702,800
Wirtgen Cold Milling W 210 13.20 2139900 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Cold Milling
Type of Document: Parts Manual
Model: Wirtgen W 210
Date: 2013
Number of Pages: 372 Pages
Lighting Warning Device
Chassis Ancillary Parts
Ancillary Parts
Storage Compartments
Stickers Left
Stickers Ri I
Stickers Ri II
Stickers Left Right
Stickers Operator's Stand I
Stickers Operator's Stand II
Stickers Cabin
Stickers Rear
Stickers Conveyor
Stickers Left (USA)
Stickers Ri I (USA)
Stickers Ri II (USA)
Stickers Left Rights (USA)
Stickers Operat. Stand I (USA)
Stickers Operat. Stand II (USA)
Stickers Cabin (USA)
Stickers Rear (USA)
Stickers Conveyor (USA)
Additional Weight 1000 Kg
Additional Weight 1400 Kg
Storage Compartment Xxl
Ladder Left
Ladder Right
Platform
Mirror
Control Panel Ancillary Parts
Control Panel Ancill.Parts I
Control Panel Ancill.Parts II
Control Panels Left And Right
Control Panel, Center
Machine Display
Protection Roof
Canopy Rear Window
Canopy Up Down
Umbrella
Mirror Hydr. Fold-Away
Folding Mirrors
Operator´S Seat Left
Operator´S Seat Right
Heating
Camera System
Cabin Platform
Cabin Handrail
Cabin Ladder Left
Displace Cabin
Cabin Moving Unit
Cabin Suspension
Air Conditioning
Cabin Heating
Cab Ancillary Parts
Cabin Control Panels Ri Le
Cabin Mounting Plate
Cabin Operator's Seat
Mill.Drum Housing Fb2000 2200
Milling Drum Housing Fb1500
Drum Bearing Fb2000 2200
Drum Bearing Fb1500
Gearbox
Gearbox I Fb2000 2200
Gearbox II Fb2000 2200
Gearbox I Fb1500
Gearbox II Fb1500
Drive Milling Drum
Clutch ActIVator
Coupling
Belt Tensioner Unit
Belt-Drive Case
Belt-Drive Case Base Part
Scraper Fb2000
Scraper Fb2200
Scraper Fb1500
Scraper Raise Lower
Side Plate Fb2000 2200
Side Plate Fb1500
Side Plate Up Down
Depressor
Drum Fb2000 Ht11 La15
Drum Fb2200 Ht11 La15
Drum Fb1500 Ht11 La15
Drum Fb2000 Ht11 La25
Drum Fb2000 Ht11 La8
Drum Fb2000 Ht5 La6x2
Drum Fb2200 Ht11 La25
Drum Fb2200 Ht11 La8
Drum Fb2200 Ht5 La6x2
Drum Fb1500 Ht11 La25
Drum Fb1500 Ht11 La8
Drum Fb1500 Ht5 La6x2
Fcs-Drum Bearing Fb2000 2200
Fcs-Scraper Fb2000-2200 Up Dow
Fcs-Drum Housing Fb600-1200
Fcs-Drum Bearing Fb600-1200
Fcs-Scraper Fb600-1200
Fcs-Scraper Fb600-1200 Up Down
Fcs-Side Plate Fb600-1200
Fcs-Gear Oil Cool. Fb600-1200
Fcs-Drum Fb2000 Ht11 La15
Fcs-Drum Fb2000 Ht11 La25
Fcs-Drum Fb2000 Ht11 La8
Fcs-Drum Fb2000 Ht5 La6x2
Fcs-Drum Fb2200 Ht11 La15
Fcs-Drum Fb2200 Ht11 La25
Fcs-Drum Fb2200 Ht11 La8
Fcs-Drum Fb2200 Ht5 La6x2
Fcs-Drum Fb1200 Ht11 La15
Fcs-Drum Fb900 Ht11 La15
Fcs-Drum Fb600 Ht11 La15
Assembly Aid
Pick Extractor
Drum Turning Jig
Auxiliary Seat
Engine I Ancillary Parts
Engine II Ancillary Parts
Air Filter
Exhaust System
Turbo-Charge Cooling
Fuel Supply
Bleeding Fuel Filter
Combined Cooler
Fan Drive
Engine Hood
Soundproofing
Engine Hood Up Down
Engine Diagnostic Contr. Panel
Covers Bottom Fb 2000 2200
Covers Bottom Fb 1200 1500
Diesel-Fuel Filling Pump
Pump Splitter Gearbox Clutch
Functions - Hydr. Pumps
Cyl.Funct. Pump Connectors
Cylinder Funct. - Valve Blocks
Service Interface Hydraulic
Hydraulic Aggregat
Return Lines
Hydraulic Oil Tank
Battery Alternator Starter
Electrical Cabinet
Central Board
Electrical Cabinet Cover
Control Unit Left
Control Unit Rh
Control Unit Emergency Stop
Generator Drive
Cover Generator
Height Adjustment-Crawler Unit
Height Adjustment Front
Height Adjustment Rear
Crawler Units
Pump Connectors
Advance Drive System, Front
Advance Drive System, Rear
Chain Tensioner
Material Guiding (Crawlers)
Steering
Steering System Front
Steering System Rear
Drive Primary Conveyor
Primary Conveyor
Primary Conveyor-Convers
Prim.Conveyor Material Guiding
Primary Conveyor - Up Down
Drive Discharge Conveyor
Discharge Conveyor - Support
Discharge Conveyor
Disch.Conv.-Mat. Bin Side Parts
Disch.Conv. Raise-Lower Sleving
Folding Conveyor I
Folding Conveyor II
Fold.Conv.-Mat. Bin Side Parts
Folding The Hydr. Folding Conv.
Vcs Discharge Conveyor
Vcs Ventilator Drive
Conveyor Support
Auto. Grade & Slope Control
Scanner
Scanner
Multiplex Unit
Lateral Tilt
Laser Control Without Transm.
Sonic-Ski Scanning
Levelling 3d
Levelling Arm
Levelling Arm Displace
Terminal Box
Water Tank
Drive - Water Pump
Sprinkling Dr. Unit Fb2000 2200
Sprinkling Mill. Dr.Unit Fb1500
Sprinkling Conveyor Unit
Water Filling Rear
Fcs-Sprinkler Drum Fb600-1200
Hyd. Water Filling Pump
Jet Cleaner
Compressed Air System
Pneumatic Punch
Filter Inserts-Engine(500h,..)
Filter Inserts-Hydr. (500h,..)
Filter Inserts-Hydr.(1000h,..)
Tools
Dresser Unit-Movable Bearing
Oil Diagnostic Set No.3
Keys Set
Service Set - Belt Repair
Hydraulic Instrument Case
Service Master Test Kit
Hydraulic Accessories
O-Ring Set
Electrical Service Kit
Electr. Measuring Tools Case
Emergency Kit
Vacuum-Pump
