Momed80
150
35,046
XCMG Hydraulic Excavator XE2000 Parts Catalog 2021
Brand: XCMG
Model: XCMG XE2000 Hydraulic Excavator
Publication Date: 2021
Number of Pages: 1004 Pages
318306920 Hydraulic Excavator
Chassis Assembly
318306961 Chassis Assembly
318307463 Left Longitudinal Beam Assembly
318307466 Right Longitudinal Beam Assembly
Working Device
318301099 Working Device
318301100 Bucket
318301101 Bucket Body
Driver’s Cab
318306907 Driver’s Cab
318306548 Driver’s Cab
318307195 Driver's Cab Housing
318305547 Front Passenger’s Seat Assembly
318305370 Mounting Support
801975208 Seat Assembly
316101010 Left Control Lever
316101014 Right Control Lever
318305545 Foot Padi
318305638 Foot Padii
318307638 Lower Bin Assembly
318813530 Lower-Cab Left Side Door
318305509 Anti-Collision Ball
Turntable Assembly
318306967 Turntable Assembly
Channel Assembly
318306909 Channel Assembly
318307632 Antiskid Plate Assembly In The Engine Room
318307717 Engine Room Front Walkway Assembly
318304015 Superstructure Ladder Assembly
318308250 Superstructure Ladder Bracket Assembly
Slewing Movement
318305685 Slewing Movement
800555455 Slewing Bearing
Hydraulic Pilot Control System
318306921 Hydraulic Pilot Control System
318307903 Ladder Pilot Pipeline
319001886 Pipe Clamp Assembly
318304208 Pipe Clamp Assembly
318301068 Electronic Pump Assembly
318305802 Valve Assembly
318305820 Winch Mounting Assembly
318305817 Valve Assembly
318307922 Engine Compartment Pilot Pipeline
318307975 Transition Block Assembly
318307925 Steel Pipe Assembly
318307916 Pilot Filter Assembly
318307919 Steel Pipe Assembly
318307914 Quadruple Solenoid Assembly
318307917 Pump Pilot Pipeline
318307908 Centralized Lubrication Drive Pipeline
318307907 Steel Pipe Assembly
318307904 Steel Pipe Assembly
318307923 Clamp Assembly
318307942 Valve Group Pilot Pipeline
318307930 Steel Pipe Assembly
318307924 Energy Accumulator Assembly
318307932 Transition Block Assembly
318307937 Solenoid Valve Assembly
318307933 Solenoid Valve Assembly
318307934 Solenoid Valve Assembly
318307943 Welding Bracket
318307931 Pressure Reducing Valve Assembly
318305821 Connector Assembly
318307940 Steel Pipe Assembly
Handrail Assembly
318303431 Handrail Assembly
Electrical Control System
318307013 Electrical Control System
318308000 Engine Compartment Electrical System
318307010 Driver’s Cab Electrical System
318306808 Electrical Parts Attached To Driver’s Cab
318307205 Console Panel Box
318305014 Right Armrest
318305032 Left Handrail Box Assembly
318307200 Switch Mounting Assembly
318307019 Diesel Tank Electrical Assembly
318304919 Right Trunking Architecture Electric
318304910 Left Trunking Architecture Electric
318305040 Ladder Control Box Assembly
318308009 Battery Wire Assembly
318304809 Electrical Cabinet
318304714 Battery Installation
318308011 Turntable Electric
318307023 Lower Cab Electrical System
316508011 Button Switch Assembly
318304895 Electric Box Body
316508013 Emergency Stop Switch Assembly
803751307 Central Electrical Box
Hangar Assembly
318306949 Hangar Assembly
318306950 Frame Assembly
318301979 Left-Lower Sealplate
318301976 Left-Rear Sealplate
318301973 Left-Upper Sealplate
318301995 Cover Plate
318301991 Left Front Closure Plate
318307634 Door
318307694 Door
318307775 Door
318307727 Door
318307633 Door
318302177 Cover Plateⅱ
318302188 Cover Plateⅱ
318302194 Front Right Basic Coverⅱ
318302210 Cover Plateⅰ
318302221 Front Right Basic Coverⅰ
318302248 Cover Plate
318302259 Middle Cover Plate
318302278 Rear-Left Cover Plateii
318302287 Left Cover Plate Assemblyⅱ
318302297 Cover Plateⅱ
318302306 Rear-Left Cover Plate
318302315 Left Cover Plate Assemblyⅰ
318302323 Cover Plateⅰ
318302379 Upper Closure Plate Of The Auxiliary Water Tank Steel Pipe
Get-On Hydraulic System
318306944 Get-On Hydraulic System
318307968 Turntable Hydraulic Pipeline Layout
318307799 Oil Return System Pipeline
318307498 Turntable Main Oil Pipeline
318307325 Pump Oil Suction Pipeline
318307823 Drain Oil Pipeline
318307797 Main Pump System Pipe
318307969 Working Device Piping
804009182 Left Bucket Cylinder
804009180 Right Bucket Cylinder
804009181 Bucket Arm Cylinder
318300984 Pipe Clamp Assembly
318300988 Pipe Clamp Assembly
318300994 Pipe Clamp Assembly
804009179 Boom Cylinder
318301038 Pipe Clamp Assembly
318300996 Pipe Clamp Assembly
318307902 Independent Heat Dissipation And Air-Conditioning System Piping
318307900 Independent Radiator Pipe
318307854 Transfer-Box Independent Radiator Pipe
318307877 Air Conditioner System Pipeline Arrangement
Engine System
318306874 Engine System
318302434 Engine Air Intake System
318306873 Engine Installation
800366057 Transfer Gear
800157114 Engine Assembly
318300809 Quick Filling System
318300827 Fuel Filter Installation
318302447 Muffler System
318302397 Radiator System
800164400 Radiator
318302400 Steel Pipe Assembly
318302403 Pull Rod Assembly
318302448 Expansion Tank Assembly
318307472 Heater Installation
Chassis Hydraulic System
318306916 Chassis Hydraulic System
800366058 Walking Reducer
804001698 Walking Motor
318307944 Bracket
318307949 Baffle Connector Assembly
318307951 Pipe Clamp Assembly
318307964 Pipe Bracket Assembly
318307950 Bracket
318307954 Confluence Block Assembly
318306915 Rotary Joint Assembly
318300009 Right Supporting Plate Connector Assembly
318305794 Tension Valve Block Assembly
318307941 Logic Valve Assembly
318305787 Energy Accumulator Assembly
318307962 Pipe Clamp Assembly
318307961 Pipe Clamp Assembly
318300025 Left Supporting Plate Connector Assembly
Diesel Tank
318300227 Diesel Tank
Oil Tank
318301614 Oil Tank
318305687 Main Hydraulic Oil Tank Assembly
803420966 Breathing Valve
318305693 Suction Filter Assy
318303629 Centralized Oil Injector Assembly
Counterweight
318303581 Counterweight
Air Conditioning System
318307366 Air Conditioning System
318305190 Return Air Box
803595934 Air Conditioning System
802159540 Ordinary Filter Supercharger
318301303 Centralized Lubrication
318307381 Turntable Centralized Lubrication System
803409672 Filter Assembly
318306987 Working Device Centralized Lubrication System
Logo
318301721 Logo
