702,169
Wirtgen Cold Milling W 210i 15.20 2199314 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Cold Milling
Type of Document: Parts Manual
Model: Wirtgen W 210i
Date: 2013
Number of Pages: 355 Pages
Lighting Left
Lighting Right
Warnings
Covers Rear
Storage Compartments
Stickers Left I
Stickers Left II
Stickers Right I
Stickers Right II
Stickers Rear
Stickers Operator's Stand I
Stickers Operator's Stand II
Stickers Cabin
Stickers Conveyor
Stickers Left I (USA)
Stickers Left II (USA)
Stickers Right I (USA)
Stickers Right II (USA)
Stickers Rear (USA)
Stickers Operat. Stand I (USA)
Stickers Operat. Stand II (USA)
Stickers Cabin (USA)
Stickers Conveyor (USA)
Additional Weight 1000 Kg
Additional Weight 1700 Kg
Storage Compartment Xxl
Ladder Left
Ladder Right
Platform
Handrail Left
Handrail Right
Mirror
Control Panel Ancillary Parts
Control Panel Covers
Control Panels Left And Right
Control Panel, Center
Machine Display Bracket
Machine Display
Protection Roof
Canopy Front Window
Canopy Rear Window
Canopy Up Down
Heating
Heating System
Operator´S Seat Left
Operator´S Seat Right
Cabin Ladder Left
Cabin Platform
Cabin Suspension
Cab Ancillary Parts
Cabin Operator's Seat
Cabin Armrest Left
Cabin Armrest Right
Cabin Heating
Cabin Air Conditioner
Cabin Moving Unit
Displace Cabin
Incline Displace Cabin
Turn Cabin
Cabin Mounting Plate
Cabin Control Panels
Cabin Terminal Box
Radio Communication Unit
Cabin Handrail
Camera System
Mirror Hydr. Fold-Away
Folding Mirrors
Mill.Drum Housing Fb2000 2200
Milling Drum Housing Fb1500
Drive Milling Drum
Clutch ActIVator
Clutch Covers
Coupling
Flange Bearing
Gearbox I
Gearbox II
Belt Tensioner Unit
Drive Belt Tensioner
Belt-Drive Case
Belt-Drive Case Base Part
Drum Bearing Fb2000 2200
Drum Bearing Fb1500
Scraper Fb2200
Scraper Fb1500
Scraper Raise Lower
Scraper Open Close
Side Plate Fb2000 2200
Side Plate Fb1500
Side Plate Up Down
Depressor
Material Depressor Extension
Drum Fb2000 Ht11 La15
Drum Fb2200 Ht11 La15
Drum Fb1500 Ht11 La15
Drum Fb2000 Ht11 La25
Drum Fb2000 Ht11 La8
Drum Fb2000 Ht5 La6x2
Drum Fb2200 Ht11 La25
Drum Fb2200 Ht11 La8
Drum Fb2200 Ht5 La6x2
Drum Fb1500 Ht11 La25
Drum Fb1500 Ht11 La8
Drum Fb1500 Ht5 La6x2
Fcs-Drum Housing Fb600-1200
Fcs-Drum Bearing Fb600-1200
Fcs-Drum Bearing Fb2000 2200
Fcs-Scraper Fb600-1200
Fcs-Scraper Fb600-1200 Up Down
Fcs-Side Plate Fb600-1200
Fcs-Gear Oil Cool. Fb600-1200
Fcs-Drum Fb2000 Ht11 La15
Fcs-Drum Fb2000 Ht11 La25
Fcs-Drum Fb2000 Ht11 La8
Fcs-Drum Fb2000 Ht5 La6x2
Fcs-Drum Fb2200 Ht11 La15
Fcs-Drum Fb2200 Ht11 La25
Fcs-Drum Fb2200 Ht11 La8
Fcs-Drum Fb2200 Ht5 La6x2
Fcs-Drum Fb1200 Ht11 La15
Fcs-Drum Fb900 Ht11 La15
Fcs-Drum Fb600 Ht11 La15
Drum Turning Jig
Drum Rotating Device ActIVator
Auxiliary Seat
Assembly Aid
Pick Extractor
Engine I Ancillary Parts
Engine II Ancillary Parts
Air Intake
Fuel Supply
Cooling System-Air
Cooling System-Water
Engine Hood
Engine Hood Rear
Soundproofing
Engine Hood Up Down
Cover Bottom
Fcs Covers Bottom Fb1200
Covers Bottom Fb1500-2200
Engine Diagnostic Contr. Panel
Diesel-Fuel Filling Pump
Pump Splitter Gearbox Clutch
Functions - Hydr. Pumps
Cyl.Funct.-Pump Connectors
Cyl.Funct. Valve Blocks Front
Cyl.Funct. Valve Blocks Rear
Hydraulic Aggregat
Return Lines
Hydraulic Oil Tank
Battery Alternator Starter
Auxiliary Starting Aid
Control Unit Bracket
Control Unit
Control Unit Emergency Stop
Electrical Cabinet Anc.Parts
Central Board
Electr.Cab. Micro Controller
Electrical Cabinet Cover
Generator Drive
Cover Generator
Height Adj. Crawlers Front
Height Adjust. -Crawler Rear
Height Adjustment Front
Height Adjustment Rear
Valve Block
Crawler Unit Front
Crawler Unit Rear
Crawler Unit
Pump Connectors
Advance Drive System, Front
Advance Drive System, Rear
Chain Tensioner
Material Guiding (Crawlers)
Steering, Front
Steering, Rear
Steering System Front
Steering System Rear
Primary Conveyor Suspension
Primary Conveyor Ancill.Parts
Primary Conveyor - Side Parts
Prim.Conveyor Material Guiding
Primary Conveyor - Up Down
Discharge Conveyor - Support
Discharge Conveyor Ancill. Pts
Discharge Conveyor Sealings
Discharge Conveyor Chute
Pump Connectors
Conveyor Drive
Discharge Conveyor - Up Down
Discharge Conveyor - Slewing
Folding Conveyor I
Folding Conveyor II
Folding Conveyor Sealings
Folding Conveyor Folding
Vcs Discharge Conveyor
Vcs Ventilator Drive
Conveyor Support
Auto. Grade & Slope Control
Scanner
Sonic-Ski Scanning
Multiplex Unit
Levelling Arm
Levelling Arm Displace
Levelling Arm Terminal Box
Levelling 3d
Levelling 3d Control Unit
Laser Control
Lateral Tilt
Water Tank
Water Pump - Drive
Sprinkling Dr. Unit Fb2000 2200
Sprinkling Mill. Dr.Unit Fb1500
Sprinkling Primary Conveyor
Sprinkling Discharge Conveyor
Water Filling Rear
Water Filling Pump
Water Filling Pump - Drive
Fcs-Sprinkler Drum Fb600-1200
Jet Cleaner
Drive - High Pressure Cleaner
Compressed Air System
Filter Inserts-Engine
Filter Inserts-Hydr. (500h,..)
Filter Inserts-Hydr.(1000h,..)
Tools
Keys Set
Dresser Unit-Movable Bearing
Hydraulic Accessories
O-Ring Set
Oil Diagnostic Set No.3
Hydraulic Instrument Case
Service Master Test Kit
Vacuum-Pump
Emergency Kit
Electrical Service Case
Electr. Measuring Tools Case
Service Set - Belt Repair
