Hyundai
86
176,834
XCMG Crane XCA220H Parts Manual 2024
Brand: XCMG
Model: XCMG XCA220H Crane
Publication Date: 2024
Number of Pages: 950 Pages
120401157 ALL TERRAIN CRANE
TURNTABLE
120203314 TURNTABLE
120202295 BRACKET
SLEWING SYSTEM
120701299 SLEWING SYSTEM
800369722 SLEWING REDUCER
800379494 BRAKE
803280431 HYDRAULIC MOTOR
SLEWING BEARING
120400339 SLEWING BEARING
MAIN WINCH SYSTEM
120400246 MAIN WINCH SYSTEM
800367001 WINCH REDUCER
860576190 WINCH REDUCER BRAKE
803281371 HYDRAULIC MOTOR
AUXILIARY WINCH SYSTEM (HYDRAULIC PARTS & ELECTRICAL PARTS INCLUDED)
120400282 AUXILIARY WINCH SYSTEM (HYDRAULIC PARTS & ELECTRICAL PARTS INCLUDED)
120202274 AUXILIARY WINCH PIPELINE
122000671 BRAKE CONTROL VALVE ASSEMBLY
120202775 COUNTERBALANCE VALVE MOUNTING ASSEMBLY
116101723 BRAKE CONTROL VALVE ASSEMBLY
120400281 AUXILIARY WINCH SYSTEM
120201346 ROLLER
BOOM
120400208 BOOM
120400190 BASE BOOM ASSEMBLY
120201501 SLIDER
120201398 ROLLER
120300269 ROPE GUARD ROLLER ASSEMBLY
120400185 2ND BOOM SECTION ASSEMBLY
120201501 SLIDER
120202414 ROLLER
120200289 DETECTOR SEAT
120400167 3RD BOOM SECTION ASSEMBLY
120201501 SLIDER
120200286 ROLLER
120400169 4TH BOOM SECTION ASSEMBLY
120200383 ROLLER
120200376 DETECTOR SEAT
120201501 SLIDER
120400186 5TH BOOM SECTION ASSEMBLY
120200383 ROLLER
120201501 SLIDER
120400210 6TH BOOM SECTION ASSEMBLY
120200467 ROLLER
120201501 SLIDER
120400189 7TH BOOM SECTION ASSEMBLY
120200568 DETECTOR SEAT
119500087 SHEAVE ASSEMBLY
120400215 ELECTRIC AND HYDRAULIC ACCESSORIES
COVERING
120202389 COVERING
119201298 FOLDING LADDER
120202390 LEFT COVERING
119201281 REARVIEW MIRROR ASSEMBLY
120202384 COVERING
COUNTERWEIGHT
120402627 COUNTERWEIGHT
COUNTERWEIGHT FIXTURE DEVICE
120200648 COUNTERWEIGHT FIXTURE DEVICE
120202887 COUNTERWEIGHT CYLINDERI
120202886 COUNTERWEIGHT CYLINDERII
LUFFING CYLINDER
120400219 LUFFING CYLINDER
AIR CONDITIONING SYSTEM
120202189 AIR CONDITIONING SYSTEM
819963680 AIR CONDITIONING DEVICE
FIXED JIB ASSEMBLY
120400252 FIXED JIB ASSEMBLY
120400222 JIB ELECTRICAL SYSTEM
120200620 JIB SUBSYSTEM
120201977 CONNECTING BRACKET ASSEMBLY
115600062 PULLEY BRACKET ASSEMBLY
120201894 OFFSETTING BRACKET ASSEMBLY
120201970 PULL PLATE
120201038 EXTENSION I
120700475 ROLLER ASSEMBLY
120201068 EXTENSION II
120202988 1ST JIB SECTION ASSEMBLY
120200986 SHEAVE
122103825 PULLING-SHAFT DEVICE
120200989 2ND JIB SECTION ASSEMBLY
120202989 ROLLER ASSEMBLY
120201033 SHEAVE ASSEMBLY
INSTALLATION ASSEMBLY OF HYDRAULIC PIPES FOR SUPERSTRUCTURE
120400283 INSTALLATION ASSEMBLY OF HYDRAULIC PIPES FOR SUPERSTRUCTURE
120202266 PIPING OF MAIN WINCH AND SLEWING
120202267 SLEWING PIPING
120202268 MAIN WINCH PIPING
120400229 TELESCOPING AND LUFFING PIPING
803000776 BACK PRESSURE VALVE
120400338 ASSEMBLY OF LARGER CHAMBER RELIEF VALVE
120400230 TELESCOPING CYLINDER PIPING
120202230 AUXILIARY PIPING
120202202 ASSEMBLY OF COUNTERBALANCE VALVE OF OPERATOR’S CAB
120202229 INSTALLATION ASSEMBLY OF AUXILIARY VALVE
120202204 COUNTERWEIGHT PIPELINE ASSEMBLY
120202237 SUPERSTRUCTURE CENTER ROTARY JOINT HYDRAULIC PIPE
120702764 BRACKET
803163321 FILTER
120202203 PILOT VAVLE INSTALLATION ASSEMBLY
803009962 RADIATOR
120202772 MAIN VALVE INSTALLATION ASSEMBLY
OPERATOR'S CAB
119501857 OPERATOR'S CAB
802152573 OPERATOR'S CAB ASSEMBLY
802149411 SLIDING DOOR ASSEMBLY
860503279 OUTER DECORATION AND ACCESSORY SYSTEM (TILTED)
802149408 AIR CONDITIONING ACCESSORY SYSTEM (DENTED)
802149342 INTERIOR DECORATION AND ACCESSORY SYSTEM (DENTED)
802149252 WIPER ASSEMBLY
TELESCOPING CYLINDER ASSEMBLY
120400217 TELESCOPING CYLINDER ASSEMBLY
120400218 TELESCOPIC CYLINDER
TURNTABLE LOCKING DEVICE
115601478 TURNTABLE LOCKING DEVICE
115601479 LOCKING CYLINDER
OPERATOR'S CAB TILTING CYLINDER
121202893 OPERATOR'S CAB TILTING CYLINDER
SUPERSTRUCTURE ELECTRICAL SYSTEM
120400248 SUPERSTRUCTURE ELECTRICAL SYSTEM
120400247 ELECTRICAL SYSTEM IN THE OPERATOR’S CAB
120202722 INSTRUMENT PANEL ASSEMBLY
121105443 JOYSTICK ASSEMBLY
120400153 TURNTABLE ELECTRIC SYSTEM
120400233 CONTROL BOX ASSEMBLY
120400154 BOOM ELECTRICAL SYSTEM
120200619 BASIC CONTROL SYSTEM
120202503 SUB-SYSTEM
120202504 CONTROLLER ASSEMBLY
CENTRALIZED LUBRICATION SYSTEM
120200058 CENTRALIZED LUBRICATION SYSTEM
120200060 CENTRAL LUBRICATE SYSTEM PIPING
803393160 CENTRALIZED LUBRICATION ASSEMBLY
ALL TERRAIN CRANE CHASSIS
142502491 ALL TERRAIN CRANE CHASSIS
143102700 DRIVER'S CAB
802158980 DRIVER'S CAB ASSEMBLY
142608589 AIR CONDITIONING DEVICE
143102707 STEERING HYDRAULIC SYSTEM PIPELINE
142501897 ELECTRO-HYDRAULIC STEERING SYSTEM PIPELINE
143102741 OIL SUCTION PIPELINE
143102109 MECHANICAL STEERING HYDRAULIC SYSTEM PIPELINE
143102110 STEERING SYSTEM
142007218 FIRST PULL ROD ASSEMBLY
142007220 PULL ROD ASSEMBLY
142007219 THIRD PULL ROD ASSEMBLY
142007221 PULL ROD ASSEMBLY
142000715 TIRE
142501861 AXLE 1 ASSEMBLY
142602613 SUSPENSION CYLINDER
800370735 AXLE 1
142501341 UPPER PUSH ROD
142200741 CONNECTING ROD MECHANISM
803282573 STEERING CYLINDER ASSEMBLY
800374977 THRUST ROD
142605269 ENGINE INSTALLATION
800175325 ENGINE
142605476 TRANSMISSION ASSEMBLY
800374078 TRANSMISSION
142603775 EXTENSION CYLINDER
142501822 OUTRIGGER BEAM ASSEMBLY
142501838 FRONT OUTRIGGER BEAM ASSEMBLY
142501850 REAR OUTRIGGER BEAM ASSEMBLY
142501859 JACK CYLINDER
142603939 FRONT JACK CYLINDER
142600287 REAR JACK CYLINDER
142501860 AXLE 2 ASSEMBLY
142602614 SUSPENSION CYLINDER
800370734 AXLE 2
142603794 SUSPENSION HYDRAULIC PIPING
141903225 SUSPENSION VALVE BLOCK
142501862 AXLE 3 ASSEMBLY
142600112 STEERING CYLINDER ASSEMBLY
143601049 STEERING MIDDLE-POSITION LOCKING CYLINDER
800370733 AXLE 3
143102740 ADBLUE/DEF SOLUTION SUPPLY SYSTEM
800163468 UREA TANK ASSEMBLY
143102215 FUEL TANK INSTALLATION
819975968 FUEL TANK
819975967 FUEL TANK
800181963 FUEL FILTER
142602498 CONNECTOR OF CENTRAL ROTARY JOINT
142501864 AXLE 4 ASSEMBLY
144901666 STEERING CYLINDER ASSEMBLY
143601050 STEERING MIDDLE-POSITION LOCKING CYLINDER
800370732 AXLE 4
142501863 AXLE 5 ASSEMBLY
142600116 STEERING CYLINDER ASSEMBLY
142600117 STEERING CYLINDER ASSEMBLY
800370731 AXLE 5
142603639 AIR RESERVOIR INSTALLATION
141902621 AIR RESERVOIR 10L
144803418 NG12 NUT SEAT
142601182 ALUMINUM ALLOY AIR RESERVOIR COMPONENTS 40L
143102704 PNEUMATIC VALVE INSTALLATION ASSEMBLY
144803417 FOOT RELAY VALVE INSTALLATION ASSEMBLY
144803419 HAND RELAY VALVE INSTALLATION ASSEMBLY
142601189 INSTALLATION OF FOUR CIRCUIT VALVE
145100355 TRIPLE VALVE BLOCK
142601187 OIL-WATER SEPARATOR INSTALLATION
143700159 DRYER INSTALLATION
142601843 TWO-POSITION FIVE-WAY SOLENOID VALVE ASSEMBLY
144803420 FOOT RELAY VALVE INSTALLATION ASSEMBLY
143700020 ABS SOLENOID VALVE ASSEMBLY Ⅰ
142005656 SOLENOID VALVE GROUP
142603763 PNEUMATIC CIRCUIT DETECTION MODULE
143102703 PIPING FOR PNEUMATIC SYSTEM
803790407 CM-6S/6M ABS ASSEMBLY
140702030 NG6 NUT SEAT
143102702 PNEUMATIC PIPE ASSEMBLY
142605821 FRAME WIRING HARNESS ASSEMBLY
142605820 DRIVER'S CAB ELECTRICAL SYSTEM INSTALLATION
142603651 ELECTRICAL SYSTEM INSTALLATION ASSEMBLY
142603899 CHASSIS LIGHTING SYSTEM
144501458 SPARE TIRE MOUNT
142502494 DECK ASSEMBLY
143601748 FRONT TRACTION DEVICE
142602439 LEFT REAR OUTRIGGER SHIELD PLATE
142602448 LEFT REAR UPPER COVER PLATE
142602438 RIGHT REAR OUTRIGGER SHIELD PLATE
142602446 RIGHT REAR UPPER COVER PLATE
142502503 WEICHAI DIESEL CHINA V ENGINE AND ZF TRANSMISSION
142604440 LEFT FRONT OUTRIGGER SHIELD PLATE
142604397 RIGHT FRONT OUTRIGGER SHIELD PLATE
142604426 TOOLBOX
142504560 OUTRIGGER REMOVAL ASSEMBLY
142603652 BATTERY INSTALLATION
142602598 BATTERY ASSEMBLY
142301483 COMPONENT BOX ASSEMBLY
143102706 OIL PUMP
143102346 FRONT OIL PUMP
142603676 REAR OIL PUMP
143504506 AIR FILTER INSTALLATION
800176042 AIR FILTER
142003022 HYDRAULIC SYSTEM PIPING FOR HEAT DISSIPATION
142605268 RADIATOR
142608578 BYPASS PIPELINE
142605287 INTERCOOLER OUTLET PIPE
143102335 RADIATOR ASSEMBLY
143102268 WATER OUTLET PIPE
143102275 INTERCOOLER INLET PIPE
143102332 RADIATOR OUTLET PIPE
142604806 BOOM BRACKET
143102370 ENGINE HOOD
142606023 ENGINE HOOD
142301952 LEFT ENCLOSURE
142301953 RIGHT ENCLOSURE
143102785 BRACKET ASSEMBLY
143102371 BRACKET ASSEMBLY
142501885 HYDRAULIC SYSTEM PIPING FOR CHASSIS
142504554 REAR OUTRIGGER INNER PIPING
142609196 FRONT OUTRIGGER INNER PIPING
142603845 HYDRAULIC SYSTEM PIPING FOR OUTRIGGERS
142003020 HYDRAULIC OIL TANK
803100064 AIR FILTER
803100118 RETURN FILTER
142605261 MUFFLER ASSEMBLY
800175321 AFTER TREATMENT SYSTEM HOUSING
142501787 TRANSFER BOX AND SUSPENSION
142501786 PREASSEMBLY OF TRANSFER BOX
142003074 PREASSEMBLY OF OIL COOLER
142501874 DRIVE SHAFT
HOOK BLOCKS
120400280 HOOK BLOCKS
120400308 11TON HOOK
119810683 LATCH ASSEMBLY
120400274 75 TON HOOK BLOCK
120400330 NO.25 STANDARD HOOK BLOCK I
WIRE ROPE OF MAIN WINCH AND SLINGS
120400241 WIRE ROPE OF MAIN WINCH AND SLINGS
120400237 POUCH CONNECTOR
150TON HOOK
120400273 150TON HOOK
130003220 NO.50 HOOK ASSEMBLY
130002949 LATCH ASSEMBLY
120400262 SHEAVE ASSEMBLY
