Wirtgen Soil Stabilizer WR 2500 S WR 2500 SK 04.WR 192130 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Soil Stabilizer
Type of Document: Parts Manual
Model: Wirtgen WR 2500 S, WR 2500 SK
Date: 2013
Number of Pages: 247 Pages
Lighting Warning Device
Chassis Ancillary Parts
Lock Box
Stickers Le I
Stickers Le II
Stickers Right
Stickers Operator's Stand
Stickers Front Rear
Stickers Foam-Bitumen
Stickers Le I (USA)
Stickers Le II (USA)
Stickers Right (USA)
Stickers Operat. Stand (USA)
Stickers Front Rear (USA)
Stickers Foam-Bitumen (USA)
Control Panel, Lh
Control Panel, Rh
Control Panel, Center
Contr.Panel, Center-Binder Unit
Control Panel Lh. Cab
Operator's Station And Seat
Covers Hand Rails
Cab Frame
Displace Cabin
Heater Unit
Mirror
Additional Mirror
Air Conditioning
Camera System
Radio Unit
Drum Suspension
Drum Flap Front
Drum Flap Rear
Drum Flap Rear-Pressure Contr.
Milling Drum Unit-Suspension
Belt-Drive Case
Drum Bearing
Drive Drum Clutch
Coupling
Gearbox Toothing
Gearbox Bearing
Gearbox Preliminary Bearing
Belt Tensioner Unit
Belt Tensioner Unit
Milling Drum Unit Up-Down
Drum Fb2400 Ht11 La20 D20
Drum Fb2400 Ht11 La20 D22
Control Unit
Drum Turning Jig
Power Unit
Fuel Supply
Air Intake
Exhaust System
Exhaust Silencer Cover
Combined Cooler
Fan Drive
Ancillary Parts Cooler
Combined Cooler Covers
Cooling System-Air
Cooling System-Water
Covers
Pump Splitter Gearbox Clutch
Functions - Hydr. Pumps
Cyl. Functions-Pump Connectors
Cyl.Functions - Valve Blocks
Return Lines
Hydraulic Oil Tank
Battery Alternator Starter
Electrical Cabinet Doors
Elec.Cabinet - Mounting Plate
Emergency Stop
Wheel Brackets
Height Adjustment Front
Height Adjustment Rear
Drive System Pump Connectors
Drive System, Left
Drive System, Right
Switching System
Leakage Oil
Control Unit
Steering, Front
Steering, Rear
Lateral Tilt
Water System Ancillary Parts
Additional Water Tank
Jet Cleaner
Control Unit
El.Cabinet Generator Heat.Unit
Drive Generator
Spraying Unit Ancillary Parts
Hyd. Drive-Water Emuls. Single
Hyd. Drive-Water Emuls. Double
Spraying Unit Single
Spraying Unit Double
Flow Meter
Pump Connect-Bitumen Generator
Hyd.Drive-Foam Bitumen
Inject.Pump-Foam Bit.Front
Inject.Pump-Foam Bit.Rear
Injection Bar-Foam Bitumen
Foam Bitumen - Air System
Foam Strip-Process Water
Foam Strip-Hyd. Cilinder
Foam Strip-Air Intake
Foam Strip-Air Cylinder
Drive Water Pump-Foam Bitumen
Bitumen Water
Oil Feed-Spraying Unit Single
Oil Feed-Spraying Unit Double
Injection Bar-Water Emulsion
Inject.Bar-Hyd. Cylinder
Conveying System
Cylinder Functions
Drive Water Pump
Spraying (Standard)
Spraying Unit Printer
Compressed Air System
Pneumatic Punch
Pushing Device
Filter Inserts-Engine(250h,..)
Filter Inserts-Engine(500h,..)
Filter Inserts-Hydr. (500h,..)
Filter Inserts-Hydr.(1000h,..)
Tools
Oil Diagnostic Set No.3
Keys Set
Hydraulic Instrument Case
Instrument Case-Service Master
Hydraulic Accessories
O-Ring Set
Service Case Electr.
Electr. Measuring Tools Case
Service Case I
Service Case II
Service Case III
Service Case IV
Emergency Kit
Vacuum-Pump
