118
6,911
XCMG Articulated Dump Truck XDA45U Parts Catalogue EN
Brand: XCMG
Type of Machine: Articulated Dump Truck
Type of Manual: Parts Catalogue
Model: XCMG XDA45U Articulated Dump Truck
PIN: XUG00455EMWB00028
Number of Pages: 578 Pages
332107575 Articulated Dumping Truck
Power System
332107580 Power System
800164461 Engine Assembly
800173319 Crankcase, Cover And Gaskets Set
800173326 Flywheel Case Assembly
800173315 Oil Pan And Oil Level Indicator
800172942 Cylinder Head, Air Door, Gasket Set
800172934 Cylinder Head Cover
800173313 Crankshaft And Flywheel Assembling Group
800173334 Link Rod And Piston Assembly
800173327 Camshaft And Timing Components
800172932 High Pressure Pump Component
800173333 Fuel Hose
800173320 Fuel Filter Component
800173328 Turbocharger Bearing Component
800173325 Air Compressor
800172940 Air Compressor Accessory
800172939 Air Intake Manifold Element
800173330 Exhaust Manifold Components
800172941 Waste Gas Recirculation Component
800172935 Diesel Metering Device
800172933 Engine Electrical Device
800173316 Starter Motor Component
800173321 Generator
800173331 Accessories Of Starter & Ac Alternator
800173329 Oil Pump Assembly
800173314 Oil Filter And Cooler Assembly
800173324 Oil Pipeline
800173332 Water Pump Component
800173322 Fan Assembly
800173323 Engine Brackets And Accessories
800173318 Power Take-Off Components
800173317 A/C Compressor Components
800172937 Waste Gas After-Treatment Component
332107409 Intake And Exhaust Assembly
332107400 U-Shaped Hoop
332107433 Grip Ring
332107438 Exhaust Gas Pipe Component
332107232 Fuel Tank Assembly
332102241 Quick Filling Components
332107461 Radiator
332107453 Guard Shell
332107459 Cooling Assembly
332107472 Engine Cooling System
332107517 Engine Water Inlet Pipe Components
332107477 Engine Water Outlet Pipe Component
332107368 Transmission Box Cooling System
332107329 Fan Assembly
332107391 Engine Support System
332107240 Oil Circuit Assembly
332107300 Aftertreatment System
332107275 Muffler Hood
332107279 Differential Pressure Sensor Component
332107320 Adblue Tank Component
332107523 Cargo Compartment Heater Assembly
332107531 Cargo Compartment Heater Transition Component
332107565 After-Treatment Base
332107251 Cold Start System
332105992 Electrical System
332105993 Driver’s Cab Electrical Layout
332105994 Electric Cabinet Assembly
332109218 Led Front Combined Lamp Component
332105990 Power Cord
332109233 Auxiliary Starting Socket Component
332109231 Starting Power Switch Component
332109076 Turbine Timer (Optional)
332108513 Steering Angle Displacement Assembly
332105999 Proximity Sensor Assembly
332105997 Cargo Compartment Angle Displacement Assembly
332107064 Hydraulic System
332107039 Hydraulic Oil Tank Assembly
803389052 Filter
332107125 Oil Pipe Support
332106986 Front Vehicle Working Hydraulic System
332107006 Main Valve Control Pipeline
332107178 Steering Control Pipeline
332106989 Cooling Control Pipeline
332106911 Hydraulic Oil Supply Pipeline
332106881 Rear Vehicle Hydraulic System
332107116 Brake Control Pipeline
332107149 Lift Cylinder Pipeline Component
332107141 Brake Cooling Pipeline
332106892 Axle Brake System
332107041 Front Vehicle Brake System
332107137 Brake Cooling System
332107019 Front Axle Brake System
332106860 Brake Oil Supply System
332107047 Retarder Cooling Control System
332106963 Brake Control System
332107164 Pneumatic System
332107175 Pneumatic Front Vehicle Component
332107062 Right Box Pneumatic Component
332107161 Parking Brake Components
Logo
332107579 Logo
332106041 Cab
332106037 Driver’s Cab
332106010 Electrical Component Fixing Bracket
802155645 Wiper Water Can Assembly
332109285 Pressure Charging System (Optional)
802154505 Driver’s Seat
332106055 Driver's Cab Lifting System
Safety Protection
332106517 Safety Protection
332109603 Rearview Mirror Component
332109639 Left Rear-View Mirror Assembly
Frame Assembly
332106428 Frame Assembly
332106337 Articulation Assembly
Cargo Compartment
332105926 Cargo Compartment
332105980 Rear Fender
332105971 Left Mudguard Cover
332105902 Front Heightened Guardrail
332105915 Right Mudguard Cover
Suspension System
332105874 Suspension System
332105840 Rear Suspension System
332101387 Rear Tie Rod Assembly
332101388 Mid-Position Rear Tie Rod Assembly
332105880 Front Suspension System
332105884 Suspension Cylinder Component
332105852 Front Tie Rod Component
Coverings Assembly
332106673 Coverings Assembly
332106576 Right Box
332106533 Hydraulic Pipe Bracket
332106564 Left Platform Assembly
332106555 Air Conditioner Pipe Guard Plate
332106642 Rear Windproof Assembly
332106536 Right-Side Edge Component
332106635 Right Platform Assembly
332106827 Air Intake Grille
332107802 Anti-Slip Sticker Assembly
332106736 Front Left Guard Plate
332106770 Mounting Plate
332106606 Front Right Guard Plate
332106712 Lifting Mechanism Assembly
332106632 Bottom Guard Plate
332106794 Left-Side Edge Component
332106637 Hydraulic Pump Transmission Shaft Guard Plate
332106652 Inner Supporting Frame
332106767 Engine Hood Assembly
332106834 Right Hinge
332106753 Left Hinge
Automatic Central Lubrication System (Optional)
332109194 Automatic Central Lubrication System (Optional)
332109512 Lubrication Pump Protective Components
Drive System
332105827 Drive System
800367472 Front Axle
800372073 Planetary Gear
800372076 Hub Assembly
800372077 Differential And Gear Ass'y
800372072 Braking
332105797 Tire And Rim Assembly
332105826 Transmission Box Mounting Assembly
800367009 Transmission 4800ors
332105810 Intermediate Support And Brake Assembly
800361009 Parking Brake
332105779 Protection Cover
800367473 Middle Axle
800372075 Hub Assembly
800372074 Differential And Gear Ass'y
800372072 Braking
800367471 Rear Axle
800372079 Hub Assembly
800372078 Differential And Gear Ass'y
800372072 Braking
332105802 Breather Assembly
332105796 Transfer Box Mounting Assembly
800366995 Transfer Box Assembly
Air Conditioner System Assembly
332105983 Air Conditioner System Assembly
803596753 Air Conditioning System
803598582 Air-Conditioning Unit
Temporary Materials
332107577 Temporary Materials
332109694 Centralized Filling And Sampling System
332109702 Adaptor Assy Offilling And Sampling System
332109698 Ball Valve Assembly
