118
6,911
Weidemann Wheel Loader 4270CX100 TELE 4270CX100T Spare Parts List 1000326087 2014 IT ES EN
Language: Italian, English, Spanish
Brand: Weidemann
Type of Machine: Wheel Loader
Type of Manual: Spare Parts List
Model: Weidemann 4270CX100 TELE Type 4270CX100T Wheel Loader
Version 1.0
Engine: Perkins 1104D-44T Engine
Part Number: 1000326087
Publication Date: 2014
Number of Pages: 417 Pages
Service Kit
Engine Accessories
Exhaust System
Fuel Supply System
Engine 1104D-44T
Radial Shaft Seal
Piston
Connecting Rod
Rocker Arm
Camshaft
Fuel Supply Pump
Fuel Supply Pipe
Injection Nozzle
Clamp
Switch
Plug
Pipe
Ring Gear
Starter
V-Belt
Oil Pan
Dipstick
Oil Strainer
Valve Cover
Valve Cover
Ventilation
Filler Neck
Oil Radiator
Oil Filter
Control Box
Control Box
Control Box
Cover
Plug
Oil Pump
Turbocharger
Pipe
Intake Manifold
Joint
Pipe Elbow
Cover
Vacuum Pump
Pipe
Pipe
Pipeline
Glow Plug
Switch
Plug
Switch
Pipe
Cooling
Cooling
Drive And Motor
Drive And Motor
Variable Displacement Pump
Drive And Motor
Variable Motor
Axle
Axle
Drive / Power Take-Off
Axle Tube
Axle Tube
Axle Tube
Planetary Housing
Disc Brake
Brake
Axle Tube
Axle Tube
Axle Tube
Planetary Housing
Gearbox Housing
Torque Distributor
Brake Assembly
Brake Assembly
Steering
Steering
Work Hydraulics
Work Hydraulics
Control
Control Valve
Control Valve
Third Control Circuit
Additional Control Circuit
Work Hydraulics
Control
Control Valve
Control Valve
Electrical
Steering Column
Steering Column
Cabin
Wiring Harness
Electrical
Valve Wiring Harness
Work Lighting
Tires
Tires
Frame
Frame
Front Frame
Articulated Joint
Covering
Engine Bonnet
Engine Bonnet Insulation
Engine Bonnet
Loading System / Main Arm
Telescopic Loading System
Quick-Change Plate
Quick-Change Plate
Quick-Change Plate
Quick-Change Plate
Cabin
Cabin
Pedal
Covering
Covering
Cabin
Crossbeam
Cabin Door
Windshield
Rear Window
Special Equipment
Hydraulics
Seat Msg Msg 85/S722
Suspension Msg 95al-06
Heating
Heating
Option
Vibration Damping
Toolbox
Air Conditioner
License Plate Holder
Lighting Device
Trailer Hitch
Support
Earth Shovel
Earth Shovel
Pallet Fork
Machine Documentation
Sticker
