Wirtgen Vogele Crawler Asphalt Paver SUPER 1800-2 12.82 2074045 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Crawler Asphalt Paver
Type of Document: Parts Manual
Model: Vogele SUPER 1800-2
Date: 2013
Number of Pages: 208 Pages
Signs And Warnings Left
Signs And Warnings Right
Signs And Warnings Front
Signs And Warnings Rear
Cover Panel
Bulkhead Panel
Cover
Engine Hood
Lighting, Halogen In Hardtop
Working Light
Headlight 24v
Horn
Footstep
Additional Weight
Additional Weight 9m
Operator Console Electrics
Control Desk
Console Slide
Console Rail Power Cable
Platform
Mount For Seat With Guard Rail
Driver's Seat
Lateral Operator's Console
Poles Canopy
Canopy Frame Without Screen
Front Window
Canopy
Rear View Mirror With Fixation
Set Of Tools
Power Unit
Diesel Engine Com3 Epa
Fuel Supply
Silencer
Complete Hinged Exhaust Flange
Air Intake
Hydraulic Tank
Pump Splitter Gearbox
Pump Hydraulic Rams
Leakage
Conveyor,Left Side (Hydraulic)
Conveyor,Right Side(Hydraulic)
Reverse Motion
Valve Block Hydraulic Rams 1
Valve Block Hydraulic Rams 2
Valve Block Width Control
Valve Block Tamper
Valves Vibrators, Pressure Bar
Battery
Power Supply, 24 V
Plug
Control Box Compl.
Control Box Mechanical
Control Box Mounting Plate
Control Box Terminal Strip
Control Box Control Unit
Control Box Plug Sockets
Wire Harness
Can Node
Heating Box Complete
Heating Box Mechanical
Heating Box Connecting Plate
Heating Box Control Unit1
Heating Box Control Unit2
Heating Box Plug Socket
Generator With Mounting Parts
Generator Standard
Crawler Track, Left Side
Crawler Track, Right Side
Crawler With Rubber Pads
Traction Transmission
Traction Drive, Left Side
Traction Drive, Hydr, Right
Control,Traction Drive
Feed,Traction Drive(Hydraulic)
Adjusting Pressure
Brake (Hydraulic)
Direction Indicator
Automatic Steering Control
Ultrasonic Scanning
Tube
Push-Roller
Material Hopper
Hopper Side, Left (Hydraulic)
Hopper, Right Side Hydraulic
Hopper Front (Mechanical)
Return Pulley Compl.
Bottom Plate
DrIVing Shaft Conveyor
Conveyor Chain Cpl.
Guard For Conveyor
Drive Conveyor, Left, Mech
Drive Conveyor, Left Side
Conveyor Drive, Right, Mech
Drive Conveyor(R) Hyd
Control Mechanical Sensor
Suspension Augers
Auger Drive Left Side
Auger Drive Right Side
Spur Gearbox
Drive Auger, Left Side
Drive Auger, Right Side
Height Adjustment, Mechanical
Auger Shaft, Left Side
Auger Shaft, Right Side
Bearing Block, Left Side
Bearing Block, Right Side
Sonic Sensor Auger
Limiting Plate Auger Tunnel
Auger Extension 2x0,25m
Auger Extension 2x0,65m
Auger Extension 2x1,2m
Auger Extension 2x1,0m
Auger Extension 4, 6m
Auger Extension 4. 6-7.1m
NIVeltronic Plus, Basic
Bracket 2nd Sensor
Mechanical Sonic Sensor
Ultrasonic Sensor
Slope Sensor
Ski 2m
Accessories For Stringline
Screed Arms
Hydraulic Ram, Left Side
Hydraulic Ram, Right Side
Screed Lift-Lower
Screed Assist
Valve Block
Screed Lock (Mechanical)
Width Control Screed
Tamper Connector
Tamper And Vibrators
Hydraulic Elements
Lubrication System Pump
Lubrication System Conveyor
Lubrication System Auger
Grease Pump
Lubrication System Filling
Bracket 2nd Sensor
Ultrasonic Sensor
Slope Sensor
Ski 2m
Screed Arms
Screed Lift-Lower
Screed Assist
Valve Block
Tamper Connector
Hydraulic Elements
Grease Pump
