Wirtgen Vogele Extending Screed AB 500-2 TP 15.AB 2041806 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Extending Screed
Type of Document: Parts Manual
Model: Vogele AB 500-2 TP
Date: 2013
Number of Pages: 246 Pages
Signs And Warnings
Signs And Warnings USA
Tamper Shield Basic Screed
Tamper Shield Extending Unit
Tamper Basic Screed
Tamper Extending Unit, Left
Tamper Extending Unit, Right
Pressure Bar1, Basic Screed,Lh
Pressure Bar1, Basic Screed,Rh
Pressure Bar1, Extending Unit
Pressure Bar2, Basic Screed,Lh
Pressure Bar2, Basic Screed,Rh
Pressure Bar2, Extending Unit
Suspension, Left Side, Tp
Suspension, Right Side, Tp
Deflector, Left Side
Deflector, Right Side
Height Adjustment, Left Side
Height Adjustment, Right Side
Drive Height Adjustment
Height Adjustment Hydraulic
Voltage Supply
Crown Adjustment, Mechanical
Hydraulic Crown Adjustment
Voltage Supply
Cover Panel
Cover
Cover Sprayjet
Footboard
Footstep
End Plate, Left Side
Support, Left Side
Support, Left Side Hyd.
End Plate, Right Side
Support, Right Side
Support, Right Side Hyd.
End Plate, Electrics
End Plate, Hyd.
Basic Screed, Hyd.
Extension End Plate, Left Side
End Plate, Left
Extension End Plate,Right Side
End Plate, Right
Spindle
End Plate
End Plate, Hyd. Vb0,75m
End Plate, Hyd. Vb1,25m
Cut-Off Shoe
Bevel Iron Tp
Display Pave Data (Tamper)
Display Pave Data (Temp.1)
Display Pave Data (Temp.2)
Distributor Block
Speed Control
Control Block
Hydraulic Drive Tamper
Hydraulic Ram 1, Right Side, T
Hydraulic Ram 2, Left Side, Tp
Leakage Oil Tamper Tp
Return Pipe Tp
Hydraulic Drive Pressure Bar
Pressure Bar 1 Basic Screed
Hydraulics Pressure Bar 1
Pressure Bar 2, Basic Screed
Hydraulics Pressure Bar 2
Power Supply, 24 V
Voltage Supply
Fixed Cabling (Screed)
Voltage Supply 400v
Distributor Screed Heating
Heating Rod, Standard Tp1
Heating Rod, Standard Tp2
Monitoring Heating Rod, Tp1
Monitoring Heating Rod, Tp2
Heating Bevel Iron
Greasing Basic Screed, Left
Greasing Basic Screed, Right
Greasing Extending Unit,Left
Greasing Extending Unit,Right
Tamper Shield, Left Side
Tamper Shield, Right Side
Tamper Shield Compl.
Tamper, Left Side
Tamper, Right Side
Frame, Left Side
Frame, Right Side
Pressure Bar1, Vb 0,25m Left
Pressure Bar1, Vb 0,25m Right
Pressure Bar 1 0, 75m, Left
Pressure Bar 1 0, 75m, Right
Pressure Bar 1 Vb0,75m, Left
Pressure Bar 1 Vb0,75m, Right
Pressure Bar1, Vb 1,25m Left
Pressure Bar1, Vb 1,25m Right
Pressure Bar 1 Vb1,25m
Pressure Bar2, Vb 0,25m Left
Pressure Bar2, Vb 0,25m Right
Pressure Bar2, Vb 0,75m Left
Pressure Bar 2, Ext 0,75m, Rig
Pressure Bar 2, Left Side
Pressure Bar 2, Right Side
Pressure Bar2, Vb 1,25m Left
Pressure Bar2, Vb 1,25m Right
Pressure Bar 2 Vb1,25m
Deflector
Deflector Tp
Bracing 1x, Left Side
Bracing 1x, Right Side
Bracing 2x, Left Side
Bracing 2x, Right Side
Bracing, Left Side
Bracing, Right Side
Cover, Left Side
Cover, Right Side
Footboard
Voltage Supply
Greasing Tamper
Greasing Tp
Vss Basic Screed Tp1
Vss Basic Screed Tp2
Vss Bolt-On Extension 0,25mtp1
Vss Bolt-On Extension 0,25mtp2
Vss Bolt-On Extension 0,75mtp1
Vss Bolt-On Extension 0,75mtp2
Vss Bolt-On Extension 1,25mtp1
Vss Bolt-On Extension 1,25mtp2
