705,578
Wirtgen Slipform Paver SP 500 02.SP 128426 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Slipform Paver
Type of Document: Parts Manual
Model: Wirtgen SP 500
Date: 2013
Number of Pages: 290 Pages
Chassis-Ancillary Parts
Walkway
Chassis Telescoping (Mech.)
Chassis Telescoping (Hydr.)
Slewing Arms I
Slewing Arms II
Sound Insulation Hydr.+El.VIbr
Sound Insulation Electr.VIbr.
Sound Insulation Hydr.VIbr.
Extension 1,25 M Lh
Extension 1,25 M Rh
Ancillary Parts For Dbi I
Ancillary Parts Dbi II
Lighting
Lighting 110v
Control Desk
Contr.Panel Mounting Parts I
Contr.Panel Mounting Parts II
Contr.Panel Mounting Parts III
Contr.Panel Mounting Parts IV
Contr. Panel Mounting Parts V
Contr. Panel Mounting Parts VI
Electrical Cabinet
Elec.Cabinet Ventilation
Electr.Cab. Mount. Parts I
Electr.Cab. Mount. Parts II
Protection Roof
Trimmer Base
Drive Trimmer
Trimmer Up Down
Trimmer Traverse
Contol Panel Trimmer
Trimmer Drum, Rh
Ancillary Part 0, 25 M Rh
Ancillary Part 0, 30 M Rh
Ancillary Part 0, 35 M Rh
Trimmer Drum, Lh
Ancillary Part 0, 25 M Lh
Ancillary Part 0, 30 M Lh
Ancillary Part 0, 35 M Lh
Drive Station
Drive Station-Anc. Parts Engine
Fuel Supply
Engine- El. Ancillary Parts
Hydraulic Pump Drive
Valve Block Engine Station
Valve Blocks Crawlers
Valve Block Concrete Unit I
Valve Block Concrete Unit II
Valve Block Dbi
Valve Block Trimmer
Fan Drive Oil
Return Lines
Generator 20kva
Generator 40kva
VIbrator Connection Box
Additional VIbr. Connection Box
El.Power Supp. -Battery Altern.
Plug Box 24v
Undercarriage, Front, Lh
Undercarriage, Front, Rh
Undercarriage, Rear, Rh
Crawler Unit Rear Left
Height Adjustment, Left Side
Height Adjustment, Right Side
Terminal Box - Crawler
Crawler-Layout Of Groups
Crawler Unit
Drive System, Left
Drive System, Right
Travel Direction Changing
Towing Attachment
Steering, Front Lh (Mech.)
Steering, Front Rh (Mech.)
Steering Rear Lh (Mech.)
Steering Rear Rh (Mech.)
Steering, Lh (Hydr.)
Sterring Rh (Hydr. )
Conveyor 4,5m
Conveyor 5,5m
Control Unit Conveyor 5,5m
Drive Unit Conveyor
Feed Auger
Feed Auger Sliding
Drive Unidefeed Auger
Auger
Spreading Auger - Camber 3.50m
Drive Spreader Auger Lh
Drive Spreader Auger Rh
Auger Extension Lh
Auger Extension Rh
Spreader Plough Basis 2,00m
Drive Spreader Plough
Spreader Plough Raise Lower
Spreader Plough-Extension
Levelling Unit
Tracer - Steer. Height Adjust.
Slab Tracer
Wire Tension System
Tension-Cycle
Slope Control
Water System
Drive Jet Cleaner
Oscillating Beam Base 2,00 M
Drive Oscillating Beam
Oscillating Beam Extension
Camber 1,50m
Camber Up Down
Concrete Mould
Concrete Mould Camber
Concrete Mould Camber Up Down
Front Panel Rh Control Up Down
Front Panel Lh Control Up Down
Metering Central Up Down
Control Unit Camber
Remote Control
Mould - Extension
Super Smoother Base 2m
Super Smoother Base 2,00m
Lateral Drive - Super Smoother
Drive Unit-Super Smoother
Conn.Box-S. Smoohter Oscil.Beam
Super Smooter - Extension
Slipform
Slipform Lh Up Down
Slipform Rh Up Down
Depthform 200 Mm
Depthform 260 Mm
Depthform 360 Mm
Slipform Suspension
Drive - Hydr. Vibration
Connectors - Hydr. Vibration
VIbrator D66 Bent Electr.
VIbrators D66 Strait Electr.
VIbrators D76 Elektrical
VIbrators Hydrailical
Side-Bar Inserter D16x800
Side-Bar Inserter D32x500
Side-Bar Inserter D20x800
Side-Bar Inserter D32x1000
Basic Unit Stbi
Ancillary Parts Dbi
Contr. Units-Tie-Bar Inserter
Side Tie-Bar Inserter-Sliding
Dbi Frame Masch. 41+43
Dbi Frame Standard
Vibration Frame
Vibration Frame Lh Up Down
Vibration Frame Rh Up Down
Dbi-Frame Sliding
Dbi-Guide Rail
Dbi-Guide Rail Sliding
Distributor
Drive Distributor Control
Control Panel Distributor
Impulse Generator Unit
Controls Impulse Transm.Unit
Camber Unit
Dbi-Base Plates 200mm
Dbi-Base Plates 250mm
Slipform
Dbi-Electrical Cabinet
Dbi-Control Panel I
Dbi-Control Panel II
Dbi-Control Panel III
Crane Unit 610t
Crane Unit 810t
Filter Inserts-Engine
Filter Inserts - Hydraulics
SerVIce Set - Sealing Kits
SerVIce Set - Electrical Syst.
SerVIce Set - Bearings
Tools
Oil Diagnostic Set No.3
Keys Set
SerVIce Set - Belt Repair
Hydraulic Instrument Case
Instrument Case-Service Master
Hydraulic Accessories
O-Ring Set
SerVIce Case Electr.
Electr. Measuring Tools Case
Vacuum-Pump
