Willmar Wrangler Loader 4500 Parts Catalog WRP0407
Brand: Willmar
Type of Machine: Wrangler Loader
Model: Willmar 4500 Wrangler Loader
Part Number: WRP0407
Number of Pages: 625 Pages
Publication Information
Engine Group
Air Cleaner-Dry Type
Flange Assembly-Exhaust
Engine Group-Wrangler
Pump Assembly-Drive
Hydrostat
Kit-Filter, Charge
Relief Valve-Charge
Charge Pump Kit
Pump-Gear,1.54,Pri Fl Div
Bypass Valve
Pump Drive Assembly-Loader
Coupling Assembly- Pump Drive
Engine Harness Group-45 7500
Heater-Oil Pan Assembly
Cover-Rear End Install
Crankcase Assembly
Dipstick Assembly
Dipstick Guide Assembly
Crankcase Breather Install
Oil Pan Assembly
Pto Install
Crankshaft Access Install
Pulley Assembly
Flywheel Assembly
Crankshaft Assembly
Connecting Rod Assembly
Piston Assembly
Filler Cap Install
Valve Cover Assembly
Fastenings Assembly
Cylinder Head Assembly
Camshaft Drive Install
Hood Protection Assembly
Camshaft Assembly
Rocker Arm Bracket Assembly
Valve Drive Assembly
Oil Pump Install
Oil Filter Install
Oil Filter Bracket Install
Oil Suction Line Install
Heater Connection Install
Radiator Connecton Install
Oil Return Pipe Install
Oil Line Install
Plug Install
Tappet Assembly
Fuel Injection Pump Install
Fuel Injector Install
Filter Cartridge
Fuel Pump Install
Pump Fuel Supply
Fuel Supply Pump
Bracket Install
Overflow Line Assembly
Fuel Line Assembly
Fuel Line Install
High Pressure Pipe Install
Blanking Parts Install
Charge Air Pipe Assembly
Torque Adapter Install
Control Rod Install
Torque Control Spring Install
Front Cover Governer Assembly
Fastenings Install
Narrow V-Belt
Fan Support Assembly
Exhaust Manifold Install
Turbocharger
Alternator Assembly
Alternator Bracket Assembly
Alternator Fastenings
Starter Cooling Air Baffle Assembly
Starter Assembly
Cover Plate Assembly
Adapter Housing Assembly
Shutdown Device Install
Gasket Set Supplemental
Gasket Set
Glow Plug Assembly
Kit-Engine Conversion
Axle And Steering Group
Articulation Joint Group
Upper Link W Grease Fittings
Link Assembly-Articulation,W Taper
Hdwe Install-Articulation Joint
Frame And Suspension Group
Hood-Assembly, 4500 Wrangler
Frame Group-Front,Wrangler
Tilt Link Assembly
Tilt Arm Assembly
Coupler-Univ Quick Assembly
Link Assembly-Articulation,Upper
Kit-Hood,Wrangler 4300
Lift Arm Assembly
Loader-Articulation Group
Fuel System Group
Tank Group-Fuel,Wrangler
Hydraulic Group
Cylinder-Hydraulic,3.50x21.75x2.00
Cylinder-Hydraulic,3.00x11.50x1.25
Cylinder-Hydraulic,3.50x23.50x2.00
Cooler Assembly-Hydraulic Oil And Engine Cool
4 3-Way Directional Valve
Pump-Hydraulic,Rexroth R B 127995
Kit-Charge Filter
Valve-Relief, 1500 Psi
Tank Group-Hydraulic,Wrangler
Tank Assembly-Oil
Tank Weldment-Oil
Filter-Filler Breather,(6in W Dipstick )
Filter-Tank,Top Return
Valve-Check,Mod,-08fj
Valve Assembly-Park Brake,Hydraulic
Valve-Solenoid
Clamp Assembly-Tube,0.75 Diameter
Valve Control, 3 Spool
Valve Control,3 Spool
Drive Group-Wrangler,4500
Hub-Power Wheel 21.74 W
Pedal-Foot,Hydraulic,Rexroth, (Proportional)
Kit-Power Wheel,In Shaft And
Pump Drive Assembly-Deutz
Pump-Hydraulic,Rexroth,4.33 Cir
Cab Group
Station Assembly-Operator,Enclosed
Ignition Switch Loader
Light-Turn Flasher,Amber
Light-Tail,Red
Joystick Assembly-3 Spool
Steering Column-Mod,6in
Shifter-Fnr W Horn
Motor-Steering,14.1cir(Dynamic Load Snse,C L)
Station Assembly-Operator,Open
Rops Assembly-4 Post
Rops Subassembly
Skylight Assembly-Cab
Window Assembly-Rear
Window Assembly-Rh
Window Assembly-Front
Motor Rework
Window Assembly-Lh
Panel Assembly-Rh
Light Assembly-Dome
Door Assembly-Cab
Panel Assembly-Lh
Group-Parts,Cab Install
F A-Cab Upgrade
Heater Assembly-Cab
Hardware Parts Bag,Cab Heater
Electric Group
Electric Group,Wrangler
Light-Head W Rubber Bezel
Tire And Wheel Group
Tire Assembly-31x15.50-8 Ply
Tire Assembly-31x155-8p,15 X
Tire Assembly-31x15.50,8 Ply,
Tire Rim Assembly-31x15.5,Ureth,Lh
Tire Assembly-30.5x12.5x
Decal Group
Decal Group-Wrangler 4500
Options Group
Option-Cutting Edge,84 Inch
F A-Bucket,20 Cubic Foot General Purpose
F A-Bucket 36 Cubic Foot Light Material
F A-Bucket 45 Cubic Foot Light Material
F A-Cutting Edge,63 Inch
F A-Cutting Edge,74 Inch
F A-Cutting Edge,84 Inch
Option-Bucket,20 Cubic Foot General Purpose
Option-Bucket,30 Cubic Foot Light Material
Option-Bucket,36 Cubic Foot Light Material
Option-Bucket,45 Cubic Foot Light Material
Pallet Fork Assembly
Pallet Fork
Option-Cutting Edge,63 Inch
Option-Cutting Edge,74 Inch
Kit-Glowplug Heater
F A-Bucket,30 Cubic Foot Light Material
Option-Tooth Bar,74 Inch
Tooth Bar Assembly,74 Inch
Instruction-Tooth Bar Assembly,4500
Brand: Willmar
Engine Group
Pump Assembly-Drive
Hydrostat
Kit-Filter, Charge
Relief Valve-Charge
Charge Pump Kit
Bypass Valve
Crankcase Assembly
Dipstick Assembly
Oil Pan Assembly
Pto Install
Pulley Assembly
Flywheel Assembly
Crankshaft Assembly
Piston Assembly
Filler Cap Install
Fastenings Assembly
Camshaft Assembly
Oil Pump Install
Oil Filter Install
Oil Line Install
Plug Install
Tappet Assembly
Filter Cartridge
Fuel Pump Install
Pump Fuel Supply
Fuel Supply Pump
Bracket Install
Fuel Line Assembly
Fuel Line Install
Control Rod Install
Fastenings Install
Narrow V-Belt
Turbocharger
Alternator Assembly
Starter Assembly
Gasket Set
Glow Plug Assembly
Tilt Link Assembly
Tilt Arm Assembly
Lift Arm Assembly
Fuel System Group
Hydraulic Group
Kit-Charge Filter
Tank Assembly-Oil
Tank Weldment-Oil
Valve-Solenoid
Cab Group
Light-Tail,Red
Shifter-Fnr W Horn
Rops Subassembly
Window Assembly-Rh
Motor Rework
Window Assembly-Lh
Panel Assembly-Rh
Light Assembly-Dome
Door Assembly-Cab
Panel Assembly-Lh
F A-Cab Upgrade
Heater Assembly-Cab
Electric Group
Decal Group
Options Group
Pallet Fork
Kit-Glowplug Heater
- Willmar NA 4565 WILLMAR WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA Applicators S150-SS800 WILLMAR SPREADER REPAIR TIME SCHEDULE
- Willmar NA 4560 WILLMAR WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA Material Handling 4565 ARTICULATED LOADER SERVICE MANUAL
- Willmar NA Applicators 8500 EAGLE LIQUID SPRAYER REPAIR TIME SCHEDULE
- Willmar NA Material Handling 4560 ARTICULATED LOADER SERVICE MANUAL
- Willmar NA Material Handling 4550 WRANGLER LOADER REPAIR TIME SCHEDULE
- Willmar NA 1600,16T,24T WILLMAR TENDER REPAIR TIME SCHEDULE
- Willmar Applicators Parts Documents AG333083
- Willmar Liquid Sprayer Air Ride 745 Parts Catalog WRP0378
- Willmar Liquid Sprayer Air Ride 765 Parts Catalog WRP0379
- Willmar Liquid Sprayer Air Ride 765HT Parts Catalog WRP0373
- Willmar Liquid Sprayer Chassis Eagle 8650 Parts Catalog WR125235
- Willmar Liquid Sprayer Chassis Eagle 8650 Parts Catalog WR128688
- Willmar Liquid Sprayer Eagle 8100 Parts Catalog WRP0401
