Willmar Wrangler Loader 4550 Parts Catalog 507322D1
Brand: Willmar
Type of Machine: Wrangler Loader
Model: Willmar 4550 Wrangler Loader
Part Number: 507322D1
Number of Pages: 1365 Pages
Publication Information
Air Cleaner-Dry Type
Flange Assembly-Exhaust
Engine Group-Loader,Tier 2
Engine Subassembly-Deutz,T2,83hp,Tpem
Engine-Deutz T2,83hp,T2
Dipstick Assembly
Guide Dipstick Assembly
Breather Crankcase Assembly
Block Engine Assembly
Pan Oil Assembly
Power Take-Off Assembly
Pulley V-Grooved Assembly
Crankshaft Assembly
Flywheel Assembly
Crankshaft Accessories Assembly
Rod Connecting Assembly
Piston Assembly
Cap Filler Assembly
Cover Valve Assembly
Head Cylinder Assembly
Head Gasket Fastenings Assembly
Protection Hood Fastenings Assembly
Drive Camshaft Assembly
Camshaft Assembly
Bracket Rocker Arm Assembly
Drive Valve Assembly
Pump Oil Assembly
Filter Oil Assembly
Bracket Assembly
Line Pilot Assembly
Line Oil Suction Assembly
Connection Assembly
Connection Radiator Assembly
Pipe Oil Return Assembly
Line Lubrication Oil Assembly
Plug Screw Assembly
Injection Fuel Assembly
Cartridge Filter Assembly
Pump Fuel Supply Assembly
Line Fuel Assembly
Pipe High Pressure Assembly
Filter Fuel Assembly
Parts Blanking Assembly
Plug Glow Assembly
Rod Control Assembly
Adapter Torque Assembly
Cover Governer Front Assembly
Spring Torque Control Assembly
Solenoid Assembly
Fastenings Assembly
Fan Support Fastenings Assembly
Belt Narrow V- Assembly
Support Fan Assembly
Flange Companion Assembly
Manifold Exhaust Assembly
Turbocharger Assembly
Generator Assembly
Baffle Cooling Air Assembly
Starter Assembly
Pulley Fastenings Assembly
Unit Control Assembly
Pipe Connecting Assembly
Plate Cover Assembly
Housing Adapter Assembly
Device Shutdown Assembly
Gasket Set Assembly
Fuel Injection Pump
Pump Assembly-Drive
Kit-Charge Filter,R B 544340d1
Relief Valve-Charge
Charge Pump Kit
4 3-Way Directional Valve
Pump-Gear,1.54
Bypass Valve
Pump Drive Assembly-Loader
Coupling Assembly- Pump Drive
Adapter Straight -10mbx12mj
Engine Harness
Protection Hood Assembly
Pump Fuel Supply
Fuel Supply Pump
Fuel Group-Loader,Tier 2
Frame And Suspension
Hood-Assembly-Loader,App Yellow
Frame-Front
Tilt Link Assembly
Tilt Arm Assembly
Coupler-Universal Quick Assembly
Link Assembly-Articulation,Upper
Lift Arm Assembly
Upper Link W Grease Fittings
Link Assembly-Articulation,W Taper
Frame Group-Rear,Loader,Challenger Yellow
Rops Assembly-4 Post
Rops Assembly
Assembly-Rops
Wheel Assembly-Steering,14 In- R B 534619d1
Wheel-Steering
Steering Column-Mod,6in
Articulation Joint Group
Valve Assembly-Park Brake
Valve-Solenoid
Hydraulic Group-Wrangler
Tilt Cylinder-Hydraulic,3.50x21.75x2.00
Cylinder-Hydraulic,3.00x11.50x1.25
Lift Cylinder-Hydraulic,3.50x23.50x2.00
Cooler Assembly-Hydraulic Oil And Engine Cool
Elbow 90d -12mjic X -12mstor
Adapter Straight 0.50mo-R X 0.50 Mjic
Elbow 90d 0.25mo-R X 0.25mjic
Adapter Straight 0.50mo-R X 0.75mjic
Hydrostat
Kit-Charge Filter
Valve-Relief, 1500 Psi
Tank Group-Hydraulic
Tank Assembly-Oil
Filter-Filler Breather
Filter-Tank,Top Return
Valve-Check,Mod,-08fj
Motor-Hydraulic,Fixed 2.48 Cuin
Clamp Assembly-Tube,0.75 Diameter
Valve Control, 3 Spool
Valve Control,3 Spool
Drive Group
Hub-Power Wheel 21.74
Kit-Power Wheel,In Shaft
Pedal-Foot,Hydraulic,Rexroth
Motor-Steering,14.1cir
Valve Install
Valve Assembly,3 Spool
Elbow 90d 0.62mo-R X 0.75mjic
Adapter Straight 0.62mo-R X 0.50mjic
Light-Turn Flasher,Amber
Light-Tail,Red
Electric Group,Wrangler
Light-Head W Rubber Bezel
Lamp-Warning,Amber
Light Assembly-Dome
Kit-Glowplug Heater
Kit-Glowplug Control,Sealed
Station Assembly-Operator,Enclosed
Ignition Switch Loader
Joystick Assembly-3 Spool
Shifter-Fnr W Horn
Station Assembly-Operator,Open
Skylight Assembly-Cab
Window Assembly-Rear
Window Assembly-Rh
Window Assembly-Front
Motor Rework
Window Assembly-Lh
Panel Assembly-Rh
Door Assembly-Cab
Panel Assembly-Lh
Parts,Cab Install
F A-Cab Upgrade
Heater Assembly-Cab
Hardware Parts Bag,Cab Heater
Cab Assembly-Operator,Enclosed
Cab Assembly-Enclosed
Cab Assembly-Operator,Open
Kit-Field,Valve Replacement
Kit-,Boot And Cover Plate
Kit-Hood
Decal Group
Tire Assembly-31x15.50-8 Ply
Tire Assembly-31x155-8p,15
Tire Assembly-31x15.50,8 Ply
Tire Assembly-30.5x12.5
Tire Assembly-Liquid Filled,Rh
Tire Assembly-31x15.50,8ply,Ure,Rh
Tire Assembly-31x15.50-8ply,Cac,Rh
Option-Cutting Edge,84 Inch
F A-Bucket,20 Cubic Foot General Purpose
F A-Bucket 36 Cubic Foot Light Material
F A-Bucket 45 Cubic Foot Light Material
F A-Cutting Edge,63 Inch
F A-Cutting Edge,74 Inch
F A-Cutting Edge,84 Inch
Option-Bucket,20 Cubic Foot General Purpose
Option-Bucket,30 Cubic Foot Light Material
Option-Bucket,36 Cubic Foot Light Material
Option-Bucket,45 Cubic Foot Light Material
Pallet Fork Assembly
Pallet Fork
Option-Cutting Edge, 63 Inch
Option-Cutting Edge,74 Inch
F A-Bucket,30 Cubic Foot Light Material
