Wirtgen Vogele Crawler Asphalt Paver SUPER 1600-1 SUPER 1800-1 09.82 2034271 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Crawler Asphalt Paver
Type of Document: Parts Manual
Model: Vogele SUPER 1600-1, SUPER 1800-1
Date: 2013
Number of Pages: 220 Pages
Operating Instructions Warning
Signs Instructions And Safety
Cover Outside, Left Side
Cover Inside, Left Side
Panel, Right Side
Engine Hood
Lighting Warning
Plug Socket, Schuko-2x Cee
Plug Socket,4x Cee
Guard
Footstep
Control Desk
Console Slide
Guide
Platform
Driver's Seat With Guardrail
Remote Control With Display
Rc With Display NIVeltronic
Protection Roof
Canopy With Sides, Rear, Front
Windscreen With Wiper
Rear View Mirror With Fixation
Tools
Power Unit
Additional Parts Engine
Fuel Supply
Silencer
Air Intake
Refuelling System
Hydraulic Tank
Pump Splitter Gearbox
Pump Hydraulic Rams
Valve Block
Pumps
Valve Block
Pump Tamper
Valve Block Tamper
Pump Tamper, Vibrators
Valve Block Tamper, Vibrators
Pump
Return Pipe I
Return Pipe II
Valve Block Hydraulic Rams
Valve Block Width Control
Valve Screed Assist On Off
Valve Block High Compaction
Valve Block Tamper
Valves Vibrators, Pressure Bar
Power Supply, 24 V
Switch Box
Control Box Mounting Plate 1
Control Box Mounting Plate 2
Control Box Mounting Plate 3
Control Box Mounting Plate 4
Control Box Screed Heating
Generator Standard
Generator Power
Valves Output Module
Crawler Track, Left Side
Traction Drive, Left Side
Crawler Track, Right Side
Traction Drive, Hydr, Right
Traction Transmission
Roller Crawler Track
Front Idler
Spring Assembly
Strike-Off Plate
Strike-Off Plate
Brake
Gear Shifting Mechanism
Adjusting Pressure
Reverse Motion Horn
Direction Indicator
Automatic Steering Control
Push-Roller, Rigid
Material Hopper
Hopper Side, Left (Hydraulic)
Hopper Side, Right (Hydraulic)
Hopper Front (Mechanical)
Hopper Front (Hydraulic)
Return Pulley
Bottom Plate
DrIVing Shaft Conveyor
Conveyor Chain
Guard Mechanical Hopper Front
Guard Hydraulic Hopper Front
Drive Conveyor, Left, Mech
Drive Conveyor, Left Side
Conveyor Drive, Right, Mech
Drive Conveyor(R) Hyd
Gearbox
Monitoring Conveyor
Suspension Augers
Auger Drive Left Side
Auger Drive Right Side
Auger Shaft, Left Side
Auger Shaft, Right Side
Height Adjustment, Hydraulic
Height Adjustment, Mechanical
Monitoring Unit Auger
Sonic Sensor Auger
Auger Extension 2x0,25m
Auger Extension 2x0.5m
Auger Extension 2x1m
Auger Extension 4. 6m
Auger Extension 4. 6-7.1m
Limiting Plate Auger Tunnel
Tube
Bearing Block, Left Side
Bearing Block, Right Side
NIVeltronic Basics
Handset
Bracket 2nd Sensor
Levelling Sensor
Sonic Sensor
Slope Sensor
Averaging Beam 7m
Accessories For Stringline
Washdown System Without Tank
Washdown System With Tank
Switch
Spray Assembly
Rewinder
Screed Arms
Hydraulic Ram, Left Side
Hydraulic Ram, Right Side
Ram Screed Lift
Screed Assist
Screed Lock (Mechanical)
Screed Lock (Hydraulic)
Width Control Screed
Tamper
Vibration
High-Power Compaction
Screed Connections
Hydraulic Elements
Pump Connector
Lubrication System Conveyor
Lubrication System Auger
Grease Pump
Filling Grease Reservoir
Service Kit 50 Hours
Service Kit 500 Hours
Service Kit 1000 Hours
