Wirtgen Vogele Asphalt Paver VISION 5200-2i 09.74 2102002 Spare Parts Catalog
Brand: Wirtgen Vogele
Type of Machine: Asphalt Paver
Type of Document: Parts Manual
Model: Vogele VISION 5200-2i
Date: 2013
Number of Pages: 223 Pages
Signs And Warnings Left USA
Signs And Warnings Right USA
Signs And Warnings Front USA
Signs And Warnings Rear USA
Cover Panel
Sound Proofing Covers
Noise Insulation, Center
Engine Hood
Lighting, Halogen Lamps
Lighting, Xenon Lamps
Lighting Balloon
Lighting Balloon, Mount.Device
Working Light
Patrol Light
Horn
Footstep
Operator Console Electrics
Control Desk
Console Slide
Console Rail Power Cable
Platform
Mount For Seat With Guard Rail
Driver's Seat
Lateral Operator's Console
Remote Control
Umbrella
Mount For Umbrella
Storage Shelves
Set Of Tools
Power Unit
Diesel Engine
Power Unit
Diesel Engine
Fuel Supply
Exhaust System
Air Intake
Hydraulic Tank
Pump Splitter Gearbox
Pump Hydraulic Rams
Cyl.Funct.-Oil Feed
Leakage
Conveyor,Left Side (Hydraulic)
Conveyor,Right Side(Hydraulic)
Reverse Motion
Push-Roller, Hydraulic
Hopper Front (Hydraulic)
Hyd.Feeding Auger Conveyor
Screed Lock (Hydraulic)
Ventilation System (Hydraulic)
Valve Block Hydraulic Rams
Valve Block Switching Sys.
Valve Block
Suspension Valve Blocks
Power Supply, 24 V
Plug
Plug
Control Box Compl.
Control Box Mechanical
Control Box Mounting Plate
Control Box Terminal Strip
Control Box Control Unit
Control Box Plug Sockets
Wire Harness
Can Node
Heating Box Complete
Heating Box Mechanical
Heating Box Connecting Plate
Heating Box Control Unit
Heating Box Plug Socket
Generator With Mounting Parts
Generator Standard
Crawler Track, Left Side
Crawler Track, Right Side
Traction Drive, Left Side
Traction Drive, Hydr, Right
Crawler Track Tensioning Hydr.
Valve Block
Feed,Traction Drive(Hydraulic)
Advance Drive Gear System Hyd.
Adjusting Pressure
Deflector
Towing Attachment Hydr.
Reverse Motion Horn
Direction Indicator
Push-Roller, Rigid
Truck Hitch Mech.
Connector Kit
Push-Roller Bar (Hydraulic)
Truck Hitch Hyd.
Valve Block Push-Roller
Material Hopper
Hopper Side, Left (Hydraulic)
Hopper Side, Right (Hydraulic)
Extra Material Hopper
Return Pulley Compl.
Bottom Plate
Driving Shaft Conveyor
Conveyor Chain Cpl.
Guard For Conveyor
Conveyor Tensioning
Conveyor Tensioning (Hydr.)
Valve Block
Drive Conveyor, Left, Mech
Conveyor Drive, Right, Mech
Drive Conveyor, Left Side
Drive Conveyor(R) Hyd
Control Mechanical Sensor
Suspension Augers
Auger Drive Left Side
Auger Drive Right Side
Height Adjustment Hydr.
Height Adjustment, Auger Hydr.
Auger Shaft, Left Side
Auger Shaft, Right Side
Bearing Block, Left Side
Bearing Block, Right Side
Sonic Sensor Auger
Limiting Plate, Mech.
Limiting Plate, Hyd.
Limiting Plate, Elec.
Valve Block Limiting Plate
Auger Extension 2x0,65m
Auger Extension 2x1,0m
Auger Extension
Auger Width 4,6m
Niveltronic Plus, Basic
Bracket 2nd Sensor
Tow Arm Fixture
Mechanical Sonic Sensor
Sonic Sensor
Sonic Sensor
Ultrasonic Sensor
Slope Sensor
Big-Ski (Mechanical)
Big-Ski (Electronics)
Ski 2m
Accessories For Stringline
Cleaning Pump
Pump Hose Drum
Tank For Washdown System
Screed Arms
Hydraulic Ram, Left Side
Hydraulic Ram, Right Side
Screed Lift-Lower
Screed Assist
Valve Block
Screed Lock (Mechanical)
Hydraulics For Screed Lock
Width Control Screed
Vibration Hydraulics
Hydraulic Elements Berm
Hydr.Elements Carlson Ez Iv
Hydr.Elements Carlson Ez Iii
Hydraulic Elements Hr500e
Hydraulic Elements Vr600-2v
Additional Function Vr600-2v
Valve Block Width Control
Hydraulic Elements Vf600-2v
Electrics Hr500e
Lubrication System Pump
Distributor
Lubrication System Conveyor
Lubrication System Auger
Grease Pump
Lubrication System Filling
Service Kit 50 Hours
Service Kit 500 Hours
Service Kit 1000 Hours
Vss Hopper Front
Vss Return Pulley
Vss Drive Shaft
Vss Auger Blade
Vss Auger
Shop Kit
Date: 2013
Cover Panel
Engine Hood
Lighting Balloon
Working Light
Patrol Light
Horn
Footstep
Control Desk
Console Slide
Platform
Driver's Seat
Remote Control
Umbrella
Mount For Umbrella
Storage Shelves
Set Of Tools
Power Unit
Diesel Engine
Power Unit
Diesel Engine
Fuel Supply
Exhaust System
Air Intake
Hydraulic Tank
Pump Hydraulic Rams
Cyl.Funct.-Oil Feed
Leakage
Reverse Motion
Valve Block
Power Supply, 24 V
Plug
Plug
Control Box Compl.
Wire Harness
Can Node
Generator Standard
Valve Block
Adjusting Pressure
Deflector
Reverse Motion Horn
Direction Indicator
Push-Roller, Rigid
Truck Hitch Mech.
Connector Kit
Truck Hitch Hyd.
Material Hopper
Bottom Plate
Conveyor Chain Cpl.
Guard For Conveyor
Conveyor Tensioning
Valve Block
Suspension Augers
Sonic Sensor Auger
Auger Extension
Auger Width 4,6m
Bracket 2nd Sensor
Tow Arm Fixture
Sonic Sensor
Sonic Sensor
Ultrasonic Sensor
Slope Sensor
Ski 2m
Cleaning Pump
Pump Hose Drum
Screed Arms
Screed Lift-Lower
Screed Assist
Valve Block
Electrics Hr500e
Distributor
Grease Pump
Vss Hopper Front
Vss Return Pulley
Vss Drive Shaft
Vss Auger Blade
Vss Auger
Shop Kit
- Wirtgen Hamm Roller 3412-3625 HT Repair Manual_01298119
- Wirtgen W1000F, W1200F, W1300F Hydraulic Hose Diagram 07.10 (811-9999)
- Wirtgen W1000F Electrical Diagram 07.10 (811-9999)
- Wirtgen Vogele Super 1600-1800 Spare Parts Catalogue_2060709
- WIRTGEN WIDOS WR2500S, SK PART CATALOG SHEMATIC
- Wirtgen Vogele Super 1900 2100 Circuit Diagrams_2042776
- WIRTGEN WIDOS CM2000 PART CATALOG SHEMATIC
- Wirtgen W200 Milling Machine Service Instruction_2154700_V02_es
- Wirtgen Vogele Super 1800-2 SJ Techical Training
- Wirtgen W1000F Hydraulic Diagram 07.10 (811-9999)
- Wirgen Group Parts and More 2015
- Wirtgen Vogele Super 1100-1300(3i) Operating Instruction_2325145
- Wirtgen Vogele 1182(Super 1600-18002SJ) Training Manual
- Wirtgen W2200 CR SM Spare Parts Catalogue_169647
- Wirtgen Hamm Roller 3516-3520 HT P Operating Manual
