Momed80
151
35,046
Weichai Deutz Engine WP6 Series WP6D152E200 Parts Catalog DHP06D0090 EN ZH
Language: English, Chinese
Brand: Deutz, Weichai
Model: Deutz WP6 Series WP6D152E200 Engine
Part Number: DHP06D0090
Number of Pages: 129 Pages
机体结合组(Enging block group)
机体分总成(Pre-Assembly)
前端盖结合组(Front cover group)
喷嘴组件(Piston nozzle set)
曲轴箱通风装置总成()
液压泵结合组(Hydraulic pump assembly)
油底壳总成(Oil sump assembly)
曲轴结合组(Crankshaft Group)
主轴瓦组件(Main Bearing Set)
止推主轴瓦组件(Main bearing se)
止推片组件(Thrust plate set)
飞轮总成(Flywheel combination)
曲轴皮带轮总成(Crankshaft pulley)
轮毂组件(Hub set)
活塞连杆结合组(Piston and connecting rod assembly)
连杆瓦组件(Connecting Rod Bearing Set)
气缸盖总成(Cylinder head subassembly)
气缸盖分总成(Cylinder head subassebly)
气缸垫片(Cylinder gasket)
摇臂座组件(Rocker arm bracket assembly)
气缸盖罩结合组(Cylinder head cover assembly)
凸轮轴总成(Camshaft group)
气门传动装置总成(Valve train assembly)
机油泵(Oil pump body)
机油冷却器结合组(Oil cooler cap group)
机油冷却器总成(Lubricating oil filter assembly)
润滑油进油管总成(Oil Inlet Pipe Assembly)
增压器润滑油管结合组(Tuobocharger oil pipe group)
喷油泵结合组(Fuel pump group)
喷油器结合组(Fuel injector assembly)
喷油器回油管结合组(Injector fuel-return pipe set)
燃油滤清器结合组(Fuel Filter Group)
燃油滤清器(Fuel Filter)
高压油管结合组(High-Pressure fuel pipe group)
进气管结合组(Intake pipe assembly)
空滤器结合组(Air filter)
空气滤清器(Air filter)
水泵结合组(Water pump)
中间垫块总成()
水泵皮带轮总成(Water Pump Pulley Assembly)
排气管结合组(Exhaust pipe group)
增压器结合组(Turbocharger asm)
发电机支架总成(Alternator bracket assembly)
发电机结合组(Complete alternator 8/13m26.3)
起动机结合组(Starter assembly)
压气机管路结合组(Compressor Pipeline Group)
发动机支架结合组(Engine bracket assembly)
飞轮壳总成(Flywheel housing group)
进水管结合组(Water pump group)
零件箱结合组(Parts kit group)
包装箱底盘零件结合组(Dashboard assembly)
消声器结合组(Silencer Group)
机体分总成(Pre-Assembly)
曲轴箱通风装置总成()
轮毂组件(Hub set)
机油泵(Oil pump body)
燃油滤清器(Fuel Filter)
空滤器结合组(Air filter)
空气滤清器(Air filter)
水泵结合组(Water pump)
中间垫块总成()
https://drive.google.com/file/d/1gHfdsZ67xMjZ17Rp5fjl3Lvi22iA3BXd/view?usp=drive_link
Deutz, Engine, WP6 Series, WP6D152E200, Parts Catalog,
750
机体分总成(Pre-Assembly)
曲轴箱通风装置总成()
轮毂组件(Hub set)
机油泵(Oil pump body)
燃油滤清器(Fuel Filter)
空滤器结合组(Air filter)
空气滤清器(Air filter)
水泵结合组(Water pump)
中间垫块总成()
机体分总成(Pre-Assembly)
曲轴箱通风装置总成()
轮毂组件(Hub set)
机油泵(Oil pump body)
燃油滤清器(Fuel Filter)
空滤器结合组(Air filter)
空气滤清器(Air filter)
水泵结合组(Water pump)
中间垫块总成()
