702,800
Wirtgen Asphalt Recycler RX 4500 05.RX 194088 Spare Parts Catalog
Brand: Wirtgen
Type of Machine: Asphalt Recycler
Type of Document: Parts Manual
Model: Wirtgen RX 4500
Date: 2013
Number of Pages: 313 Pages
Lights Warning Devices Left
Lights Warning Devices Right
Signs Stickers I
Signs Stickers II
Control Panel Support X3
Control Panel X3
Control Unit X3 I
Control Unit X3 II
Platform
Ancillary Parts Tool Box
Driver's Seat
Umbrella
Suspension Centre
Scarif.Unit Centre Left
Scarif.Unit Centre Right
Scarifier Unit Drive
Suspension Left
Scarifier Unit Left
Scarif.Unit Traverse Left
Scarifier Unit Up Down Left
Suspension Right
Scarifier Unit Right
Scarif.Unit Traverse Right
Scarifier Unit Up Down Right
Spur Gearbox
Engine Ancillary Parts
Engine Station Cover
Engine Station Hood
Engine Hood Open Close
Fuel Supply
Silencer
Air Intake
Combination Cooler (Water)
Combination Cooler (Charge)
Engine Throttle Control
Pump Splitter Gearbox Clutch
Overview Manometers
Hydraulic Oil Tank
Oil Cooler Fan Drive
Cylinder Functions
Cyl.Funct. Valve Blocks I
Cyl.Funct. Valve Blocks II
Scarifier Unit
Advance Drive
Hopper Conveyor
Chassis Conv. Generator Drive
Thermo-Oil Pump
Paving Screed
Tamper
Vibration
Spreader Auger Paving Screed
Spreader Auger Smooth.Screed
Heater Fan Drive
Mixing Unit
Return-Flows Oil Cooler
Return-Flows Hydr. Oil Tank
Electrical Cabinet X1
Mounting Plate
Control Panel Electrical Cab.
Control Panel X2
Electric Cabinet X2
Slewing Arm Control Panel X2
Control Unit X6
Control Unit X7
Control Unit X8
Control Unit X9
Terminal Box X11
Terminal Box X12
Battery Starter Alternator
Generator 22 35 Kva
Generator Drive
Electrical Cabinet Generator
Electric Cabinet X401
Control Unit X401
Front Axle
Rear Axle
Advance Drive Front Rear
Switching System
Planetary Gear
Axle Body
Back Gear Arrangement
Steering, Front
Steering, Rear
Impact Rollers
Hopper
Hopper Tilt Left
Hopper Tilt Right
Hopper Up Down
Hopper Conv Ancillary Parts
Hopper Conv. Ancillary Parts II
Hopper Conv Covers
Hopper Conv Susp Supp Wheel
Hopper Conv Drive
Chassis Conv. -Ancill. Parts I
Chassis Conv. -Ancill. Parts II
Chassis Conv. -Ancill.Parts III
Chassis Conveyor Drive
Proportioning Tank
Levell. Chassis Scarifier Unit
Levelling System Paving Screed
Ultrasonic Scanning
Tank
Bitumen Unit
Binder Pump Drive
Terminal Box
Distributor Box Camber
Gas Regulation Unit
Thermo-Oil Pump
Thermal Oil Pump Drive
Spraying Unit
Compressed Air System
Gas Tank
Paving Screed Trailing Arms
Paving Screed Compl. Up Down
Paving Screed Up Down Left
Paving Screed Up Down Right
Paving Screed Spreader Auger
Pav.Screed Spr. Auger Suspens.
Pav.Screed Spr. Auger Up Down
Pav.Screed Spr. Auger Drive I
Pav.Screed Spr. Auger Drive II
Control Unit Support X4 X5
Control Unit X4
Control Unit X5
Terminal Box Paving Screed
Smooth.Scr.Susp. Ancill.Parts
Smooth.Scr. Ancill. Wear.Parts
Smoothing Screed Front Shields
Smoothing Screed Up Down Left
Smoothing Screed Up Down Right
Smooth.Screed Traverse Left
Smooth.Screed Traverse Right
Smooth. Screed Spreader Auger
Sm.Screed Spr. Auger Drive I
Sm.Screed Spr. Auger Drive II
Smooth.Screed Tamper Left Ext.
Smooth.Screed Tamper Right Ext
Smoothing Screed Tamper Left
Smoothing Screed Tamper Right
Smooth.Screed Tamper Lubric.
Smoothing Screed Drive I
Smoothing Screed Drive II
VII Smoothing Screed Left
VII Smoothing Screed Right
Smoothing Screed
Smoothing Screed Centre Le.
Smoothing Screed Centre Ri.
Smooth.Screed Traverse Le Ri.
Smoothing Screed Vibration
Vibration Drive
Vibration Left
Vibration Right
Smoothing Screed Electr.System
Gas Tank
Pipework (Vaporizer)
Vaporizer Ancill. Parts
Vaporizer
Ctrl Unit Vaporizer
Gas Regulation Station
Overview Heater Banks
I Left
I Right
I Heaters Left
I Heaters Rechts
II Infra-Red Heater
III Central Frame
III Inner Frame Left
III Inner Frame Right
III Outer Frame
III Pilot Flames
III Heaters Central Frame
III Heaters Mounting Frames
III Heater Fan Drive
III Mount.Frames Ancill.Parts
III Folding Mounting Frame
IV Up Down
IV Suspension
IV Central Frame
IV Outer Frame Left
IV Outer Frame Right
IV Pilot Flames
IV Heaters Central Frame
IV Heaters Mounting Frames
IV Heater Fan Drive
IV Mount.Frames Ancill.Parts
IV Folding Mounting Frame
V Left
V Right
V Heaters Left
V Heaters Rechts
Vi Burner
VIII Lance
Infra-Red Heater
Mixing Unit Drive I
Mixing Unit Drive II
Mixing Unit Housing
Mixing Unit Inner Casing
Mixing Unit Shaft + Bearing
Mixing Unit Flap
Mixing Unit Flaps
Mixing Unit Flaps Open Closed
Spur Differential
Filter Inserts-Engine
Filter Inserts-Hydraulics
Tools
Oil Diagnostic Set No.3
Keys Set
Hydraulic Instrument Case
Instrument Case-Service Master
Hydraulic Accessories
O-Ring Set
Service Case Electr.
Service Case I
Service Case II
Service Case III
Service Case IV
Electr. Measuring Tools Case
Vacuum-Pump
