Wirtgen Hamm Roller HD 70 - 75 H1.73 2041696 Spare Parts Catalog
Brand: Wirtgen Hamm
Type of Machine: Roller
Type of Document: Parts Manual
Model: Hamm
HD 70, HD 75, HD 75.4, HD O70V(ASC)
HD O75V(ASC), HD O75K(ASC), HD 75.4K (ASC)
HD 70K (ASC), HD 75K (ASC), HD O75K (ASC)
Date: 2013
Number of Pages: 337 Pages
Main Frame And Assemblies
Canopies And Covers
Sticker Arrangement
Sound-Insulation
Operator Platform
Tilting Hydraulic (Operator Platform)
Operator's Seat With Adjustment
Roll Over Protection
Fops
Handles
Instrument Panel Covering
Operator's Cabin
Cabin-Heating
Pump Drive And Engine Assembly
Fuel System
Engine Control
Air Filter System
Exhaust System
Cooling (Engine Hydraulic Oil)
DrIVing Gear (Variable Displacement Pump - Drive) Not Version Hd 75.4 (Asc)
DrIVing Gear (Variable Displacement Pump - Drive) Version Hd 75.4 (Asc)
DrIVing Gear (Variable Displacement Pump - Vibration Drive)
Constant Motor (Vibration Drive) Not Version Hd O75k (Asc)
Constant Motor (Oscillation Drive) Version Hd O70v(Asc),O75v(Asc),O75k (Asc)
Gear Hub Motor Not Version Hd 75.4 (Asc), Hd 75.4k (Asc)
Gear Hub Motor Version Hd O70v(Asc),O75v(Asc) ,75.4k(Asc)
Gear Hub Motor - Full Shaft (Tires) Version Hd 70k, 75k, O75k Asc, 75.4k Asc
Gear Hub Motor Version Hd 75.4 (Asc), Hd 75. 4k (Asc)
Valve Block (Track Offset)
Control Block (Vibration With Vohido)
Control Block (Single Vibration) Version Hd 70k,75k,O75k(Asc),75.4k (Asc)
Valve Block (Parking Brake)
Filter (Hydraulic Oil)
Filter (Hydraulic Steering System)
Collecting Block (Hydraulic Oil)
Tandem Pump (Steering, Engine Cooling)
Gear Motor (Drive Of Engine Cooling)
Valve Block (Asc)
Oil Tank
Instrument Panel
Electrical System (With Lighting)
Electrical System (Asc) Version Hd O70v (Asc), Hd O75v (Asc)
Electrical System (Asc) Version Hd O75k (Asc)
Electrical System (Asc) Version Hd 75.4 (Asc)
Electrical System (Asc) Version Hd 75.4k (Asc)
Electrical System (Radio)
Tire Equipment Version Hd 70k
Drive With Drum Drive (Smooth Roller Drum) Version H 70, Hd 75
Advance Drive With Drum Drive (Smooth Roller Drum) Version Hd O70v (Asc), Hd O75v (Asc)
Advance Drive (Tires) Version Hd 70k, Hd 75k
Advance Drive (Tires) Version Hd O75k (Asc)
Advance Drive With Drum Drive (DIVided Smooth Roller Drum) Version Hd 75.4 (Asc)
Drive Shifting
Parking Brake Version Hd 70, Hd 75
Parking Brake Version Hd O70v (Asc), Hd O75v (Asc)
Parking Brake Version Hd 70k, Hd 75k
Parking Brake Version Hd O75k (Asc)
Parking Brake Version Hd 75.4 (Asc)
Gear Shifting Version Hd 70, Hd 75
Gear Shifting Version Hd O70v (Asc), Hd O75v (Asc)
Gear Shifting Version Hd 70k, Hd 75k
Gear Shifting Version Hd O75k (Asc)
Gear Shifting Version Hd 75.4 (Asc)
Centre PIVot Assembly
Centre PIVot Assembly All Versions (Asc)
Steering Fork Bearing (Tires) Version Hd 75k, O75k (Asc), 75.4k (Asc)
Steering Fork Bearing (Roller Drum Front) Version Hd 70, 70k, 75, 75k
Steering Fork Bearing (Roller Drum Front) Version Hd O70v
Steering Fork Bearing (Roller Drum Front) Version Hd O75k (Asc)
Steering Fork Bearing (Roller Drum Rear) Version Hd O70v (Asc)
Steering Fork Bearing (Roller Drum Rear) Version Hd O75v (Asc)
Steering Fork Bearing (Roller Drum Rear) Version Hd 75.4 (Asc)
Steering
Steering Column Adjustable
Sprinkling Version Hd 70k,75k,O75k(Asc), 75.4k(Asc)
AdditIVe Sprinkling Version Hd 70k, 75k,O75k(Asc),75.4k(Asc)
Water Filter
Edge Pressing And Cutting Device Version Hd 70, Hd 75, Hd 70k, Hd 75k
Edge Pressing And Cutting Device All Versions (Asc)
Add-On Pieces (Edge Pressing And Cutting Device)
Hydraulic System (Edge Pressing And Cutting Device)
Sprinkling (Edge Pressing And Cutting Device)
Track Indicator
Thermal Scuffle Version Hd 75k
Sun Roof Version With Rops
Sun Roof
Lamp Protection
Additional Lighting, Fops
Vibro Automatic
Rotary Beacon (Driver's Cabin)
Rotary Beacon
Position Indicator
Compactometer, Hcq Version Hd 70, Hd 75, Hd 70k, Hd 75k
Ecomatic Hd 70, 75, O70v, O75v, 75.4
Ecomatic 70k, 75k,O75k,75.4k
Tachograph Version Hd 70, Hd 75, Hd 70k, Hd 75k
Tachograph Version Hd O70v, O75v, O75k, 75.4, 75.4k
Battery Isolating Switch Control
Chip Spreader (Disk Spreader)
Chip Spreader (Cylinder Spreader, Manual)
Add-On Device (Cylinder Spreader)
Hydraulic System (Chip Spreader) Version Hd O70v,O75v,O75k,75.4,75.4k
Hydraulic System (Chip Spreader) Version Hd 70, Hd 75, Hd 70k, Hd 75k
Electrical System (Disk Spreader)
Electrical System (Cylindrical Spreader)
Tüv Italy
Scraper (Smooth Roller Drum) Version Hd 70
Scraper (Tires) Version K
Scraper (Smooth Roller Drum) Version Hd 75
Smooth Roller Drum With Vibrator (With Drum Drive) Version Hd 70, Hd 70k
DIVided Roller Drum With Vibrator Version Hd O70v (Asc)
Smooth Roller Drum With Oscillator Version Hd O70v (Asc)
Smooth Roller Drum With Vibrator (With Drum Drive) Version Hd 75, Hd 75k
DIVided Roller Drum With Vibrator Version Hd O75v(Asc),75.4(Asc),75.4k (Asc)
Vibration Drive Version Hd 70, Hd 75
Vibration Drive (Single Vibration) Version Hd 70k, Hd 75k
Oscillation Drive (Single Oscillation) Version Hd O75k (Asc)
Vibration Drive Version Hd 75.4 (Asc)
Vibration Drive (Single Vibration) Version Hd 75.4k (Asc)
Oscillation Drive (OscilLATION VIBRATION) VERSION HD O70V (ASC), HD O75V (ASC)
