEMBLY
800166460 SECONDARY FUEL FILTER
FUEL TANK
310202932 FUEL TANK
ELECTRICAL CONTROL SYSTEM
310203891 ELECTRICAL CONTROL SYSTEM
310202899 BATTERY ASSEMBLY
310202893 BASE PLATE ASSEMBLY
310202882 ELECTRICAL CABINET ASSEMBLY
803608691 FUSE BOX
310203867 RIGHT ARMREST BOX ASSEMBLY
310202904 LEFT ARMREST BOX
803802281 VEHICLE ELECTRICAL CENTER
AIR CONDITIONING SYSTEM
310202905 AIR CONDITIONING SYSTEM
813501428 AIR CONDITIONER
860565679 HEATER
UNDERCARRIAGE ASSEMBLY
310203842 UNDERCARRIAGE ASSEMBLY
800367916 TENSIONER
800367912 TENSIONER
HYDRAULIC SYSTEM - UNDERCARRIAGE
310203846 HYDRAULIC SYSTEM - UNDERCARRIAGE
310203128 SWIVEL ASSEMBLY
800305417 SWIVEL
804009840 DOZER BLADE CYLINDER
804024922 TRAVEL MOTOR
BUCKET
310204202 BUCKET
310204192 BUCKET BODY
EQUIPMENT
310203434 EQUIPMENT
310203428 BOOM
310204136 ARM
LUBRICATION SYSTEM
310202917 LUBRICATION SYSTEM
SIGN
310203872 SIGN
MECHANICAL QUICK CONNECTOR
819983472 MECHANICAL QUICK CONNECTOR
