705,578
Wirtgen Slipform Paver SP 250 08.SP 129496 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Slipform Paver
Type of Document: Parts Manual
Model: Wirtgen SP 250
Date: 2013
Number of Pages: 371 Pages
Chassis-Front Part
Crawler Unit Suspension
Chasis-Rear Part
Chassis Extension
Chassis Telescoping (Hydr.)
Lighting
Lighting 110v
Stickers Left
Stickers Right
Stickers Left Right
Sticker
Stickers Operator's Stand
Stickers Front Rear
Stickers Charging Auger
Control Panel I
Control Panel II
Control Panel III
Control Panel IV
Control Panel V
Electrical Cabinet I
Electrical Cabinet-Pl Control
Elec.Cabinet Ventilation
Control Panel
Electrical Cabinet
Control Unit
Electrical Cabinet
Protection Roof
Trimmer Base
Height Adjustment Trimmer
Trimmer Traverse
Drive Trimmer
Milling Drum Suspension
Trimmer Drum, Lh
Trimmer Drum, Rh
Ancillary Part 0, 25 M Lh
Ancillary Part 0, 25m Rh
Ancillary Part 0, 30m Lh
Ancillary Part 0, 30m Rh
Ancillary Part 0, 35m Lh
Ancillary Part 0, 35m Rh
Drive Station
Power Station
Engine Hood Up Down
Drive Station-Anc. Parts Engine
Exhaust Silencer + Air Filter
Ancill.Parts Oil Watercooler
Fuel Supply
Fuel Supply
Engine- El. Ancillary Parts
Hydraulic Tank
Hydraulic Pump Drive
Pump Splitter Gearbox
Oil Feed-Feed Auger
Oil Feed-Conveyor Drive
Oil Feed-Lateral Auger
Oil Feed - Drive System
Hydr.Oil Feed - Cyl.Functions
Generator Vibrator
Oil Feed Trimmer
Return Lines
Valve Blocks I
Valve Blocks II
Valve Blocks III
El.Power Supp. -Battery Altern.
Generator 20kva
Drive Generator
Electr.Cabinet Vibrat. 6-Fold
Electr.Cabinet Vibrat. 10-Fold
Plug Box 24v Single
Undercarriage, Front, Lh
Undercarriage, Front, Rh
Crawler Unit Slewing Front
Terminal Box Crawler Front
Crawler Unit Rear Left
Undercarriage, Rear, Rh
Terminal Box Crawler Rear
Height Adjustment, Left Side
Height Adjustment, Right Side
Crawler Unit Front
Crawler Unit Front Lh
Crawler Unit Front Rh
Crawler Unit
Advance Drive System 3-Chain
Adv.Drive Sys., Front 3-Chain
Adv.Drive Sys. Rear 3 - Crawler
Adv.Drive Sys., Front 4-Chain
Advance Drive System, Rear
Adv.Drive Sys. Rear 4-Crawler
Switching Sys.
Drive System-Flow Driver
Towing Attachment
Steering, Front Lh
Steering, Front Rh
Steering Rear Lh
Steering Rear Rh
Steering, Rear
Steering, Front
Steering, Rear
Conveyor
Feed Auger
Charging Auger I
Charging Auger II
Drive Unidefeed Auger
Feed Auger Sliding
Transport Support
Charging Conveyor 4,50m
Conveyor Suspension
Conveyor Drive
Conveyor Drive 6m
Conveyor Drive 4, 5m
Charging Conveyor 6m
Conveyor Suspension
Conveyor Suspension Displace
Conveyor Buckle Lean
Conveyor Turning Slewing Shift
Control Unit Emergency Stop
Spreading Auger Basic
Lateral Auger
Auger Extension Rh
Drive Lateral Auger
Lateral Auger Sliding
Levelling Unit
Slab Tracer
Additional Steering Sensor
Control Unit
Wire Tension System
Tension-Cycle
Ancillary Parts
Terminal Box 3d-Control Unit
Water Tank I
Water Tank II
Additional Water Tank
Jet Cleaner
Additional Water Pump
Control Unit
Drive - High Pressure Cleaner
Concrete Mould Suspension
Mould Bracket Double-Sided
Mould Suspension, Rigid
Mould Susp. Height Adjustable
Trough Bracket
Trough Bracket Turnable
Slide Concr.Mould Telescoping
Slipform
Slipform
Slipform, Spring-Tensioned
Slipform Side Offset Hydr.Lh.
Slipform Side Offset Hydr.Rh.
Funnel
Vibrators D66 Strait Electr.
Vibrators D66 Bent Electr.
Vibrators Hydrailical
Drive Vibrator Left
Drive Vibrator Right
Return Lines
Mould Boards 1,00m
Slipform-Mould Rumway Hydr.Lh.
Slipform-Mould Runway Hydr.Rh.
Mould Boards Extension V I
Finisher Blade
Concrete Mould 2, 00m Basic
Slipform Basic
Mould Boards Extension V II
Filter Inserts-Engine
Filter Inserts - Hydraulics
Tools
Oil Diagnostic Set No.3
Keys Set
Service Set - Belt Repair
Hydraulic Instrument Case
Instrument Case-Service Master
Hydraulic Accessories
O-Ring Set
Service Case Electr.
Electrical Service Kit
Service Case I
Service Case II
Service Case III
Service Case IV
Electr. Measuring Tools Case
Vacuum-Pump
