705,578
Wirtgen Slipform Paver SP 500 SP 500 Vario 10.SP 172172 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Slipform Paver
Type of Document: Parts Manual
Model: Wirtgen SP 500, SP 500 Vario
Date: 2013
Number of Pages: 434 Pages
Chassis Basic
Chassis-Base Vario
Chassis Telescoping Step 2
Mechanical Telescoping
Hydr.Telescoping
Chassis Telescoping (Hydr.)
Slewing Arm Front
Slewing Arm Rear
Slewing Arm Offset
Crawler Unit Suspension
Arm Front
Arm Rear
Arms Vario
Arm Slewing
Lighting
Lighting 110v
Chassis Extension For Dbi
Signs Stickers Front
Stickers Rear I
Stickers Rear II
Stickers Left
Stickers Right
Stickers Operator's Stand
Stickers Conveyor Unit
Handrail Gangway
Control Desk
Contr.Panel Mounting Parts I
Contr.Panel Mounting Parts II
Contr.Panel Mounting Parts III
Contr.Panel Mounting Parts IV
Electrical Cabinet
Electrical Cabinet-Pl Control
Electr.Cab. Mount. Parts I
Electr.Cab. Mount. Parts II
Elec.Cabinet Ventilation
Protection Roof
Trimmer Base
Drive Trimmer
Trimmer Up Down
Trimmer Traverse
Contol Panel Trimmer
Trimmer Drum, Lh
Ancillary Part 0, 25 M Lh
Ancillary Part 0, 30 M Lh
Ancillary Part 0, 35 M Lh
Trimmer Drum, Rh
Ancillary Part 0, 25 M Rh
Ancillary Part 0, 30 M Rh
Ancillary Part 0, 35 M Rh
Milling Drum Suspension Lh Rh
Engine Ancillary Parts
Air Filter
Silencer
Diesel Tank
Fuel Supply
Cooler Cooling System
Engine Station Cover
Functions - Hydr. Pumps
Clutch Hyd.Oil Tank
Hyd.Oil Tank - Heat Protection
Valve Blocks I
Valve Blocks II
Valve Block Trimmer
Cyl.Functions Advance Drive
Return Lines
Generator Drive 20kva
Generator Drive 40kva
Electrical Cabinet 110v
El.Power Supp. -Battery Altern.
Undercarriage, Front, Lh
Undercarriage, Front, Rh
Crawler Unit Rear Left
Undercarriage, Rear, Rh
Height Adjustment Front Rear
Terminal Box - Crawler Front
Terminal Box - Crawler Rear
Crawler-Layout Of Groups
Crawler Unit
Drive System, Left
Drive System, Right
Brake Sys. Emerg. Towing Device
Steering, Front Lh (Mech.)
Steering, Front Rh (Mech.)
Steering Rear Lh (Mech.)
Steering Rear Rh (Mech.)
Steering (Hydr.)
Conveyor 4,5m
Conveyor Suspension 4,5m
Conveyor 5,5m
Conveyor Suspension 5,5m
Drive Conveyor, Hyd
Feed Auger
Charging Auger I
Charging Auger II
Transport Support
Drive Unidefeed Auger
Feed Auger Sliding
Conveyor Sliding
Auger
Spreading Auger - Camber 3.50m
Auger Extension Lh
Auger Extension Rh
Spreading Auger Hydr.
Spreading Auger-Camber Hydr.
Spreader Plough
Spreader Plough - Course Cart
Spreader Plough - Guide Rail
Spreader Plough - Drive
Drive Spreading Plough Hydr.
Spreading Plough-Drive Vario
Drive Spread. Plough-Vario Hyd.
Spreader Plough - Up Down
Levelling Unit
Tracer - Steer. Height Adjust.
Slab Tracer
Wire Tension System
Tension-Cycle
Slope Control
Ancillary Parts
Terminal Box 3d-Control Unit
Water Tank
Jet Cleaner
Control Unit
Drive - High Pressure Cleaner
Additional Water Pump
Concrete Mould 2, 00m Basic
Concrete Mould Camber
Front Panel Up Down
Metering Central Up Down
Concrete Mould Camber Up Down
Remote Control
Mould - Extension
Slipform Basic
Depthform 200 Mm
Depthform 200mm Dbi
Depthform 260 Mm
Depthform 260mm Dbi
Depthform 360 Mm
Slipform
Slipform Suspension
Concrete Mould Basic - Vario
Camber Up Down Vario
Remote Control Camber Vario
Mould - Extension Vario
Front Panel - Vario
Metering Central Up Down Vario
Slipform - Vario
Depthform - Vario 200mm
Depthform Dbi Vario 200
Depthform - Vario 260mm
Depthform Dbi Vario 260
Depthform - Vario 360mm
Slipform - Vario
Slipform Dbi Vario
Slipform Lh Up Down
Slipform Rh Up Down
Drive - Hydr. Vibration 1-8
Drive - Hydr. Vibration 9-16
Connectors-Hydr. Vibration 1-8
Connectors-Hydr. Vibration 9-16
Vibrator D66 Bent Electr.
Vibrators D66 Strait Electr.
Vibrators D76 Elektrical
Vibrators Hydrailical
Oscillating Beam 2,0m
Lateral Screed Extension
Lateral Screed 1, 5m
Camber Up Down
Oscillat.Beam Basic-Vario I.
Oscillat.Beam Basic-Vario II.
Lateral Screed Extens.Vario
Oscillating Beam 2,5m-Vario
Oscillating Beam Drive
Super Smoother Basic
Super Smoother Basic Vario
Super Smoother - Extensions
Super Smoother Drive
Drive Unit-Sup. Smoother Vario
Course Cart-Longitud.Smoother
Rope Drum - Super Smoother
Longitudinal Smoother-Sliding
Longit. Smoother-Sliding Vario
Mould Suspension Offset
Slipform With Spring-Tensioned
Slipform Side Offset Hydr.Lh.
Slipform Side Offset Hydr.Rh.
Funnel
Side Bar Inserter
Side Bar Inserter Vario
Basic Unit Stbi
Side Tie-Bar Inserter - Stand.
Side Tie-Bar Inserter-Sliding
Frame Basic
Suspension - Basic
Vibration Frame Lh Up Down
Vibration Frame Rh Up Down
Vibration Frame
Modular System For Dbi
Base Group - Dbi
Base Group Spare Parts
Distributor
Drive Distributor Control
Dbi - Ancillary Parts
Dbi - Ancillary Parts Vario
Dbi-Frame Sliding
Dbi Extension
Dbi Extension 1, 0m Camber
Electrical Cabinet - Dbi
Control Panel - Dbi
Remote Control Dbi
Terminal Box Dbi
Control Units Dbi
Vibrator Connection Box Dbi
Impulse Generator Unit
Controls Impulse Transm.Unit
Crane Unit
Filter Inserts-Engine
Filter Inserts-Hyd.(El.Vibrat)
Filter Inserts-Hyd.(Hyd.Vibr.)
Tools
Additional Tools
Oil Diagnostic Set No.3
Keys Set
Service Set - Belt Repair
Hydraulic Instrument Case
Instrument Case-Service Master
Hydraulic Accessories
O-Ring Set
Service Case Electr.
Electrical Service Kit
Service Case I
Service Case II
Service Case III
Service Case IV
Electr. Measuring Tools Case
Vacuum-Pump
