118
7,392
Weidemann Wheel Loader 8080 345-02 Spare Parts List 2014 IT ES EN
Language: Italian, English, Spanish
Brand: Weidemann
Type of Machine: Wheel Loader
Type of Manual: Spare Parts List
Model: Weidemann 8080 Type 345-02 Wheel Loader
Serial Number: 345 02 0001
Version 1.8
Publication Date: 2014
Number of Pages: 481 Pages
Maintenance
Maintenance Group
Hose Connection
Seal
Engine Suspension
Injection
Lubricating Oil
Engine Cooling
Engine Accessories
Fuel Piping
Pump Housing
Air Filter
Gas Regulator
Hand Throttle
Exhaust System
Cooling
Universal Radiator
Hydraulic Discharge
Reversing Cooler
Power Unit
Travel Drive And Engine
Filter
Hydraulic Motor
Gearbox
Control Cover
Axle
Axle Connection
Front Axle
Steering Cylinder
Bevel Gear Drive
Brake
Wheel Hub
Rear Axle
Double Joint Shaft
Gearbox Housing
Gearbox
Differential Lock
Brake Assembly
Brake
Brake Pedal
Steering
Steering
Diagonal Steering
Working Hydraulics
Circulation
Loader Equipment – Hydraulic System
Oil Tank
Selector Lever Support
Floating Position
Control Valve – Float Position
Control Unit
Lift Cylinder
Tipping Cylinder
Limiter Unit
Hose Rupture Safety Device
Additional Control Circuit
4th Auxiliary Control Circuit
Automatic Bucket Return
Return Line
Dump Truck Body Cylinder
Transport Safety
Central Lubrication System
Electrical
Dashboard
Lighting
Battery Cycle
Oil Preheating Bg
Wiring Harness
Main Harness
Armrest Harness
License Plate Light Bg
Add-On Group
Slow Travel Device
Electric Mirror
Additional Spotlight
Radio
Chain/Wheel
Tire
Chassis / Frame
Frame
Cladding
Cladding
Loading System / Main Boom
Loading System
Quick-Change Plate
Cab / Driver’s Seat
Cabin Elements
Cladding
Protective Grid
Cabin Door Left
Cabin Door Right
Driver’s Seat Fixation
Driver’s Seat Upper Part
Lower Seat Part
Driver’s Seat
Air-Suspended Seat Base
Heating / Air Conditioning
Heating
Additional Heating
Air Conditioner
Labels, Tools
Adhesive Label
Tools / Documents
Use In Aggressive Environments
Attached Equipment
Shovel
Loader Bucket
Clamshell Bucket
Multi-Purpose Hydraulic Bucket
Cylinder
Disposal Equipment
Work Platform
Trailer Coupling
