Wirtgen Vogele Crawler Asphalt Paver SUPER 3000-2 08.74 2099775 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Crawler Asphalt Paver
Type of Document: Parts Manual
Model: Vogele SUPER 3000-2
Date: 2013
Number of Pages: 392 Pages
Signs And Warnings Left
Signs And Warnings Right
Signs And Warnings Front
Signs And Warnings Rear
Cover Panel
Sound Proofing Covers
Engine Hood
Lighting, Halogen In Hardtop
Lighting, Xenon In Roof
Lighting, Halogen Lamps
Lighting, Xenon Lamps
Lighting Balloon With Support
Lighting Balloon With Bracket
Headlight 24v
Rotary Beacon With Roof
Horn
Collision Protection,Mech.
Collision Protection,Elec.
Footstep
Operator Console Electrics
Control Desk
Console Slide
Console Rail Power Cable
Platform
Mount For Seat With Guard Rail
Driver's Seat
Driver's Seat
Lateral Operator's Console
Poles Canopy
Canopy Frame Without Screen
Front Window
Canopy
Rear View Mirror With Fixation
Cover Panel
Set Of Tools
Power Unit
Diesel Engine
Fuel Supply
Silencer
Complete Hinged Exhaust Flange
Air Intake
Refuelling System
Hydraulic Tank
Panolin Partial Flow Filter
Pump Splitter Gearbox
Pump Hydraulic Rams
Leakage
Conveyor Unit
Conveyor Unit
Return Lines
Tamper
Vibration
High-Power Compaction
Valve Block Hydraulic Rams
Valve Block Width Control
Valve Block
Control Block
Valve Block
Power Supply, 24 V
Plug Socket,Schuko
Safety Switch
Plug Socket
Control Box Compl.
Control Box Mechanical
Control Box Mounting Plate
Control Box Control Unit
Wire Harness
Heating Box Complete
Heating Box Mechanical
Heating Box Connecting Plate
Heating Box Control Unit1
Heating Box Control Unit2
Heating Box Plug Socket
Generator
Crawler Track, Left Side
Crawler Track, Right Side
Crawler With Rubber Pads
Traction Drive, Left Side
Traction Drive, Hydr, Right
Feed,Traction Drive(Hydraulic)
Brake (Hydraulic)
Rubber Baffle
Reverse Motion Horn
Direction Indicator
Automatic Steering Control
Tube
Push-Roller
Material Hopper
Hopper, Left Side Hydraulic
Hopper, Right Side Hydraulic
Hopper Front (Mechanical)
Reservoir
Operating Instructions Warning
Accessories Reservoir
Return Pulley Compl.
Bottom Plate
Conveyor Unit
Paving Crushed Stone
DrIVing Shaft Conveyor
Conveyor Chain
Guard For Conveyor
Drive Conveyor, Left Side
Drive Conveyor, Right Side
Drive Conveyor(R) Hyd
Control Mechanical Sensor
Suspension Augers
Auger Drive
Gearbox Auger, Left Side
Gearbox Auger, Right Side
Auger Drive Left Side
Auger Drive Right Side
Height Adjustment, Auger Hydr.
Auger Shaft With Bearing
Shaft With Bearing 1110mm
Shaft With Bearing 2370mm
Mechanical Sensor
Sonic Sensor Auger
Limiting Plate Auger Tunnel
Auger Extension 2x0,65m
Auger Extension 1, 0m
Auger Extension 4, 6m
Auger Extension 7, 1m
Auger Extension 9, 7m
Auger Extension 10,7m
Auger Extension 14,3m
NIVeltronic Plus, Basic
Bracket 2nd Sensor
Mechanical Sonic Sensor
Sonic Sensor
Ultrasonic Sensor
Slope Sensor
Laser Sensor
Big-Multiplex-Ski
Ski 2m
Averaging Beam 7m
Accessories For Stringline
Cleaner Unit
Washdown System With Tank
Spray Hose
Spray Pump
Rewinder
Screed Arms
Hydraulic Ram, Left Side
Hydraulic Ram, Right Side
Roller Guiding
Screed Lift-Lower
Screed Assist
Screed Lock
Screed Lock (Hydraulic)
Hydraulics For Screed Lock
Width Control Screed
Tamper
Vibration
Screed, High Compaction
Hydraulic Elements
Grease Lubrication Unit
Lubrication System Conveyor
Lubrication System Auger
Lubrication System Outside
Grease Pump
Lubrication System Filling
Service Kit 50 Hours
Service Kit 500 Hours
Service Kit 1000 Hours
Vss Hopper Front
Vss Return Pulley
Vss Drive Shaft
Vss Auger Blade
Vss Auger
Shop Kit
