Wirtgen Vogele Crawler Asphalt Paver SUPER 1600-1 SUPER 1800-1 07.82 2010432 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Crawler Asphalt Paver
Type of Document: Parts Manual
Model: Vogele SUPER 1600-1, SUPER 1800-1
Date: 2013
Number of Pages: 269 Pages
Operating Instructions Warning
Signs Instructions And Safety
Cover Outside, Left Side
Cover Inside, Left Side
Panel, Right Side
Engine Hood
Lighting Warning
Plug Socket, Schuko-2x Cee
Plug Socket,4x Cee
Guard
Guard
Footstep
Operator´S Stand
Control Desk PIVot-Mounted
Connecting Plate
Control Desk Row 1
Control Desk Row 2
Control Desk Row 3
Control Desk Row 4
Control Desk Row 5
Control Desk Row 6
Platform
Driver's Seat With Guardrail
Remote Control (Standard)
Rc With Display NIVeltronic
Remote Control With Display
Protection Roof
Canopy With Sides, Rear, Front
Windscreen With Wiper
Rear View Mirror
Tools
Power Unit
Additional Parts Engine
Fuel Supply
Silencer
Air Intake
Refuelling System
Hydraulic Tank
Pump Splitter Gearbox
Pump Hydraulic Rams
Valve Block
Pumps
Valve Block
Pump Tamper
Valve Block Tamper
Pump Tamper, Vibrators
Valve Block Tamper, Vibrators
Pump
Return Pipe I
Return Pipe II
Valve Block Hydraulic Rams
Valve Block Width Control
Valve Screed Assist On Off
Valve Block High Compaction
Valve Block Tamper
Valves Vibrators, Pressure Bar
Power Supply, 24 V
Switch Box
Control Box Mounting Plate 1
Control Box Mounting Plate 2
Control Box Mounting Plate 3
Control Box Mounting Plate 4
Control Box Screed Heating
Heating Box Budget
Generator 13 18 Kva
Three-Phase A.C. Generator
Valves Output Module
Crawler Track, Left Side
Traction Drive, Left Side
Crawler Track, Right Side
Traction Drive, Hydr, Right
Traction Transmission
Roller Crawler Track
Front Idler
Spring Assembly
Deflector, Left Side
Deflector, Right Side
Brake
Gear Shifting Mechanism
Adjusting Pressure
Reverse Motion Horn
Direction Indicator
Automatic Steering Control
Push-Roller, Rigid
Material Hopper
Hopper Side, Left (Hydraulic)
Hopper Side, Right (Hydraulic)
Hopper Front (Mechanical)
Hopper Front (Hydraulic)
Return Pulley
Bottom Plate
DrIVing Shaft Conveyor
Conveyor Chain
Guard Mechanical Hopper Front
Guard Hydraulic Hopper Front
Drive Conveyor, Left, Mech
Drive Conveyor, Left Side
Conveyor Drive, Right, Mech
Drive Conveyor(R) Hyd
Gearbox
Monitoring Conveyor
Suspension Augers
Auger Drive Left Side
Auger Drive Right Side
Auger Shaft, Left Side
Auger Shaft, Right Side
Height Adjustment, Hydraulic
Height Adjustment, Mechanical
Monitoring Unit Auger
Auger Extension 2x0,25m
Auger Extension 2x0.5m
Auger Extension 2x1m
Auger Extension 4. 6m
Auger Extension 4. 6-7.1m
Limiting Plate Auger Tunnel
Tube
Bearing Block, Left Side
Bearing Block, Right Side
NIVeltronic Basics
Handset
Bracket 2nd Sensor
Levelling Sensor
Sonic Sensor
Slope Sensor
Roadscan System
Ski 2m
Averaging Beam 7m
Accessories For Stringline
Washdown System Without Tank
Washdown System With Tank
Switch
Spray Assembly
Rewinder
Screed Arms
Hydraulic Ram, Left Side
Hydraulic Ram, Right Side
Ram Screed Lift
Screed Assist
Screed Lock (Mechanical)
Screed Lock (Hydraulic)
Width Control Screed
Tamper
Vibration
High-Power Compaction
Screed Connections
Hydraulic Elements
Pump Connector
Lubrication System Conveyor
Lubrication System Auger
Pump
Grease Pump
Filling Grease Reservoir
Service Kit 50 Hours
Service Kit 500 Hours
Service Kit 1000 Hours
Service Packs
Date: 2013
Panel, Right Side
Engine Hood
Lighting Warning
Plug Socket,4x Cee
Guard
Guard
Footstep
Operator´S Stand
Connecting Plate
Control Desk Row 1
Control Desk Row 2
Control Desk Row 3
Control Desk Row 4
Control Desk Row 5
Control Desk Row 6
Platform
Protection Roof
Rear View Mirror
Tools
Power Unit
Fuel Supply
Silencer
Air Intake
Refuelling System
Hydraulic Tank
Pump Hydraulic Rams
Valve Block
Pumps
Valve Block
Pump Tamper
Valve Block Tamper
Pump
Return Pipe I
Return Pipe II
Valve Block Tamper
Power Supply, 24 V
Switch Box
Heating Box Budget
Generator 13 18 Kva
Front Idler
Spring Assembly
Brake
Adjusting Pressure
Reverse Motion Horn
Direction Indicator
Push-Roller, Rigid
Material Hopper
Return Pulley
Bottom Plate
Conveyor Chain
Gearbox
Monitoring Conveyor
Suspension Augers
Tube
NIVeltronic Basics
Handset
Bracket 2nd Sensor
Levelling Sensor
Sonic Sensor
Slope Sensor
Roadscan System
Ski 2m
Averaging Beam 7m
Switch
Spray Assembly
Rewinder
Screed Arms
Ram Screed Lift
Screed Assist
Tamper
Vibration
Screed Connections
Hydraulic Elements
Pump Connector
Pump
Grease Pump
Service Packs
- Wirtgen Hamm Roller 3412-3625 HT Repair Manual_01298119
- Wirtgen W1000F, W1200F, W1300F Hydraulic Hose Diagram 07.10 (811-9999)
- Wirtgen W1000F Electrical Diagram 07.10 (811-9999)
- Wirtgen Vogele Super 1600-1800 Spare Parts Catalogue_2060709
- WIRTGEN WIDOS WR2500S, SK PART CATALOG SHEMATIC
- Wirtgen Vogele Super 1900 2100 Circuit Diagrams_2042776
- WIRTGEN WIDOS CM2000 PART CATALOG SHEMATIC
- Wirtgen W200 Milling Machine Service Instruction_2154700_V02_es
- Wirtgen Vogele Super 1800-2 SJ Techical Training
- Wirtgen W1000F Hydraulic Diagram 07.10 (811-9999)
- Wirgen Group Parts and More 2015
- Wirtgen Vogele Super 1100-1300(3i) Operating Instruction_2325145
- Wirtgen Vogele 1182(Super 1600-18002SJ) Training Manual
- Wirtgen W2200 CR SM Spare Parts Catalogue_169647
- Wirtgen Hamm Roller 3516-3520 HT P Operating Manual
