Willmar Wrangler Loader 4550 Parts Catalog WR134906
Brand: Willmar
Type of Machine: Wrangler Loader
Model: Willmar 4550 Wrangler Loader
Part Number: WR134906
Number of Pages: 1060 Pages
Publication Information
Engine Group
Air Cleaner-Dry Type
Flange Assembly-Exhaust
Engine Group-Loader,Tier 2
Engine Subassembly-Deutz,T2,83hp,Tpem
Engine-Deutz T2,83hp,T2
Dipstick Assembly
Guide Dipstick Assembly
Breather Crankcase Assembly
Block Engine Assembly
Pan Oil Assembly
Power Take-Off Assembly
Pulley V-Grooved Assembly
Crankshaft Assembly
Flywheel Assembly
Accessories Assembly
Rod Connecting Assembly
Piston Assembly
Cap Filler Assembly
Cover Valve Assembly
Head Cylinder Assembly
Fastenings Assembly
Drive Camshaft Assembly
Camshaft Assembly
Bracket Rocker Arm Assembly
Drive Valve Assembly
Pump Oil Assembly
Filter Oil Assembly
Bracket Assembly
Line Pilot Assembly
Line Oil Suction Assembly
Connection Assembly
Connection Radiator Assembly
Pipe Oil Return Assembly
Line Lubrication Oil Assembly
Plug Screw Assembly
Injection Fuel Assembly
Cartridge Filter Assembly
Pump Fuel Supply Assembly
Line Fuel Assembly
Pipe High Pressure Assembly
Filter Fuel Assembly
Parts Blanking Assembly
Plug Glow Assembly
Rod Control Assembly
Adapter Torque Assembly
Cover Governer Front Assembly
Spring Torque Control Assembly
Solenoid Assembly
Belt Narrow V- Assembly
Support Fan Assembly
Flange Companion Assembly
Manifold Exhaust Assembly
Turbocharger Assembly
Generator Assembly
Baffle Cooling Air Assembly
Starter Assembly
Unit Control Assembly
Pipe Connecting Assembly
Plate Cover Assembly
Housing Adapter Assembly
Device Shutdown Assembly
Gasket Set Assembly
Pump Assembly-Drive
Kit-Charge Filter,R B 544340d1
Relief Valve-Charge
Charge Pump Kit
4 3-Way Directional Valve
Pump-Gear,1.54,Pri Fl Div
Bypass Valve
Pump Drive Assembly-Loader
Coupling Assembly- Pump Drive
4550
Protection Hood Assembly
Pump Fuel Supply
Fuel Supply Pump
Axle And Steering Group
Articulation Joint Group
Upper Link W Grease Fittings
Link Assembly-Articulation,W Taper
Frame And Suspension Group
Hood-Assembly, 4500 Wrangler
Frame Group-Front,Wrangler
Tilt Link Assembly
Tilt Arm Assembly
Coupler-Universal Quick Assembly
Link Assembly-Articulation,Upper
Kit-Hood,Wrangler 4300
Lift Arm Assembly
Loader-Articulation Group
Fuel System Group
Fuel Tank Group-Loader,Tier 2
Hydraulic Group
Hydraulic Group-Wrangler
Cylinder-Hydraulic,3.50x21.75x2.00
Cylinder-Hydraulic,3.00x11.50x1.25
Cylinder-Hydraulic,3.50x23.50x2.00
Cooler Assembly-Hydraulic Oil And Engine Cooling
Hydrostat
Kit-Charge Filter
Valve-Relief, 1500 Psi
Tank Group-Hydraulic,Wrangler
Tank Assembly-Oil
Tank Wldmt-Oil
Filter-Filler Breather,(6in W Dipstick)
Filter-Tank,Top Return
Valve-Check,Mod,-08fj
Valve Assembly-Park Brake,Hyd
Valve-Solenoid
Clamp Assembly-Tube,0.75 Dia
Valve Control, 3 Spool
Valve Control,3 Spool
Drive Group-Wrangler,4500
Hub-Power Wheel 21.74
Pedal-Foot,Hydraulic,Rexroth, (Proportional)
Hub-Power Wheel 21.74 W
Pallet Fork
Kit-Power Wheel,In Shaft And
Cab Group
Station Assembly-Operator,Enclosed
Ignition Switch Loader
Light-Turn Flasher,Amber
Light-Tail,Red
Joystick Assembly-3 Spool
Steering Column-Mod,6in
Shifter-Fnr W Horn
Skylight Assembly-Cab
Window Assembly-Rear
Window Assembly-Rh
Window Assembly-Front
Motor Rework
Window Assembly-Lh
Panel Assembly-Rh
Light Assembly-Dome
Door Assembly-Cab
Panel Assembly-Lh
Group-Parts,Cab Install
F A-Cab Upgrade
Heater Assembly-Cab
Hardware Parts Bag,Cab Heater
Rops Assembly-4 Post
Rops Subassembly
Electric Group
Electric Group,Wrangler
Light-Head W Rubber Bezel
Tire And Wheel Group
Tire Assembly-31x15.50-8 Ply
Tire Assembly-31x155-8p,15 X
Tire Assembly-31x15.50,8 Ply,
Tire Assembly-30.5x12.5x
Tire Assembly-Liquid Filled,Rh
Tire Assembly-31x15.50,8 Ply,Ure,Rh
Tire Assembly-31x15.50-8 Ply,Cac,Rh
Decal Group
Decal Group-Wrangler 4550
Options Group
Option-Cutting Edge,84 Inch
F A-Bucket,20 Cubic Foot General Purpose
F A-Bucket 36 Cubic Foot Light Material
F A-Bucket 45 Cubic Foot Light Material
F A-Cutting Edge,63 Inch
F A-Cutting Edge,74 Inch
F A-Cutting Edge,84 Inch
Station Assembly-Operator,Open
Option-Bucket,20 Cubic Foot General Purpose
Option-Bucket,30 Cubic Foot Light Material
Option-Bucket,36 Cubic Foot Light Material
Option-Bucket,45 Cubic Foot Light Material
Pallet Fork Assembly
Option-Cutting Edge, 63 Inch
Option-Cutting Edge,74 Inch
Kit-Glowplug Heater
Kit-Glowplug Control,Sealed
F A-Bucket,30 Cubic Foot Light Material
