Willmar Wrangler Loader 4560 Parts Catalog 532096D1
Brand: Willmar
Type of Machine: Wrangler Loader
Model: Willmar 4560 Wrangler Loader
Part Number: 532096D1
Number of Pages: 2173 Pages
Publication Information
Glowplug Heater
Kit-Glowplug Control,Sealed
Engine Group-4560
Engine Mounting Hardware
Accessory Bracket
Fuel
Exhaust
Intake Group
Air Cleaner
Engine Sub Assembly-Deutz, 83 Hp, T3
Engine-Deutz,83 Hp, T3
Dipstick Assembly
Filler Cap Assembly
Manifold Assembly Exhaust
Pulley V-Grooved Assembly
Flywheel Assembly
Crankshaft Accessories Assembly
Protection Hood Fastenings Assembly
Bracket Rocker Arm Assembly
Filter Oil Assembly
Plug Screw Assembly
Line Fuel Assembly
Parts Blanking Assembly
Rod Control Assembly
Solenoid Assembly
Fan Support Fastenings Assembly
Support Fan Assembly
Flange Companion Assembly
Turbocharger Assembly
Baffle Cooling Air Assembly
Pipe Connecting Assembly
Plate Cover Assembly
Fuel Injection Pump
Fuel Injection Pump Fastenings
Protection Hood Assembly
Dipstick Guide Assembly
Cover Rear End Assembly
Breather Crankcase Assembly
Engine Block Assembly
Oil Pan Assembly
Crankshaft Assembly
V Groove Pully Assembly
Rod Connecting Assembly
Piston Assembly
Head Gasket Fastenings
Cylinder Head Assembly
Cover Valve Mechanism
Camshaft Drive Assembly
Camshaft Assembly
Oil Pump Lubrication
Oil Filter Assembly
Pilot Line
Valve Pressure Relief
Oil Suction Line
Oil Return Line
Oil Line Lubricating
Fuel Injector
Filter Cartridge
Boost Control Fastenings
Boost Control
Fuel Supply Pump
Pump Fuel Supply
Fuel Line
High Pressure Pipe
Hose Assembly
Turbocharger Accessories
Pipe Charge Air
Cover-Front Governer
Spring Torque Contr
Adapter Torque
Thermostat Install
Water Jacket Accessories
Blanking Parts
Water Pump Bracket Fastenings
Pipe Clamp Fastenings
Line Cooling Water
Fan Blade Fastenings
V-Belt Narrow
Pulley Tensioning
Generator
Starter
Bracket
Mounting Generator
Connector Plug-In
Tachometer-Generator
Temperature Transmitter
Housing Adapter
Device Shutdown
Lines Expansion Group-Coolant
Fan Group
Cooling Group
Throttle Cable Installation
Kit-Motor Mount,Muffler Hanger 2011
Kit-Wrangler Muffler Hanger
Engine-Deutz, 83 Hp, T3
Fuel Group
Frame And Suspension
Frame -Wrangler
Chassis-Front,Wrangler
Tilt Link Assembly
Tilt Arm Assembly
Lift Arm Assembly
Coupler-Universal,Assembly
Chassis-Rear,Wrangler
Hood Assembly-Loader,No Scoop
Chassis-Articulation Joint
Link Assembly-Articulation,W Taper
Wheel Assembly-Steering,14 In.- R B 534619d1
Wheel-Steering
Steering Column-Mod,6 In
Motor-Steering, 14.1 Cir
Valve Assembly-Park Brake,Hydraulic
Valve Assembly-Hydraulic Park Brake
Adapter Straight 0.37mo-R X 0.37mjic
Hydraulic Group
Hydraulic Install-Component
Tilt Cylinder-Hydraulic,3.50x21.75x2.00
Lift Cylinder-Hydraulic,3.50x23.50x2.00
Adapter Assembly,-12morb X -12mjic
Adapter Straight 0.50mo-R X 0.50 Mjic
Hydraulic Install-Pumps
Pump Assembly-Drive And Implement
Pump-Gear,1.69,Primary Flow Divider
Pump-Hydraulic,71cc
4 3-Way Directional Valve
Filter Kit-Service
Relief Valve-Charge
Charge Pump Kit
Adapter Straight -10mbx12mj
Adapter Straight 0.75mo-R X 1.00mjic
Adapter Straight -4mbx-4mj
Pump Drive Assembly-Loader
Coupling Assembly- Pump Drive
Elbow 90d 0.25mo-R X 0.25mjic
Hydraulic Install-Drive
Valve-Check,Modified,-08fj
Motor-Hydraulic,Fixed 2.48 Cubic Inch
Tee Assembly-Run -16 Orfs Swivel
Elbow Assembly-45d-16orfs Run
Adapter Assembly,-16 Forfs X -8 Morb
Hub-Power Wheel,19.62
Kit-Seal,Mdl 6
Hub-Power Wheel,19.62 W Ci Cov
Tee Assembly-16 Orfs X 16 Stor
Hydraulic Install-Tank
Tank Assembly-Hydraulic
Filter-Filler Breather
Filter-Tank,Top Return
Adapter Straight 1.00mo-R X 0.75mjic
Hose Kit-Drive
Hose Kit-Component
Valve Install
Valve Assembly,3 Spool
Valve Control,3 Spool
Handle Assembly
Elbow 90d 0.62mo-R X 0.75mjic
Elbow 90d -12mjic X -12mstor
Adapter Straight 0.62mo-R X 0.50mjic
Adapter Straight 0.50mo-R X 0.75mjic
Adapter Assembly,-16morb X -16mjic
Cylinder-Hydraulic,3.00x11.50x1.25
Pedal-Foot,Hydraulic,Rexroth
Adapter -16,Orfs Fl90
Tube And Hose Assembly
Valve,Implement W Auxillary Circuit
Valve,Implement W O Auxillary Circuit
Light-Turn Flasher,Amber
Light-Tail,Red
Lamp-Warning,Amber
Work Light
Electric Group (4500)
Light Assembly-Dome
Install-Harness, Engine
Harness Install-Cab
Option-Cab Assembly,Open
Subassembly-Rops
Suspension Assembly-Seat
Shifter-Fnr W Horn
Ignition Switch Loader
Option-Cab Assembly,Enclosed
Cab Assembly-Enclosed
Window Assembly-Rear
Window Assembly-Lh
Window Assembly-Rh
Panel Assembly-Lh
Panel Assembly-Rh
Door Assembly-Cab
Group-Parts, Cab Install
Window Assembly-Front
Motor Rework
Skylight Assembly-Cab
Heater Assembly-Cab
Parts Bag
Vent Assembly
Heater Assembly Wrangler
Engine Rework-Heater
Option-Glass
F A-Glass
F A-Mirror, Interior
Option-Mirror, Interior
1035 Chassis
1037 Decals
Decal Install, 4560
1042 Wheels
Option-Tire,31x15.5-8 Ply,Calcium
Tire Rim Assembly-31x15.5,Calcium,Lh
Tire Rim Assembly-31x15.5,Calcium,Rh
Option-Tire,31x15.5-8 Ply,Urethane
Tire Rim Assembly-31x15.5,Urethane,Lh
Tire Rim Assembly-31x15.5,Urethane,Rh
Option-Tire,30.5x12.5-8 Ply,Calcium
Tire Rim Assembly-30.5x12.5,Calcium,Lh
Tire Rim Assembly-30.5x12.5,Calcium,Rh
F A-Tire,31x15.5-8 Ply,Urethane
F A-Tire,30.5x12.5-8 Ply,Calcium
1064 Attachments
Option-Pallet Fork
Pallet Fork
Option-Bucket,20cf,General Purpose,74 Inch
Option-Bucket,30cf,Lite Material,63 Inch
Option-Bucket,36cf,Lite Material,74 Inch
Option-Bucket,45cf,Lite Material,84 Inch
F A-Bucket,20cf,General Purpose,74 Inch
F A-Bucket,30cf,Lite Material,63 Inch
F A-Bucket,36cf,Lite Material,74 Inch
F A-Bucket,45cf,Lite Material,84 Inch
F A-Pallet Fork
F A-Cutting Edge 63 Inch
F A-Cutting Edge 74 Inch
F A-Cutting Edge 84 Inch
F A-Cab Upgrade
1087 Accessories
Kit-Deutz Oil Filter (50 Hour)
Brand: Willmar
Glowplug Heater
Engine Group-4560
Accessory Bracket
Fuel
Exhaust
Intake Group
Air Cleaner
Dipstick Assembly
Filler Cap Assembly
Flywheel Assembly
Filter Oil Assembly
Plug Screw Assembly
Line Fuel Assembly
Solenoid Assembly
Fuel Injection Pump
Oil Pan Assembly
Crankshaft Assembly
Piston Assembly
Camshaft Assembly
Oil Filter Assembly
Pilot Line
Oil Suction Line
Oil Return Line
Fuel Injector
Filter Cartridge
Boost Control
Fuel Supply Pump
Pump Fuel Supply
Fuel Line
High Pressure Pipe
Hose Assembly
Pipe Charge Air
Spring Torque Contr
Adapter Torque
Thermostat Install
Blanking Parts
Line Cooling Water
V-Belt Narrow
Pulley Tensioning
Generator
Starter
Bracket
Mounting Generator
Connector Plug-In
Housing Adapter
Device Shutdown
Fan Group
Cooling Group
Fuel Group
Frame -Wrangler
Tilt Link Assembly
Tilt Arm Assembly
Lift Arm Assembly
Wheel-Steering
Hydraulic Group
Pump-Hydraulic,71cc
Filter Kit-Service
Relief Valve-Charge
Charge Pump Kit
Kit-Seal,Mdl 6
Hose Kit-Drive
Hose Kit-Component
Valve Install
Handle Assembly
Light-Tail,Red
Lamp-Warning,Amber
Work Light
Light Assembly-Dome
Harness Install-Cab
Subassembly-Rops
Shifter-Fnr W Horn
Window Assembly-Lh
Window Assembly-Rh
Panel Assembly-Lh
Panel Assembly-Rh
Door Assembly-Cab
Motor Rework
Heater Assembly-Cab
Parts Bag
Vent Assembly
Option-Glass
F A-Glass
1035 Chassis
1037 Decals
Decal Install, 4560
1042 Wheels
1064 Attachments
Option-Pallet Fork
Pallet Fork
F A-Pallet Fork
F A-Cab Upgrade
1087 Accessories
- Willmar NA 4565 WILLMAR WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA Applicators S150-SS800 WILLMAR SPREADER REPAIR TIME SCHEDULE
- Willmar NA 4560 WILLMAR WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA Material Handling 4565 ARTICULATED LOADER SERVICE MANUAL
- Willmar NA Applicators 8500 EAGLE LIQUID SPRAYER REPAIR TIME SCHEDULE
- Willmar NA Material Handling 4560 ARTICULATED LOADER SERVICE MANUAL
- Willmar NA Material Handling 4550 WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA 1600,16T,24T WILLMAR TENDER REPAIR TIME SCHEDULE
- Willmar Applicators Parts Documents AG333083
- Willmar Liquid Sprayer Air Ride 745 Parts Catalog WRP0378
- Willmar Liquid Sprayer Air Ride 765 Parts Catalog WRP0379
- Willmar Liquid Sprayer Air Ride 765HT Parts Catalog WRP0373
- Willmar Liquid Sprayer Chassis Eagle 8650 Parts Catalog WR125235
- Willmar Liquid Sprayer Chassis Eagle 8650 Parts Catalog WR128688
- Willmar Liquid Sprayer Eagle 8100 Parts Catalog WRP0401
