705,578
White Tractor 1250 Parts Catalog 43307500
Brand: White
Model: White 1250 Tractor
Part Number: 43307500
Number of Pages: 242 Pages
Group A - Front Main Frame (1250 Gas) (S N 701881 -)
Group A - Decals And Name Plate (S N 701881 -)
Group B - Engine (1250) (S N 701881 -)
Group B - Crankcase And Cylinder Head
Group B - Oil Pan (1250 Gas) (S N 701881 -)
Group B - Oil Pan And Crankcase Covers
Group B - Crankshaft And Flywheel (1250 Gas) (S N 701881 -)
Group B - Connecting Rods And Pistons
Group B - Camshaft, Rocker Arms And Valves
Group B - Camshaft Drive (1250 Gas) (S N 701881 -)
Group B - Camshaft Drive (1250 Diesel) (S N 701881 -)
Group B - Oil Pump, Filter And Gauges (1250 Gas)
Group B - Oil Pump, Filter And Gauges (1250 Diesel)
Group B - Exhaust Manifold And Muffler (1250 Gas)
Group B - Exhaust Manifold And Muffler (1250 Diesel)
Group B - Air Cleaner And Intake Manifold (1250 Gas)
Group B - Air Cleaner And Intake Manifold (1250 Diesel)
Group B - Fuel Tank (1250 Gas)
Group B - Fuel Tank (1250 Diesel)
Group B - Fuel Pump And Lines (1250 Gas) (S N 701881 -)
Group B - Fuel Injection System (1250 Diesel) (S N 701881 -)
Group B - Injection Pump Drive (1250 Diesel) (S N 701881 -)
Group B - Accelerator Control Linkage (1250 Gas)
Group B - Carburetor And Connections (1250 Gas)
Group B - Accelerator Control Linkage (1250 Diesel)
Group B - Battery Holder (1250 Gas, Diesel) (S N 701881 -)
Group B - Distributor, Coil And Ignition (1250 Gas)
Group B - Engine Starting Equipment (1250 Gas)
Group B - Engine Starting Equipment (1250 Diesel)
Group B - Current Generating System (1250 Gas)
Group B - Current Generating System (1250 Diesel)
Group B - Lighting System (1250 Gas, Diesel) (S N 701881 -)
Group B - Lighting System - Vineyard (1250 Diesel)
Group B - Horn And Wiring (1250 Gas, Diesel) (S N 701881 -)
Group B - Fan And Belt (1250 Gas) (S N 701881 -)
Group B - Fan And Belts (1250 Diesel) (S N 701881 -)
Group B - Radiator (1250 Gas, Diesel) (S N 701881 -)
Group B - Water Pump And Connections (1250 Gas)
Group B - Water Pump And Connections (1250 Diesel)
Group B - Radiator Curtain (1250 Gas, Diesel) (S N 701881 -)
Group B - Coolant Heater (1250 Diesel) (S N 701881 -)
Group C - Rear Main Case (1250 Gas, Diesel) (S N 701881 -)
Group C - Transmission (1250 Gas, Diesel)
Group C - Reduction Unit Gears (1250 Gas, Diesel)
Group C - Gear Shift - Outer (1250 Gas, Diesel)
Group C - Gear Shift - Inner (1250 Gas, Diesel)
Group C - Propeller Shaft (1250 Diesel) (S N 701881 -)
Group C - Brakes (1250 Gas, Diesel) (S N 701881 -)
Group C - Hand Brake Control (1250 Gas, Diesel)
Group C - Differential (1250 Gas, Diesel) (S N 701881 -)
Group C - Differential Lock (1250 Gas, Diesel)
Group C - Transfer Drive Engagement Controls
Group C - Transfer Drive Case And Covers
Group C - Transfer Drive Gears - Four Wheel Drive
Group C - Transfer Drive Shaft - Four Wheel Drive
Group D - Belt Pulley (1250 Gas, Diesel) (S N 701881 -)
Group E - Power Take - Off And Pulley Control
Group E - Power Take-Off (1250 Gas, Diesel) (S N 701881 -)
Group F - Power Lift (1250 Gas) (S N 701881 -)
Group F - Power Lift (1250 Diesel) (S N 701881 -)
Group F - Power Lift Controls - Outer (1250 Gas, Diesel)
Group F - Power Lift Controls - Inner (1250 Gas, Diesel)
Group F - Power Lift Oil Reservoir (1250 Gas, Diesel)
Group F - Power Lift External Control Valve
Group F - Power Lift Hoses And Connections
Group F - Auxiliary Hydraulics Rear Mounted Pump
Group H - Rear Wheels (1250 Gas, Diesel) (S N 701881 -)
Group H - Rear Wheels - Vineyard (1250 Gas, Diesel)
Group L - Front Wheels (1250 Gas, Diesel) (S N 701881 -)
Group L - Front Wheels - Four Wheel Drive (1250 Diesel)
Group P - Drawbar (1250 Gas, Diesel) (S N 701881 -)
Group P - Three Point Hitch Drawbar (1250 Gas, Diesel)
Group P - Tow Hook (1250 Gas, Diesel) (S N 701881 -)
Group P - Three Point Hitch Category 1 (1250 Gas, Diesel)
Group P - Three Point Hitch Dual Category 1 And 2
Group P - Three Point Hitch - Vineyard (1250 Diesel)
Group Q - Center Main Case (1250 Gas, Diesel) (S N 701881 -)
Group Q - Clutch (1250 Gas, Diesel) (S N 701881 -)
Group R - Rear Axle Carrier (1250 Gas, Diesel)
Group R - Rear Axle Carrier - Vineyard (1250 Diesel)
Group R - Rear Axle (1250 Gas, Diesel) (S N 701881 -)
Group R - Bull Gear And Pinion (1250 Gas, Diesel)
Group S - Wheel Guards And Platforms (1250 Gas, Diesel)
Group S - Wheel Guards And Platforms - Vineyard
Group T - Seat (1250 Gas, Diesel)
Group T - Seat (1250 Gas, Diesel) (S N 729999 -)
Group U - Steering Gear (1250 Gas, Diesel) (S N 701881 -)
Group U - Steering Linkage (1250 Gas) (S N 701881 -)
Group U - Steering Linkage (1250 Diesel) (S N 701881 -)
Group U - Power Steering (1250 Gas) (S N 701881 -)
Group U - Power Steering (1250 Diesel) (S N 701881 -)
Group U - Steering Linkage - Four Wheel Drive
Group U - Front Axle (1250 Gas) (S N 701881 -)
Group U - Front Axle (1250 Diesel) (S N 701881 -)
Group U - Front Axle And Axle Shafts - Four Wheel Drive
Group U - Front Axle Knuckle - Four Wheel Drive
Group U - Front Axle Differential Gears - Four Wheel Drive
Group W - Hood (1250 Gas, Diesel) (S N 701881 -)
Group W - Radiator Panel And Grille (1250 Gas, Diesel)
Group W - Instrument Panel (1250 Gas, Diesel) (S N 701881 -)
Group W - Multimeter And Drive (1250 Gas) (S N 701881 -)
Group W - Multimeter And Drive (1250 Diesel) (S N 701881 -)
Group X - Tool Box (1250 Gas, Diesel) (S N 701881 -)
Group X - Tools (1250 Gas, Diesel) (S N 701881 -)
Group Y - Weather Break (1250 Gas, Diesel) (S N 701881 -)
Supplement - Water Pump 1250 Gas, Bulletin 433163, 1-26-73
Supplement - Water Pump 1250 Gas - Bulletin 433098, 2-5-70
Supplement - Coolant Heater - 8-10-72 - B&Q Engine & Clutch
