Wirtgen Vogele Extending Screed AB 590 AB 600 11.AB 2009719 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Extending Screed
Type of Document: Parts Manual
Model: Vogele AB 590, AB 600
Date: 2013
Number of Pages: 226 Pages
Operating Instructions Warning
Tamper Shield Basic Screed
Tamper Shield Extension
Tamper Shield 0.225m
Tamper Shield 0.75m
Tamper Shield
Tamper Basic Screed
Tamper Extension, Left Side
Tamper Extension, Right Side
Tamper 0,225m
Tamper 0,75m, Left Side
Tamper 0,75m, Right Side
Frame Basic Screed
Frame Extending Unit,Left
Frame Extending Unit, Right
Fixed Extension 0.225m, Left
Fixed Extension 0.225m, Right
Fixed Extension 0.75m, Left
Fixed Extension 0.75m, Right
Frame Vb 1,25m, Left Side
Frame Vb 1,25m, Right Side
Vibrators Basic Screed
Vibrators Extension, Left
Vibrators Extension, Right
Vibrators 0,75m, Left Side
Vibrators 0,75m, Right Side
Vibrators 1,25m
Pressure Bar 1 Basic Screed
Pressure Bar 1 Extension,Left
Pressure Bar 1 Extension,Right
Pressure Bar 1, 0.225m, Left
Pressure Bar 1, 0.225m, Right
Pressure Bar 1 0,75m, Left
Pressure Bar 1 0,75m, Right
Pressure Bar 1, Left Side
Pressure Bar 1, Right Side
Pressure Bar 2, Basic Screed,
Pressure Bar 2, Extension, Left
Pressure Bar 2, 0.225m, Left
Pressure Bar 2, 0.225m, Right
Pressure Bar2, Vb 0,75m Left
Pressure Bar 2, Ext 0,75m, Rig
Pressure Bar 2, Ext 1.25m, Left
Pressure Bar 2, Ext 1.25m, Right
Suspension, Left Side, Tp
Suspension, Right Side, Tp
Suspension, Left Side, Tv
Suspension, Right Side, Tv
Sliding Restraint System
Deflector, Left Side, Tv
Deflector, Right Side, Tv
Deflector, Left Side, Tp
Deflector, Right Side, Tp
Deflector 0,75m Tv
Deflector 0,75m Tp
Deflector 1,25m Tv
Deflector 1,25m Tp
Bracing 2 X Ext 0. 75m, Left
Bracing 2 X Ext 0. 75m, Right
Bracing
Vertical Adjustment, Left Side
Vertical Adjustment,Right Side
Drive Height Adjustment
Crown Adjustment
Crown Adjustment Hydraulic
Panel, Left Side
Panel, Right Side
Cover Tp
Cover Tv
Cover 0,225m
Cover 0,75m, Left Side
Cover 0,75m, Right Side
Cover 1,25m, Left Side
Cover 1,25m, Right Side
Insulation Sound Heat
Footboard
Footboard 0,75m
Footboard 1,25m
Footstep, Tv
Footstep, Tp
End Plate, Left Side
End Plate, Right Side
Extension End Plate,Left Side
Extension End Plate,Right Side
Spindle
End Plate
Cut-Off Shoe
Bevel Iron 3-6cm, 45°
Bevel Iron 6-12cm, 45°
Bevel Iron 12-18cm, 45°
Bevel Iron 3-6cm, 60°
Bevel Iron 6-12cm, 60°
Bevel Iron 12-18cm, 60°
Bevel Iron Tv
Bevel Iron Tp
Distributor Block
Control Block
Hydraulic Drive Tamper
Hydraulic Drive Vibrators
Hydraulic Ram 1, Right Side, T
Hydraulic Ram 2, Left Side, Tv
Hydraulic Ram 2, Left Side, Tp
Height Adjustment Hydraulic
Leakage Oil Tamper Tv
Leakage Oil Tamper Tp
Leakage Oil Vibrators
Return Pipe Tv
Return Pipe Tp
Hydraulic Drive Pressure Bar
Hydraulics Pressure Bar 1
Pressure Bar 1
Pressure Bar1, Vb 1,25m
Hydraulics Pressure Bar 2
Pressure Bar 2, Ext 0.75m
Pressure Bar2, Vb 1,25m
Speed Tamper
Speed Vibrators
Fixed Extension Adjustment
Crown Adjustment
Display Pave Data
Voltage Supply
24 V (Option)
Distributor Screed Heating
Screed Plate Temperature
Fixed Cabling (Screed)
Heating 0.225m
Heating 0.75m
Heating Screed Plate Tv
Heating Screed Plate Ab590 Tp
Heating Screed Plate 0,225m
Heating Screed Plate 0,75m Tv
Heating Screed Plate 0,75m Tp
Heating Fixed Extension 1.25m
Extra Screed Heating
Heating Bevel Iron
Heating Rod, Bevel Iron
