White Tractor 1550 1555 2-62 Parts Catalog 43312400
Brand: White
Model:
White 1550 2-62 Tractor
White 1555 2-62 Tractor
Part Number: 43312400
Number of Pages: 603 Pages
Front Main Frame
Cylinder Head Cover And Breather (Hc, Lpg, Diesel)
Rocker Arms And Push Rods
Cylinder Head And Valves (S N 160000 -)
Emblem, Decal Sets And Name Plates (Rc, Ind, Wht, Uty)
Crankcase (Hc, Lpg, Diesel) (S N 160000 -)
Crankshaft And Related Parts (Hc, Lpg, Diesel)
Camshaft (Gas, Lpg, Diesel) (S N 160000 -)
Oil Pan, Oil Pump And Oil Filter (Hc, Lpg, Diesel)
Oil Pump
Oil Filter
Manifold - Gas And Lp Gas (S N 160000 -)
Air Cleaner - Oil Bath - Gas And Lp Gas (Rc, Ind, Wht, Uty)
Air Cleaner
Precleaner Screener
Air Cleaner - Dry Type - Gas And Lp Gas (Rc, Ind, Wht, Uty)
Manifold - Diesel (S N 160000 -)
Muffler And Heat Shield (S N 160000 -)
Manifold Preheater - Diesel (Rc, Ind, Wht, Uty)
Air Cleaner - Oil Bath - Diesel (Rc, Ind, Wht, Uty)
Air Cleaner - Dry Type - Diesel (Rc, Ind, Wht, Uty)
Main Fuel Tank System - Gas (Rc, Ind, Wht, Uty)
Fuel Strainer
Wheel Guard Fuel Tanks - Gas (Rc, Wht) (S N 160000 -)
Two Wheel Guard Tanks And Main Tank - Gas (Rc, Wht)
One Wheel Guard Tank And Main Tank - Gas (Rc, Wht)
Auxiliary Fuel Tanks - Narrow Row Cab - Gas (Rc)
Governor Controls - Gas (Rc, Ind, Wht, Uty) (S N 160000 -)
Governor Housing
Governor Shaft
Governor Shaft (P N's 164474-As, 165687-As And 30-3044289)
Carburetor
Fuel System - Lp Gas (Rc, Wht, Uty) (S N 160000 -)
Lp Gas Filter
Lp Gas Regulator
Lp Gas Carburetor
Governor Controls - Lp Gas (Rc, Wht, Uty) (S N 160000 -)
Main Fuel Tank System - Diesel (Rc, Ind, Wht, Uty)
Primary Fuel Filter
Final Fuel Filter
Wheel Guard Fuel Tanks - Diesel (Rc, Wht) (S N 160000 -)
Two Wheel Guard Tanks And Main Tank - Diesel (Rc, Wht)
One Wheel Guard Tank And Main Tank - Diesel (Rc, Wht)
Auxiliary Fuel Tanks - Narrow Row Cab - Diesel (Rc)
Governor Controls - Diesel (Rc, Ind, Wht, Uty)
Injection Pump, Injectors And Accessory Drive - Diesel
Fuel Injector
Ignition And Starter
Distributor
Starting Motor
Ignition Wires And Clips (Rc, Ind, Wht, Uty)
Water Pump, Fan And Fan Belt (Rc, Ind, Wht, Uty)
Cooling System (Rc, Ind, Wht, Uty)
Coolant Heater (Rc, Ind, Wht, Uty) (S N 160000 -)
Rear Main Frame (Rc, Ind, Wht, Uty) (S N 160000 -)
Transmission (Rc, Ind, Wht, Uty) (S N 160000 -)
Gear Shift (Rc, Ind, Wht, Uty)
Brake Controls - Regular (Rc, Ind, Wht, Uty) (S N 160000 -)
Brake Controls - Reverse-O-Torc (Ind) (S N 160000 -)
Brakes (Rc, Ind, Wht, Uty)
Differential (Rc, Ind, Wht, Uty) (S N 160000 -)
Hydra-Power Drive (Rc, Ind, Wht, Uty)
Hydra-Power Drive Pump
Creeper Drive (Rc, Wht, Uty)
Belt Pulley (Rc, Wht, Uty) (S N 160000 -)
Power Take-Off - Single Speed (Rc, Ind, Wht, Uty)
Pto Clutch
Power Take-Off - Dual Speed (Rc, Ind, Wht, Uty)
Hydra-Lectric-Stop And Depth-Stop Internal Valve System
Flow Divider
Hydra-Lectric-Stop & Depth-Stop Internal Valve System (B, D)
Servo Valve
Hydra-Lectric-Stop And Depth-Stop Internal Valve Systems
Hydra-Lectric-Stop And Internal Valve System (A, B)
Hydra-Lectric-Stop & Depth-Stop Internal Valve Systems (C,D)
Remote Only, Depth-Stop External Valve System
Control Valve - Double Acting
Valve Assembly
Valve
Control Valve - Single Acting
Remote Only, Depth-Stop External Valve System - Industrial
Control Valve
Cylinder, Hoses And Connections - Hydra-Lectric-Stop
Power Lift Coupling
Power Lift Cylinder
Hydra-Lectric Cylinder - 3 Inch
Power Lift Cylinder (3 Inch)
Cylinder, Hoses And Connections - Depth-Stop Internal Valve
Cylinder
Cylinder, Hoses And Connections - Depth Stop External Valve
Hoses And Connections - Depth-Stop External Valve
Coupling
Hydraulic Oil Cooler (Rc, Ind, Wht, Uty) (S N 160000 -)
Bypass Valve
Rear Wheels (Rc, Ind, Wht, Uty) (S N 160000 -)
Rear Wheel Rims (Rc, Ind, Wht, Uty) (S N 160000 -)
Rear Wheel Weights (Rc, Ind, Wht, Uty) (S N 160000 -)
Front Wheels (Rc, Ind, Wht, Uty) (S N 160000 -)
Front Wheel Rims (Rc, Ind) (S N 160000 -)
Front Wheel Weights (Rc, Ind, Wht, Uty) (S N 160000 -)
Lights (Rc, Ind, Wht, Uty)
Lamp - Warning
Lamp - Tail And Flood
Lamp - Flood
Lamp - Tail
Lamp - Head
Tail And Flood Lamp
Head Lamp
Warning Lamp
Drawbar (Rc, Ind, Wht, Uty) (S N 160000 -)
Wide Drawbar (Rc, Ind, Wht, Uty) (S N 160000 -)
Extra Heavy Wide Drawbar (Ind) (S N 160000 -)
Drawbar - Extra High Clearance (Rc) (S N 160000 -)
Three-Point Hitch (Rc, Ind, Wht, Uty) (S N 160000 -)
Leveling Gear
Clutch (Rc, Ind, Wht, Uty) (S N 160000 -)
Clutch Cover
Reverse-O-Torc Drive (Ind) (S N 160000 -)
Reversing Gear
Rear Axle (Rc, Ind, Wht, Uty) (S N 160000 -)
Rear Axle - Extra High Clearance (Rc) (S N 160000 -)
Wheel Guards & Platforms (Rc, Ind, Wht, Uty) (S N 160000 -)
Wheel Guard Panels (Rc, Ind, Wht) (S N 160000 -)
Step (Rc, Ind, Wht) (S N 160000 -)
Seat (Rc, Ind, Uty) (S N 160000 -)
Seat Adjuster
Seat (Rc, Ind, Wht, Uty) (S N 160000 -)
Seat Frame And Cushions
Roll Bar And Seat Belt (Rc, Ind, Wht, Uty) (S N 160000 -)
Front Frame Weights (Rc, Ind, Wht, Uty) (S N 160000 -)
Manual Steering (Rc, Ind, Wht) (S N 160000 -)
Power Steering (Rc, Ind, Wht, Uty)
Power Steering Hydramotor
Hydramotor
Power Steering (Rc, Ind, Wht, Uty) (S N 160000 -)
Power Steering Pump
Power Steering Cylinder
Manual Steering Machanism - Adjustable Front Axle (Rc)
Tie Rod
Manual Steering Gear
Manual Steering Mechanism - Wheatland And Industrial
Power Steering Mechanism - Adjustable Front Axle (Rc)
Power Steering Mechanism - Wheatland And Industrial
Power Steering Mechanism - Short Wheel Base (Rc, Uty)
Manual Steering Front Axle - Dual Front Wheel (Rc)
Manual Steering Front Axle - Single Front Wheel (Rc)
Power Steering Front Axle - Dual Front Wheel (Rc)
Power Steering Front Axle - Single Front Wheel (Rc)
Front Axle - Adjustable Front Axle (Rc)
Front Axle - Wheatland And Industrial (Ind, Wht)
Front Axle - Short Wheel Base (Rc, Uty) (S N 160000 -)
Front Axle - Extra High Clearance (Rc) (S N 160000 -)
Hood, Side Panels And Grille (Rc, Ind, Wht, Uty)
Instrument Panel (Rc, Ind, Wht, Uty) (S N 160000 -)
Instruments And Switches (Rc, Ind, Wht, Uty)
Speed-O-Tac (Rc, Ind, Wht, Uty) (S N 160000 -)
Tool Box And Tools (Rc, Ind, Wht, Uty) (S N 160000 -)
Cab (Rc, Wht) (S N 160000 -)
Roof Extension
Cab - Left Front Door
Cab - Left Rear Door
Blower
Windshield Wiper
Cab - Continental (Rc, Ind, Wht) (S N 160000 -)
Cab - Two Front Doors
Fender Filler Panel
Cab - Narrow Row (Rc) (S N 160000 -)
Cab - Narrow Row
Mud Guard Kit
Heater And Connections (Rc, Wht) (S N 160000 -)
Blower Assembly
Plenum Assembly
Heater And Connections - Continental Cab (Rc, Ind, Wht)
Heater And Connections - Narrow Row Cab (Rc) (S N 160000 -)
Cab Plates (Rc, Ind, Wht) (S N 160000 -)
Cab - Industrial (Ind) (S N 160000 -)
Cab - Industrial
Cab Heater And Connections - Industrial (Ind) (S N 160000 -)
Weather Break (Rc, Ind, Wht, Uty) (S N 160000 -)
Converta Cab (Rc, Ind, Wht, Uty) (S N 160000 -)
Weather Break
Converta Cab
Air Conditioner (Rc, Wht) (S N 160000 -)
Air Conditioner
Brand: White
Model:
Front Main Frame
Oil Pump
Oil Filter
Air Cleaner
Precleaner Screener
Fuel Strainer
Governor Housing
Governor Shaft
Carburetor
Lp Gas Filter
Lp Gas Regulator
Lp Gas Carburetor
Primary Fuel Filter
Final Fuel Filter
Fuel Injector
Distributor
Starting Motor
Pto Clutch
Flow Divider
Servo Valve
Valve Assembly
Valve
Control Valve
Power Lift Coupling
Power Lift Cylinder
Cylinder
Coupling
Bypass Valve
Lamp - Warning
Lamp - Flood
Lamp - Tail
Lamp - Head
Tail And Flood Lamp
Head Lamp
Warning Lamp
Leveling Gear
Clutch Cover
Reversing Gear
Seat Adjuster
Hydramotor
Power Steering Pump
Tie Rod
Roof Extension
Blower
Windshield Wiper
Fender Filler Panel
Cab - Narrow Row
Mud Guard Kit
Blower Assembly
Plenum Assembly
Cab - Industrial
Weather Break
Converta Cab
Air Conditioner
