XCMG Backhoe Loader XC8-C2570 Operators Manual
Brand: XCMG
Model: XCMG XC8-C2570 Backhoe Loader
Number of Pages: 154 Pages
1. Brief Introduction
1.1About This Manual
1.2Direction
1.3Acquaint Yourself With the Machine
1.3.1 Composition of The Machine
1.3.2 Label plate
2 Safety
2.1Safety Warning Signs
2.2Safety marks
2.3Safety Precautions
2.3.1 General Safety Precautions
2.3.2 Operation Manual
2.3.3Rules and Regulations
2.3.4Machine Modification
2.3.5 Limit of The Machine
2.3.6 Clothing
2.3.7 Alcohol and Medicine
2.3.8 Maintenance
2.3.9 Communication
2.3.10 Compressed Air
2.3.11 High Pressure Solution
2.3.12 Disposal of Waste Fluids
2.3.13 Guard against Squeezing and Cutoff
2.3.14 Guard against Scalding
2.3.15 Battery
2.3.16 Guard against Fire and Explosion
2.3.17 Diethyl Ether
2.3.18 Pipelines, Pipes, and Hoses
2.3.19 Fire Extinguisher and First-Aid kit
2.3.20 Guard against Thunder and Lightning
2.3.21 Tires
2.3.22 Cab Protection
2.3.23 Precautions for Accessories
2.3.24 Understanding Your Machine
2.3.25 Understanding Your Working Area
2.3.26 Getting on/off the machine
2.3.27 Before Start of Engine
2.3.28 Engine Start
2.3.29 Operation of Machine
2.3.30 Parking of Machine
2.3.31 Supporting mechanism
2.3.32 Disassembly of machine
2.3.33 Welding Operations
2.3.34 Periodic Cleaning of Machine
3 Technical Parameters
3.1 Diagram of Overall Dimensions
3.2 Operation Specification Diagram
4 Operations
4.1 Introduction
4.2 Before Entering the Cab
4.2.1Cleaning and Inspection
4.2.2Inspection of Parts and Components
4.2.3 Tyre inspection
4.3 Entering/leaving the Cab
4.4 Cab Doors and Windows
4.4.1 Switches of Cab Doors
4.4.2 Switches of Side Windows
4.4.3 Switches of Rear Window
4.5 Seat
4.5.1 Seat Safety Belt
4.6 Layout of the Cab
4.6.1 Steering Gear Column
4.6.2 Front Instrument Panel
4.6.3 Front Control Switch
4.6.4 Right Instrument Panel
4.6.5Radio:
4.6.6 Gear Selector
4.6.7 Electric Combination Switch
4.6.8 Accelerator Pedal
4.6.9 Driving Brake Pedal
4.6.10 Parking Brake Control Lever
4.6.11 Hand Throttle Lever
4.6.12 Loading Control
4.6.13 Outrigger Operation
4.6.14 Excavation Control
4.6.15 Boom and Slewing Locking
4.6.16 Inside Ceiling Lamp in the Cab
4.6.17 Digging Multifunctional Pedal (Optional)
4.7 Start the Engine
4.7.1 Bbefore Starting Engine
4.7.2 Start the Engine
4.7.3 After Starting Engine
4.8 Operation Technology
4.8.2 Machine Driving Operation
4.8.3 Park the Vehicle
4.8.4 Shoveling and Loading Operation
4.8.5 Digging Operation
4.9Machine Transportation
4.9.1 Machine Loading and Transporting
4.9.2 Machine Hoisting
4.9.3 Haul the machine
4.10 Storage of the Machine
5. Maintenance and Servicing
5.1Health and Safety
5.1.1 Lubricating Fluid
5.1.2 Battery
5.1.3 First Aid - electrolyte
5.1.4 Warning Symbols
5.2Maintenance Guide
5.2.1 Correct maintenance and Servicing Method
5.2.2 Inspection Before Daily Starting
5.2.3 Inspect Operation Timetable
5.2.4 Service Machine in Required Period
5.2.5 Maintenance Tips
5.2.6 Windshield Cleaning Fluid
5.2.7 Clean Engine Oil and Lubricating Oil
5.2.8 Inspect Discharged Oil or Used Filer Element
5.2.9 Welding Instruction
5.2.10 Prevent Stuffs From Falling Into the Machine
5.2.11 Dusty Environment
5.2.12 Refrain From using Oil Mixture
5.2.13 Hydraulic system-exhaust
5.2.14 Mount Hydraulic Hose
5.2.15 Select the Fuel and Lubricating Oil That Adapts to the Environment
5.2.16 Inspect The Electric Circuit
5.2.17 Inspect A/C
5.2.18 Inspect the Meters
5.2.19 Preparatory Work Before the Maintenance
5.3New Vehicle Running-in
5.3.1 Requirements About New Vehicle Running-in
5.3.2 Perform Operations Below After 8 Hours of New Vehicle Running-in
5.3.3 Work afTer the Running-in Period Ends
5.4Regular Maintenance
5.4.1 Maintenance Schedule
5.4.2 Names Equivalent to Working Hours
5.4.3 Prestart inspection, Maintenance points and Liquid Levels
5.4.4 Function test and Final Inspection
5.4.5 Mixing of Coolant
5.4.6 Liquid materials and Liquid Meters
5.4.7 Applicable Air Temperatures of Fuel/Oils/Fluids of Different Trademarks
5.5Cleaning the Machine
5.6Damage Inspection
5.7Seat Belt
5.8Safety Prop of Loading Arm
5.9Lubrication
5.9.1 Loader Working Device
5.9.2 Excavator Working Device
5.9.3 Front Axle Pin
5.9.4 Front Axle
5.9.5 Drive Shaft
5.9.6 Four-in-one Shovel Bucket (optional )
5.9.7 Legs
5.10 Engine Hood
5.10.1 Open and Close
5.11 Electrical System
5.11.1 Battery
5.11.2 Jump-start the Engine
5.11.3 Junction Box Fuses
5.12 Engine
5.12.1 Check the Oil Level
5.12.2 Change the Machine Oil and Filter
5.12.3 Replace the Filter Element of the Air Filter
5.12.4 Check the Coolant
5.12.5 Replace the Coolant
5.12.6 Front end Accessory Drive Belt
5.13 Fuel System
5.13.1 Fuel Type
5.13.2 Low Temperature Fuel
5.13.3 Add Fuel to the Fuel Tank
5.13.4 Drain the Oil-water Separator and the Engine
5.13.5 Replace the Oil-water Separator Filter
5.13.6 Replace the Engine Fuel Filter Element
5.13.7 Air Bleeding of System
5.13.8 Cleaning of Radiator
5.14Hydraulic System
5.14.1 Check the Liquid Level
5.14.2 Hydraulic Tank Cap
5.14.3 Replace the Return Oil Filter Element
5.14.4 Replace the Suction Filter Element
5.15 Transmission Case
5.15.1 Check the Oil Level in the Transmission Case
5.15.2 Change the Transmission Oil and Oil Filter
5.16 Tyres and Wheels
5.16.1 Inflate the Tyre
5.16.2 Check the Torque of the Wheel Nuts
5.17 Axle
5.17.1 Checking of Oil Level for Differentials of Front and Rear Axles
5.17.2 Change the Differential Oil
5.17.3 Check the Hub Oil Level
5.17.4 Change the Hub Oil
5.18 Windshield Washer
5.18.1 Check the Liquid Level
Brand: XCMG
1.2Direction
1.3.2 Label plate
2 Safety
2.2Safety marks
2.3.6 Clothing
2.3.8 Maintenance
2.3.9 Communication
2.3.15 Battery
2.3.21 Tires
2.3.28 Engine Start
4 Operations
4.1 Introduction
4.5 Seat
4.6.5Radio:
4.6.6 Gear Selector
5.1.2 Battery
5.2.17 Inspect A/C
5.7Seat Belt
5.9Lubrication
5.9.4 Front Axle
5.9.5 Drive Shaft
5.9.7 Legs
5.10 Engine Hood
5.11.1 Battery
5.12 Engine
5.13 Fuel System
5.13.1 Fuel Type
5.17 Axle
- XCMG Wheel loader ZL50G service manual
- XCMG Road Grader Parts Handbook GR215A
- XCMG ZL50G Wheel Loader Parts Manual
- XCMG ZL30G Wheel Loader Parts List
- XCMG LW420F Wheel Loader Instruction Manual
- XCMG Excavator Loader WZ30-25 Parts Catalog EN ZH
- XCMG LW500F Wheel Loader Parts Manual part 1
- XCMG GR215 Parts Manual
- XCMG YL16 YL 20 Types Pneumatic Tyre Roller Parts List
- XCMG YZ 16 JC YZ 18JC Vibratory Roller Operation and Maintenace Manual
- XCMG ZL50A.2 Spare Parts
- XCMG LW500F Wheel Loader Parts Manual part 2
- XCMG XS 160 XS 190 Parts List of Vibratory Roller
- XCMG LW330F Wheel Loader Parts Manual
- XCMG PAT DS 380 Parts Manual
