Weidemann Telehandler T6025 T06-01 Spare Parts Catalog 07.2025 DE EN FR
Language: French, German, English
Brand: Weidemann
Type of Machine: Telehandler
Model: Weidemann T6025 Type T06-01 Telehandler
Version 1.0
Publication Date: 07.2025
Number of Pages: 928 Pages
Service Kit
Maintenance Package 100h
Maintenance Package 500h
Maintenance Package 1500h
Lubrication
Engine Attachments Parts
Mounting
Air Cleaner
Fuel System
Coupling (45kw)
Coupling (55kw)
Exhaust Pipe
Engine 404J-E22T (45kw)
Engine 404J-E22T
Hose Connection
Seal Crankshaft
Oil Line
Pressure Limit Reliefvalve
Engine Oil Pump
Crank Shaft
Piston
Bearing Set
Filter Head
Cylinder Head Gasket
Rocker Arm
Camshaft
Pressure Pump
Control Unit
Clutch Housing
Flywheel
Starter Motor
Belt Pulley
Oil Sump
Oil Dip Stick
Oildrain Plug
Cover
Venting
Venting Filter
Bracket
Belt Pulley
Belt Pulley
Thermostat
Filler Pipe
Adapter Ventilator
Generator
Flat Belt
Controlhousing
Housing Seal
Filler Pipe
Sensor
Turbocharger
Oil Line
Reflux Line
Suction Manifold
Speed Actuating
Suction Manifold
Exhaust Pipe
Soot Filter
Console Dpf
Sensor
Temperature Sensor
Exhaust Pipe
Air Sucking In
Temperature Sensor
Exhaust Pipe
Exhaust Gas Recirculation Valve
Exhaust Manifold
Bracket Fuelfilter
Water Seperator
Glow Plug
Banjo Bolt
Wiring Harness Engine
Wiring Harness
Fuel Pump
Engine 404J-E22TA (55kw)
Engine 404J-E22TA
Hose Connection
Seal Crankshaft
Oil Line
Engine Oil Pump
Crank Shaft
Piston
Bearing Set
Filter Head
Rocker Arm
Camshaft
Pressure Pump
Control Unit
Clutch Housing
Flywheel
Starter Motor
Belt Pulley
Oil Sump
Oil Dip Stick
Oildrain Plug
Cover
Venting
Venting Filter
Bracket
Belt Pulley
Belt Pulley
Thermostat
Filler Pipe
Adapter Ventilator
Generator
Flat Belt
Controlhousing
Housing Seal
Filler Pipe
Sensor
Turbo Charger
Oil Line
Reflux Line
Suction Manifold
Speed Actuating
Suction Manifold
Exhaust Pipe
Soot Filter
Console Dpf
Sensor
Temperature Sensor
Exhaust Pipe
Air Sucking In
Temperature Sensor
Exhaust Pipe
Exhaust Manifold
Bracket Fuelfilter
Water Seperator
Glow Plug
Banjo Bolt
Wiring Harness
Fuel Pump
Cooling
Cooling
Cooling
Fan Drive
Fan Drive (Reversible)
Drive Unit
Tubing Traction Drive Hydraulic (Basic)
Tubing Traction Drive Hydraulic (Performance)
Tubing Traction Drive Hydraulic (Economy)
Displacement Pump (Basic A4vgb045bt10p)
Displacement Pump (Basic 1000493419)
Displacement Pump (Performance A4vg56et)
Displacement Pump
Displacement Pump (A4vg56et 1000540676)
Displacement Motor (A36vm060ep 1000500230)
Assembly Parts (A36vm060ep)
Displacement Motor (A36vm125ep 1000400872)
Assembly Parts (A36vm125ep)
Hydraulic Tank
Reflux Suction Filter (1000493912)
Differential Lock (Differential Lock)
Solenoid Valve (1000341493)
Cardan Shaft
Axle Attachment
Load Sensor
Front Axle (Basic Without Differential Lock)
Axle Pipe (Front Axle)
Steering Cylinder (Front Axle)
Drive (Front Axle)
Differential (Front Axle)
Cross Union (Front Axle)
Wheel Hub (Front Axle)
Planet Carrier (Front Axle)
Brake Calliper (Front Axle)
Front Axle (Basic With Differential Lock)
Drive (Front Axle)
Differential Lock (Front Axle)
Front Axle (Performance Without Differential Lock)
Drive (Front Axle)
Front Axle (Performance With Differential Lock)
Drive (Front Axle)
Rear Axle (Basic Without Differential Lock)
Axle Pipe (Rear Axle)
Steering Cylinder (Rear Axle)
Drive (Rear Axle)
Differential (Rear Axle)
Cross Union (Rear Axle)
Wheel Hub (Rear Axle)
Planet Carrier (Rear Axle)
Distributor Gear-Box (Rear Axle)
Rear Axle (Performance Without Differential Lock)
Drive (Rear Axle)
Brake Assembly
Brake Assembly
Steering Unit
Steering Column (Rigid Steering Column)
Steering Column (Adjustable Steering Column)
Tubing Steering Unit (All-Wheel Steering)
Tubing Steering Unit (Steer Select Frnt/4w/Crab)
Hydrostatic Steering
Working Hydraulic
Control Valve (Without 3th Control Circuit)
Valve Plug (Exploded View 1000540029)
Control Valve (3th Control Circuit Electr.)
Control Valve (Exploded View 1000540027)
Working Hydraulic
Lift Cylinder
Lift Cylinder (Shock Absorber)
Tilt Ram
Regulation Ram
Gear Pump (31,8-10,8ccm)
Pilot Control (3rd Control Circuit Loading System)
Plug Coupling (3.Contr.Circ. Flatface)
Plug Coupling (3.Contr.Circ. Svk)
Plug Coupling (3.+4.Contr.Circ. Flatface)
Plug Coupling (3.+4.Contr.Circ. Svk)
Reflux Line (Pressureless Return)
Electrical Control Circuit (With Pressure Relief)
Electrical Control Circuit (Wthout Pressure Relief)
Auxilary Hydraulics (Back With Changeover Valve)
Pipe Line Backflow (Return Pipe)
Electric
Instrument Panel
Display (7 ")
Display (Round)
Cable Adapter (Round Display)
Drive Lock
Wiring Harness (Immobilizer)
Bracket Controlling
Control Unit (Ttc 580 V1 08)
Joystick (Type I2)
Joystick (Type J)
Main Harness
Components Wiring Harness (1000493459)
Attachment Parts Wiring Harness (1000493459)
Wiring Harness Cabine
Components Wiring Harness (1000498282)
Components Wiring Harness (1000498282 Fuse Boxes)
Attachment Parts Wiring Harness (1000498282)
Wiring Harness Lifting System (With Central Lubrication)
Wiring Harness Lifting System (Without Central Lubrication)
Wiring Harness Lifting System (Worklight)
Wiring Harness Lifting System (Worklight + 4th Aux)
Wiring Harness Lifting System (Option 1)
Wiring Harness Lifting System (Option 2)
Wiring Harness Lifting System (Option 3)
Wiring Harness Lifting System (Option 4)
Lighting (Halogen)
Working Light (Led 1000 Lm 1x Loading System)
Working Light (Led 2000 Lm 1x Loading System)
Working Light (Led 1000 Lm Frame)
Working Light (Led 2000 Lm Frame)
Working Light (Led 1000 Lm Cabin)
Working Light (Led 2000 Lm Cabin)
Battery Cable
Engine Pre Heating (230 V Engine + Hydraulic-Oil)
Battery
Shut Off Switch
Speed Actuating
Rear View Camera
Socket (7-Pole)
Horn
Signal
Bucket Backup Autom.
Pressure Relief Button (Pressure Relief)
Sensor (Angle Sensor)
Cable (Rear Light Left)
Cable (Rear Light Right)
Rotating Beacon (Orange & Green (Only England))
Rotating Beacon (Flashing Standard)
Fuse Holder (Bracket Circuit Board)
Drive Lock
Tyre
Wheel Cover (Slim)
Wheel Cover (Broad)
Wheel Cover (15.5/55-18 Et50)
Bracket
Wheel Nut
Wheel 10.5/80-18 Et17 (Galaxy Bb-R4)
Wheel 15.5/55-18 Et50 (Alliance 601)
Wheel 10.5/80-18 Et17 (Bkt As-504)
Wheel 425/50-18as 8lo.Et36 (Starco As Dumper Ii)
Wheel 425/50-18tl 8lo.Et36 (Starco Alptrak)
Wheel 12.0/75-18 Et 0 (Alliance 317)
Frame
Frame
Engine Tub
Trailer Hitch (Ball Head Trailer Coupling)
Trailer Hitch (Hitch Automatically)
Trailer Hitch (Exploded 1000158315)
Ranking Clutch
Towing Device (Italy)
Trailer Hitch (Auto-Hitch)
Coupling Auto-Hitch (Auto-Hitch Exploded View)
Rearview Mirror (Mirror Trailer Coupling)
Floor Plate
Bracket (Rear Light Bracket)
Mirror Bracket (Soporte Para Retrovisores)
Cover Head Light (Headlight Protection)
Cover (Frame Cover Plates)
Ballast Weight
Bracket Immatriculation Plate (Back)
Bracket Immatriculation Plate (Front)
Trim
Engine Hood
Bonnet Attachments
Sticker Bonnet
Loading System/Armsystem
Telescopic Stick (External Arm)
Telescopic Stick (Internal Arm)
Telescope Cylinder
Quickhitch Plate (Wm Mv)
Quickhitch Plate (Wm Hv)
Quickhitch Plate (Euro Hv)
Quickhitch Plate (Manitou Hv)
Quickhitch Plate (Ssl Hv)
Quickhitch Plate (Sms Hv)
Fixing Pin
End Switch (End Position Detection)
Indicator (Angle Display)
Sticker Loading System
Scraper Telescopic Arm
Mounting (Angle Display And Bolt Bracket)
Cylinder Support
Cabin
Cabin
Mounting Set Cabine
Cabin Windows (Windows + Screwable Wk030/050)
Cab Door
Door Window
Side Window
Rear Window
Trim
Cabin Mounting
Cab Trim (Attachement Parts Outside)
Cabine Cover
Fastening Parts (Mounting Cover Roof)
Sticker Cabin
Seat Activo Plus Mol698 (Fabric (Complete))
Seat Msg95/721 (Fabric Heating (Complete))
Seat Msg95/721 (Fabric / Air Suspension (Complete))
Lock (Belt Lock With Belt Contact Switch)
Mounting Seat
Mounting Set Cabine (Accessoires Driver´S Platform)
Indication Label
Heating/Air Condition System
Tubing
Air Condition System (Engine)
Option
Tool Box
Ranking Clutch (Hitch Front)
Pallet Forks (1200mm)
(1900mm Rz 0,80m³)
(2000mm Rz 0,95m³)
(2100mm Rz 0,90m³)
(1900mm Ws 0,80m³)
(2000mm Ws 0,95m³)
(2100mm Ws 0,90m³)
Lightweight Bucket (1900mm 1,5m³)
Lightweight Bucket (2200mm 1,76m³)
Lightweight Bucket (2400mm 1,93m³)
Multy Purpose Bucket (1900mm 1,05m³)
Multy Purpose Bucket (2200mm 1,30m³)
Earth Shovel (1900mm 0,74m³)
Earth Shovel (1900mm Rz 0,85m³)
Earth Shovel (2000mm Rz 1,00m³)
Earth Shovel (2100mm Rz 0,95m³)
Earth Shovel (1900mm 0,85m³)
Earth Shovel (2000mm 1,00m³)
Earth Shovel (2100mm 0,95m³)
Machine Docs.
Sticker Chassis
Operating Manual
Indication Label (Quick Reference Regeneration)
Brand: Weidemann
Version 1.0
Service Kit
Lubrication
Mounting
Air Cleaner
Fuel System
Coupling (45kw)
Coupling (55kw)
Exhaust Pipe
Engine 404J-E22T
Hose Connection
Seal Crankshaft
Oil Line
Engine Oil Pump
Crank Shaft
Piston
Bearing Set
Filter Head
Rocker Arm
Camshaft
Pressure Pump
Control Unit
Clutch Housing
Flywheel
Starter Motor
Belt Pulley
Oil Sump
Oil Dip Stick
Oildrain Plug
Cover
Venting
Venting Filter
Bracket
Belt Pulley
Belt Pulley
Thermostat
Filler Pipe
Adapter Ventilator
Generator
Flat Belt
Controlhousing
Housing Seal
Filler Pipe
Sensor
Turbocharger
Oil Line
Reflux Line
Suction Manifold
Speed Actuating
Suction Manifold
Exhaust Pipe
Soot Filter
Console Dpf
Sensor
Temperature Sensor
Exhaust Pipe
Air Sucking In
Temperature Sensor
Exhaust Pipe
Exhaust Manifold
Bracket Fuelfilter
Water Seperator
Glow Plug
Banjo Bolt
Wiring Harness
Fuel Pump
Engine 404J-E22TA
Hose Connection
Seal Crankshaft
Oil Line
Engine Oil Pump
Crank Shaft
Piston
Bearing Set
Filter Head
Rocker Arm
Camshaft
Pressure Pump
Control Unit
Clutch Housing
Flywheel
Starter Motor
Belt Pulley
Oil Sump
Oil Dip Stick
Oildrain Plug
Cover
Venting
Venting Filter
Bracket
Belt Pulley
Belt Pulley
Thermostat
Filler Pipe
Adapter Ventilator
Generator
Flat Belt
Controlhousing
Housing Seal
Filler Pipe
Sensor
Turbo Charger
Oil Line
Reflux Line
Suction Manifold
Speed Actuating
Suction Manifold
Exhaust Pipe
Soot Filter
Console Dpf
Sensor
Temperature Sensor
Exhaust Pipe
Air Sucking In
Temperature Sensor
Exhaust Pipe
Exhaust Manifold
Bracket Fuelfilter
Water Seperator
Glow Plug
Banjo Bolt
Wiring Harness
Fuel Pump
Cooling
Cooling
Cooling
Fan Drive
Drive Unit
Displacement Pump
Hydraulic Tank
Cardan Shaft
Axle Attachment
Load Sensor
Drive (Front Axle)
Drive (Front Axle)
Drive (Front Axle)
Drive (Front Axle)
Drive (Rear Axle)
Drive (Rear Axle)
Brake Assembly
Brake Assembly
Steering Unit
Working Hydraulic
Working Hydraulic
Lift Cylinder
Tilt Ram
Regulation Ram
Electric
Instrument Panel
Display (7 ")
Display (Round)
Drive Lock
Bracket Controlling
Joystick (Type I2)
Joystick (Type J)
Main Harness
Lighting (Halogen)
Battery Cable
Battery
Shut Off Switch
Speed Actuating
Rear View Camera
Socket (7-Pole)
Horn
Signal
Drive Lock
Tyre
Wheel Cover (Slim)
Wheel Cover (Broad)
Bracket
Wheel Nut
Frame
Frame
Engine Tub
Ranking Clutch
Floor Plate
Ballast Weight
Trim
Engine Hood
Bonnet Attachments
Sticker Bonnet
Telescope Cylinder
Fixing Pin
Cylinder Support
Cabin
Cabin
Mounting Set Cabine
Cab Door
Door Window
Side Window
Rear Window
Trim
Cabin Mounting
Cabine Cover
Sticker Cabin
Mounting Seat
Indication Label
Tubing
Option
Tool Box
(1900mm Rz 0,80m³)
(2000mm Rz 0,95m³)
(2100mm Rz 0,90m³)
(1900mm Ws 0,80m³)
(2000mm Ws 0,95m³)
(2100mm Ws 0,90m³)
Machine Docs.
Sticker Chassis
Operating Manual
- Weidemann Telehandler T4512 (T01-01) Spare Parts List EN+DE+FR
- Weidemann Hoftrac Type 110 1202 1302 1502 1802 Spare Part List
- Weidemann Engine Perkins 404D-22 1.0 Spare Parts List DE+FR+EN
- Weidemann Engine Perkins 1104D-E44T 1.0 Spare Parts List IT+ES+EN
- Weidemann Wheel Loader Hoftrac 1015 DP Spare Part List
- Weidemann Wheel Loader 1140 RL16 1.0 3057622 Spare Parts List EN+DE+FR
- Weidemann Wheel Loader 1160 eHoftrac RL20E 1.0 Spare Parts List IT+ES+EN
- Weidemann Wheel Loader Hoftrac 1090 DP 1904 DP Spare Part List
- Weidemann Wheel Loader 1380 RL28 1.0 Spare Parts List DE+FR+EN
- Weidemann Telehandler T4512CC35 4512 1.0 Spare Parts List EN+DE+FR
- Weidemann Wheel Loader Hoftrac 120 130 150 180 Spare Parts Catalog_SW
- Weidemann Wheel Loader Hoftrac 1030 DP Spare Part List
- Weidemann Wheel Loader Hoftrac 1050 DM Spare Part List
- Weidemann Wheel Loader 1160 eHoftrac RL20E 1.0 Spare Parts List DE+FR+EN
- Weidemann Wheel Loader 4270CX100 TELE 4270CX100T 1.0 Spare Parts List IT+ES+EN
