White Field Boss Tractor 2-85 Parts Catalog 43324300
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-85 Field Boss Tractor
Part Number: 43324300
Number of Pages: 412 Pages
Decals And Nameplates
Front Main Frame
Cylinder Head, Camshaft And Valves (S N 263341 Thru 297446)
Cylinder Head, Camshaft And Valves (S N 297447 And Later)
Cylinder Head Cover (263341 Thru 297446)
Cylinder Head Cover, Breather And Oil Filler
Crankcase And Flywheel Housing (S N 263341 Thru 297446)
Crankcase And Flywheel Housing (S N 297447 And Later)
Crankshaft And Pistons (S N 263341 Thru 297446)
Crankshaft And Pistons (S N 297447)
Timing Gear And Auxiliary Drive (S N 263341 Thru 297446)
Timing Gear And Auxiliary Drive (S N 297447)
Oil Pan And Oil Pump (S N 263341 Thru 297446)
Oil Pan And Oil Pump (S N 297447)
Oil Filter (S N 263341 Thru 265357)
Oil Filter - Domestic & International (S N 265358 And Later)
Oil Filter And Oil Cooler (S N 297447 And Later)
Intake And Exhaust Manifolds (S N 263341 Thru 297446)
Intake And Exhaust Manifolds (S N 297447 And Later)
Muffler
Manifold Preheater (S N 263341 Thru 277181)
Thermostart (S N 277182 And Later)
Ether Cold Starting
Air Cleaner
Vertical Air Intake Package (S N 263341 Thru 277181)
Air Cleaner (S N 277182 Thru 297446)
Air Cleaner (S N 297447 And Later)
Aspirated Pre-Cleaner (S N 277182 Thru 297446)
Aspirated Pre-Cleaner (S N 297447 And Later)
Fuel Filter, Fuel Pump And Lines (S N 263341 Thru 297446)
Fuel Filter, Fuel Pump And Lines (S N 297447 And Later)
Fuel Pump
Water Separator And Lines (S N 297447 And Later)
Governor Hand Lever
Governor Controls
Injection Pump, Injectors And Lines (S N 263341 Thru 297446)
Injection Pump, Injectors And Lines (S N 297447 And Later)
Alternator And Starter (S N 263341 Thru 297446)
Alternator And Starter (S N 297447 And Later)
Starting Motor
Step, Battery Box And Cables
Cooling System (S N 263341 Thru 297447)
Cooling System (S N 297447 And Later)
Water Pump, Fan And Fan Belt (S N 263341 Thru 297446)
Water Pump, Fan And Fan Belt (S N 297447 And Later)
Coolant Heater
Upper Fuel Tank Lines
Upper Fuel Tank
Lower Fuel Tank And Lines (S N 263341 Thru 289048)
Upper Tank To Lower Tank Transfer Kit
Lower Fuel Tank And Lines (S N 289049 And Later)
Wheel Guard Fuel Tanks
Wheel Guard Fuel Tank Lines
Transmission Pressure Lube System
Transmission Pressure Lube Switch
Transmission Pressure Lube Pump
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Transfer Drive - 4wd
Transfer Drive
Gear Shaft
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Hand Brake (S N 263341 Thru 282338)
Hand Brake (S N 282339 And Later)
Brakes
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Oil Pump
Over Under Oil Cooler
Power Take-Off
Pto Valve, Linkage And Lines
Power Take-Off Clutch And Drive
Valve - Power Take-Off
Hydraulic Housing And Cover
Hydraulic Pump, Pressure Valve, Filter And Lines
Hydraulic Oil Filter
Pressure Valve
Hydraulic Hand Controls
Servo Valve
Pressure Detent Valve
Float Valve
Hydraulic Internal Draft Sensitivity (Category Ii)
Hydraulic External Draft Sensitivity (Category Iii)
Lift Cylinder
Cylinders, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Hydraulic Cooler And Lines
Transmission Lube, Hydraulic And Cooler Pump Drive
Rear Wheel Rims
Rear Wheel Weights
Front Wheels And Hub
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Turn Signal Flasher
Drawbar
Wide Drawbar
Safety Chain
Three-Point Hitch (Category Ii)
6,000 Lb. Lift Hitch (Category Iii)
Clutch
Clutch Cover - 12 Inch
Clutch Pedal And Linkage
Wheel Guards
Platform
Instrument Panel
Seat Without Cab (S N 263341 Thru 293166)
Seat With Cab (S N 263341 Thru 280144)
Seat With Cab (S N 280145 Thru 293166)
Seat And Suspension (S N 293167 And Later)
Seat Suspension
Roll Bar And Canopy (S N 263341 Thru 281301)
Roll Bar And Canopy (S N 281302 And Later)
Front Frame Weights
Power Steering
Steering Column
Steering Control Unit
Power Steering Cylinder And Lines
Adjustable Front Axle Power Steering Mechanism
Wheatland Power Steering Mechanism
Wheatland Front Axle
Tie Rod
Tie Rod Assembly
Front Axle Carrier And Supports - 4wd
Power Steering And Connections - 4wd
Power Steering And Connections - 4wd (S N 297447 And Later)
Front Axle - 4wd
Front Axle Drive Shaft - 4wd
Hood, Side Panels And Grille (S N 263341 Thru 277181)
Hood And Side Panels (S N 277182 And Later)
Grille (S N 268142 And Later)
Speedometer
Tachourmeter
Tool Box
Cab Door And Windows
Cab Glass Specifications
Cab Roof Bird Guards (S N 296878 And Later)
Windshield Wiper
Cab Mounting (S N 263341 Thru 277181)
Cab Mounting (S N 277182 And Later)
Cable Electrical System (S N 263341 Thru 277181)
Cab Electrical System (S N 277182 And Later)
Cab Air Conditioner - Evaporator And Heater Housing
Cab Blower And Wiring (S N 263341 Thru 277181)
Cab Blower (S N 277182 And Later)
Cab Heater (S N 263341 Thru 277181)
Cab Heater (S N 277182 And Later)
Cab Air Conditioner - Condenser And Electrical Controls
Cab Air Conditioner - Compressor And Evaporator
Cab Air Conditioner - Compressor, Condenser And Evaporator
Air Conditioner Compressor And Drive Pulley
Brand: White
Front Main Frame
Muffler
Ether Cold Starting
Air Cleaner
Fuel Pump
Governor Hand Lever
Governor Controls
Starting Motor
Coolant Heater
Upper Fuel Tank
Rear Main Frame
Transfer Drive
Gear Shaft
Brake Valve
Brakes
Power Take-Off
Pressure Valve
Servo Valve
Float Valve
Lift Cylinder
Rear Wheel Rims
Rear Wheel Weights
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Turn Signal Flasher
Drawbar
Wide Drawbar
Safety Chain
Clutch
Wheel Guards
Platform
Instrument Panel
Seat Suspension
Front Frame Weights
Power Steering
Steering Column
Tie Rod
Tie Rod Assembly
Front Axle - 4wd
Speedometer
Tachourmeter
Tool Box
Windshield Wiper
