Support
Cleaner
181
99,324,774
[WEBTIC2021] CLAAS WebTIC Offline [04.2021] Operator Manual, Repair Manual & Service Documentation
Download this document, you need 18750 Gallons
Size: 72 GB (Winrar Files)
Document Language: Only English
Type: CLAAS WEBTIC Repair Manual, Assembly Instruction, Time Schedule, Miscellaneous, Technical System, Training Document, Operator Manual.
Make: Claas Agricultural
Amount of DVD: 1 DVD
Version: WebTIC Offline Updated 2021/04
Date: 04.2021
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit (Tested on window 7 ultimate 64bit)
Print Functions: Present
After download send to email to get password "autorepairmanuals.ws@gmail.com"
Detail Model List_Updated 11.2020:
1. COMBINES
LEXION
Lexion 8900-8700 (C86)
Lexion 7700-7400 (C85)
Lexion 780-770 (C76)
Lexion 780-770 (C66)
Lexion 770 (572)
Lexion 770 (C59)
Lexion 760-740 (C75)
Lexion 760-740 (C65)
Lexion 760 (C56)
Lexion 750-740 (C55)
Lexion 750 Montana (C51)
Lexion 670-650 (C74)
Lexion 670-640 (C64)
Lexion 670-640 (C54)
Lexion 670 Montana (C50)
Lexion 670 (570)
Lexion 630-620 (C73)
Lexion 630-620 (C63)
Lexion 630-620 (C53)
Lexion 630 Montana (C52)
Lexion 600 (589)
Lexion 580 (586)
Lexion 570 Montana (581)
Lexion 570 / 580 R (585)
Lexion 560-550 Montana (580)
Lexion 560-540 (584)
Lexion 530-520 Montana (582)
Lexion 530-510 (583)
Lexion 480 Terra-Trac (548)
Lexion 480 Terra-Trac (468)
Lexion 480 (546)
Lexion 480 (466)
Lexion 470 Montana (541)
Lexion 470 (545)
Lexion 460-440 (544)
Lexion 460 Terra-Trac (547)
Lexion 460 / 450 / 440 (454)
Lexion 430 Montana (542)
Lexion 430 / 420 / 415 (453)
Lexion 410 / 405 (452)
Lexion 430-410 (543)
LEXION, N.A
Lexion 8800-8500 (C89)
Lexion 7500-7400 (C88)
Lexion 6800 (C87)
Lexion 780-760 (C79)
Lexion 780-760 (C69)
Lexion 770-760 (C49)
Lexion 760-750 (C71)
Lexion 750-730 (C68)
Lexion 750-730 (C78)
Lexion 750-730 (C48)
Lexion 670 (C77)
Lexion 670 (C67)
Lexion 670 (C44)
Lexion 590R cat (579)
Lexion 585R / 580R cat (576)
Lexion 580R cat (578)
Lexion 570 cat (574)
Lexion 560 cat (573)
Lexion 480 cat (566)
Lexion 470R / 460R cat (565)
Lexion 460 cat (554)
Lexion 450 cat (553)
TUCANO
Tucano 580-570 (L37)
Tucano 580-570 (L47)
Tucano 580-570 (L07)
Tucano 580-570 (L17)
Tucano 580 / 570 (C07)
Tucano 580-570 (C38)
Tucano 560 (L06)
Tucano 560 (L16)
Tucano 560 (C06)
Tucano 480-470 (C36)
Tucano 480-470 (840)
Tucano 460 (837)
Tucano 450-440 (L05)
Tucano 450-440 (L15)
Tucano 450-440 (C30)
Tucano 450-440 (839)
Tucano 450-440 (C31)
Tucano 450-440 (C32)
Tucano 450 / 440 (C05)
Tucano 430-420 (L04)
Tucano 430-420 (838)
Tucano 430 Montana 4 (L01)
Tucano 430 Montana 4 (C01)
Tucano 430 Montana 4 (831)
Tucano 430 / 420 (C04)
Tucano 430 (L14)
Tucano 430 (C28)
Tucano 430 (C21)
Tucano 430 (C22)
Tucano 340 (L03)
Tucano 340 (L13)
Tucano 340 (C20)
Tucano 340 (834)
Tucano 340 (C26)
Tucano 340 (C03)
Tucano 330-320 (832)
Tucano 320 (C02)
Tucano 320 (L02)
Tucano 320 (L12)
Tucano 320 (C24)
Tucano 320 (C18)
AVERO
Avero 240 (451)
Avero 240 (561)
Avero 160 (450)
Avero 160 (560)
DOMINATOR
Dominator 370 (566)
Dominator 198 H (081)
Dominator 150 / 140 (200)
Dominator 130 (C14)
Dominator 98(C)FL (933)
Dominator 106 COA (143)
Dominator 98 (093)
Dominator 130 / 68 S (156)
Dominator 130 (456)
Dominator 108 SL / VX (094)
Dominator 106 (090)
Dominator 96 COA (140)
Dominator 96 (089)
Dominator 88 (092)
Dominator 86 (087)
Dominator 76 (084)
Dominator 78 H (079)
Dominator 76 COA (139)
Dominator 78 (091)
Dominator 68 S / R (155)
Dominator 58 S / 48 S (154)
Dominator 38 S (152)
Dominator 48 S (153)
Dominator 40 Terra-Trac (550)
Dominator 116 CS (144)
CROP TIGER
Crop Tiger 40 Wheel (406)
Crop Tiger 40 Wheel (100)
Crop Tiger 30 Wheel (035)
Crop Tiger Terra Trac (070)
MEGA
Mega 370 (C12)
Mega 370 / 360 (845)
Mega 370 SKD (C11)
Mega 360 SKD (846)
Mega 350 SKD (836)
Mega 350 (835)
Mega 218 / 208 (945)
Mega 204 SKD (936)
Mega 204 / 203 (935)
Mega 202 (925)
MEDION
Medion 340 (934)
Medion 330-310 (932)
Medion 330 H (931)
COMMANDOR
Commandor 228 (159)
Commandor 228 MTS (059)
Commandor 115 CS (158)
Commandor 114 CS (149)
CUTTERBAR
CONIO 1380-770 (590)
CONIO FLEX 1380-770 (591)
Maxflo 1200 (538)
Maxflex1350-1050 (531)
Maxflex 930-770 (53O)
Maxflex 930-560 (530)
V1380-1080 (536)
V930-V770 / C930-C680 (D06)
V750-V540 Vario Lexion (705)
V750-V540 Vario Lexion (712)
V930-V500 / C930-C560 (528)
C900-C750 Lexion (711)
C900-C450 Lexion (715)
C900-C450 Lexion (D02)
C900-C390 Lexion (714)
C900-C300 Lexion (700)
C660-C390 Lexion (708)
C450-C300 Dominator (703)
SW 4,5M-3,2M Crop Tiger (458)
Rapsvorsatz (437)
Mega/Dom.SW (723)
PICK UP
MAIZE PICKER HEAD
Corio 880-670 FC (H08)
Corio 875-670 C (H07)
Corio 575-470 C (H06)
Conspeed 12 Lexion (913)
Conspeed 12-70 / 75 FC (H04)
Conspeed 8 Lexion (912)
Conspeed 8 Lexion (907)
Conspeed 6-70 / 75 C (H05)
Conspeed 6 Lexion (908)
Conspeed 6 Lexion (911)
Conspeed 6 Medion (914)
Conspeed 6 Medion (909)
Maispfluecker 8-Reihig (670)
Maispfl. 8-Reihig (675)
Maispfl. 8-R-ST (677)
Maispfluecker 6-75 SL (136)
Maispfluecker 6-70 S (199)
Maispfl.6-R.KLB.Do (666)
Maispfl. 6-R-ST (676)
Maispfl. 6-R-KL (673)
Maispfl. 5-R-ST (674)
Maispfl.5-R. Dom (667)
Maispfluecker 5-70 SL (197)
MP 8-75 (665)
MP 6-70F / 75F / 80F (445)
MP 6-70F (672)
NMB 8-75 SL/010 (129)
NMB 6-90 SL (174)
NMB 5-90 SL (138)
NMB 4-95 SL+HPHG (122)
NMB 4-75 SL (120)
NMB 4-70 SL (196)
HEADER, N.A.
CONIO FLEX 1230-770 (593)
Maxflo 1200-1050 (537)
Maxflex 1200-1050 (535)
Maxflex 930-770 (534)
V1380-1080 (540)
V1200-V1050 (533)
V535 / V530 Vario Cat (718)
G530 / G525 / R525 Cat (717)
G30-G22 / R25-R22 Cat (707)
C660 Cat (709)
PICK UP, N.A.
CORN HEADER, N.A.
Maispfl.16-R-ST (915)
Maispfl.12-R-ST (918)
Maispfl.8-R-ST (917)
Maispfl.8-R-ST/6-R-ST (916)
Maispfl.6-R (679)
Maispfluecker Vista (678)
CC 518-20 (928)
C516-30 (921)
CUTTERBAR TRAILER
Cutterbar Trailer (559)
Cutterbar Trailer (719)
SW-Wagen (X03)
2. FORAGE HARVESTERS
JAGUAR
Jaguar 70 SF (162)
Jaguar 60 SF (160)
Jaguar 990-930 (502)
Jaguar 980-930 (498)
Jaguar 980-930 (497)
Jaguar 880-830 (496)
Jaguar 980-930 (494)
Jaguar 900-830 (493)
Jaguar 900-830 (492)
Jaguar 880 (490)
Jaguar 860 (489)
Jaguar 840 (488)
Jaguar 820 (487)
Jaguar 810 (495)
Jaguar 800 (186)
Jaguar 695 Mega (189)
Jaguar 690 (181)
Jaguar 690 SL (188)
Jaguar 685 (183)
Jaguar 685 SL (187)
Jaguar 680 (182)
Jaguar 675 (184)
Jaguar 85 (170)
Jaguar 75 (171)
Jaguar 71 (172)
Jaguar 61 (163)
Jaguar 51 (173)
Jaguar 35 (213)
Jaguar 25 (228)
MAIZE HEADER
Orbis 900 (I53)
Orbis 900 (992)
Orbis 750 (959)
Orbis 750 (I52)
Orbis 635 (I41)
Orbis 635 (I54)
Orbis 606 SD (I51)
Orbis 600 (I50)
Orbis 450 (I49)
Orbis 900 (I53)
Orbis 900 (992)
Orbis 750 (659)
Orbis 750 (959)
Orbis 750 (I52)
Orbis 635 (I41)
Orbis 600 (658)
Orbis 450 (657)
RU-600 (902)
RU-600 Contour (903)
RU-600 / XTRA (661)
RU-450 (662)
RU-450 (663)
RU-450 (664)
RU-450 (901)
RU-450 / XTRA (660)
Maisgebiss 8-R (423)
Maisgebiss 6-R (416)
Maisgebisse 6-R (682)
Maisgebisse 6-R (686)
Maisgebisse 5-R (681)
Maisgebiss 5-R (424)
Maisgebisse 4-R (680)
Maisgebiss 4-R (417)
MG 8-RHG NH (687)
MG 8-RHG Mengele (685)
MG-6.-RHG (683)
MG.6-RHG Case-Mammut (684)
MG 6-RHG KHD (689)
MG 4-RHG KHD (688)
PICK UP
PU 430 HD (430)
PU 380 / HD (429)
PU 380 HD PRO (906)
Pick UP 380-300 (I35)
Pick UP 300 (905)
Pick UP 300 (I30)
PU 300 / HD (428)
PU 220 (421)
GPS-LKS-MKS
Direct Disco 600 / 500 (I80)
Direct Disc 520 (426)
Feldfutter - SW 5,10 (427)
Feldfutter - SW 4,20 (425)
CUTTERBAR TRAILER
TW Directdisc 520 (469)
WOOD CUTTER
HS-2 (I22)
3. TRACTORS
XERION
Xerion 5000-4200 (784)
Xerion 5000-4000 (783)
Xerion 5000-4500 Trac (E54)
Xerion 5000-4000 (782)
Xerion 3800-3300 (781)
Xerion 3800 / 3300 Trac (E52)
Xerion 3000-2500 (033)
AXION
Axion 960-920 (A44)
Axion 950-920 NRC (B06)
Axion 900 (A23)
Axion 850-820 NRC (B02)
Axion 850-810 (A40)
Axion 850-810 (A09)
Axion 850-810 CMATIC (A41)
Axion 850-810 HEXASHIFT (A30)
Axion 840-810 CMATIC (A31)
ARION
Arion 650-610 St4 Hexa (A76)
Arion 650-620 Hexashift (A36)
Arion 650-620 Cmatic (A37)
Arion 550-530 CMATIC (A35)
Arion 550-520 Hexashift (A34)
Arion 540-510 (A18)
Arion 460-440 (A43)
Arion 430-410 (A21)
Arion 420-410 (A32)
AXOS
Axos 340-310 (A22)
ATOS
Atos 350-330 (A79)
Atos 240-220 (A78)
ELIOS
Elios 240-210 Stage 3b (A48)
Elios 200 (A28)
NEXOS
Nexos VL 240-210 (A26)
Nexos F 240-210 (A27)
Nexos VE 230-210 (A25)
Nexos 230-220 FB (A29)
TALOS
Talos 240-210 (A39)
Talos 130-120 (A38)
ATLES
Atles 946-926 RZ (A01)
ARES
Ares 836-816 RZ (A02)
Ares 697-617 ATZ (A03)
Ares 696-616 RZ, RC, RX (A04)
Ares 577-547 ATZ, ATX (A05)
Ares 566-546 RX, RZ (A06)
CELTIS
Celtis 456-426 (A24)
NECTIS
Nectis 267-227 F 2+4WD (A14)
Nectis 267-217 VL 2+4WD (A13)
Nectis 237-217 VE 2+4WD (A12)
CERES
Ceres 346-316 2+4WD (A17)
CERGOS
DIONIS
PALES
Pales 240-220 2+4WD (A15)
FRUCTUS
ERGOS
Ergos 466 - 436 2+4WD (A10)
SOLIS
Solis 60/ 50/ 40 (T12)
BASSO
RB 140/ 130 Tier2 (A16)
RB 140/ 130 Tier2 (T10)
TEMIS
FRONTLOADER
Frontloader 250-40 (B91)
Frontloader 140-40 C (B90)
Frontloader 80 / 120 (X04)
Frontloader C (B92)
Frontloader (B98)
Implements (B97)
Manubal (B96)
Frame (B95)
CHALLENGER
Challenger CH 95 (797)
Challenger CH 85 (796)
Challenger CH 75 (795)
Challenger CH 65 (794)
Challenger CH 55 (793)
Challenger CH 45 (792)
Challenger CH 35 (791)
HISTORIC
4. BALERS
QUADRANT
Quadrant 5300 (J32)
Quadrant 5200 (J31)
Quadrant 4200 (J30)
Quadrant 4000 (773)
Quadrant 3400 (740)
Quadrant 3300 RC / RF (757)
Quadrant 3200 (744)
Quadrant 2200 ADVANTAGE (756)
Quadrant 2200 / RC (735)
Quadrant 2100 (743)
Quadrant 2100 (742)
Quadrant 2100 RC / RF (741)
Quadrant 1200 (042)
Quadrant 1200 RC (040)
Quadrant 1150 (044)
Quadrant 1150 RC (045)
Stapler (737)
ROLLANT
Rollant 620 RC / 620 (J02)
Rollant 455 (761)
Rollant 455 UNIWRAP (750)
Rollant 454 (768)
Rollant 454 Uniwrap (769)
Rollant 375 / 355 / RC (764)
Rollant 350 / RC (762)
Rollant 340 (760)
Rollant 260 (765)
Rollant 255 / RC (748)
Rollant 254 / RC (754)
Rollant 250 / RC (725)
Rollant 240 (749)
Rollant 160 / 66 (008)
Rollant 85 (001)
Rollant 62 (003)
Rollant 46 (007)
Rollant 46 Roto Cut (046)
Rollant 45 (009)
Rollant 44 (004)
Rollant 34 (005)
Uniwrap (767)
Uniwrap (729)
VARIANT
Variant 370 (771)
Variant 365 / RC (745)
Variant 350 (770)
Variant 280 / RC (730)
Variant 260 / RC (732)
Variant 180 (047)
Variant 180 (049)
Variant 180 Roto Cut (048)
Variant 160 (043)
MARKANT
Markant 650 (776)
Markant 65 (041)
Markant 55 (028)
Markant 51 (018)
Markant 41 (015)
Markant 45 (290)
Markant 60 (270)
Dominant (260)
Constant (250)
Markant 50 (240)
Markant 40 (210)
5. MOWERS
COUGAR
Cougar (789)
Cougar 1400 M (788)
CORTO
Corto 8100 F / T (399)
Corto 3200 F Profil (F01)
Corto 3150 F Profil (656)
Corto 3100 F / FC / FN (647)
Corto 3100 (644)
Corto 2800 F Profil (F00)
Corto 310 S / N (653)
Corto 300 (340)
Corto 290 F (341)
Corto 280 D (395)
Corto 275 F Profil (655)
Corto 270 S / N / NC (649)
Corto 270 FC (641)
Corto 270 F (345)
Corto 252 F (640)
Corto 252 (648)
Corto 250 F (343)
Corto 250 (344)
Corto 240 D (394)
Corto 210 N / S (381)
Corto 210 F (342)
Corto 185 N / S (382)
Corto 165 N / S (383)
WM 290 FF (387)
DISCO
Disco 9400 (F66)
Disco 9300 C DUO (F59)
Disco 9200 (F62)
Disco 9200 (F64)
Disco 9200 (F65)
Disco 9100 CAS (F60)
Disco 9100 C (F57)
Disco 9100 (F55)
Disco 8700 C / C PLUS (654)
Disco 8600 C DUO (F58)
Disco 8550 (652)
Disco 8500 (F61)
Disco 8500 (F63)
Disco 8400 C / RC (F56)
Disco 8400 (F54)
Disco 4000 TC VER NA (F92)
Disco 4000 (F83)
Disco 3900 TC (F53)
Disco 3900 (999)
Disco 3600 (F82)
Disco 3600 (F86)
Disco 3600 (F91)
Disco 3550 (F77)
Disco 3500 TC (F52)
Disco 3500 FC Profil (F71)
Disco 3500 F Profil (F70)
Disco 3500 C (998)
Disco 3500 (619)
Disco 340 / 3450 Plus (636)
Disco 3200 F Profil (F72)
Disco 3200 (F81)
Disco 3200 (F85)
Disco 3200 (F90)
Disco 3150 F (F74)
Disco 3150 (F76)
Disco 3150 C (F79)
Disco 3150 (F93)
Disco 3100 TC (F51)
Disco 3100 FC / FRC (639)
Disco 3100 F Profil (623)
Disco 3100 C (997)
Disco 3100 (618)
Disco 3050 C (621)
Disco 3050 / PLUS (638)
Disco 2800 (F80)
Disco 2800 (F84)
Disco 2750 C / RC (F78)
Disco 2750 (F75)
Disco 2700 C (996)
Disco 2700 (617)
Disco 2650 C (620)
Disco 2650 / Plus (637)
Disco 1100 Trend (F67)
Disco 1100 (F68)
Disco 300 (645)
Disco 300 C (646)
Disco 290 (635)
Disco 260 C (643)
Disco 260 (642)
Disco 250 (634)
Disco 210 RC (624)
Disco 210 (633)
UNIFARM
Unifarm CM 2 (471)
Unifarm CD 210 (692)
Unifarm CM 186 (691)
Unifarm CM 166 (470)
Scheibenmahwerk Unif (694)
WM
WM 275 C (338)
WM 210 S/ WM 210 N (333)
WM 165/ WM 165 N (334)
WM 185 S/ WM 185 N (335)
6. TEDDERS
VOLTO
Volto 1320 T / 1300 T (631)
Volto 1100 / 1100 T (G55)
Volto 1050 (625)
Volto 900 / 900 T (G54)
Volto 870 H (629)
Volto 800 / 800 T (G53)
Volto 770 / T (627)
Volto 75 T / 750 (358)
Volto 740 H / HR (369)
Volto 700 (G52)
Volto 670 (628)
Volto 640 / S (357)
Volto 640 / 64 (368)
Volto 550 H / HR (396)
Volto 540 S (356)
Volto 540 H (386)
Volto 450 H (385)
Volto 77 (231)
Volto 60 / 58 (179)
Volto 52 (630)
Volto 45 (626)
W 450 S (355)
UNIFARM
Unifarm CW 500 (473)
Unifarm CW 440 (472)
Unifarm CW 300 U (693)
W 450 SL (313)
W 540 SL (314)
7. SWATHERS
LINER
Liner 4000 (G05)
Liner 3600 (G06)
Liner 3500 (G04)
Liner 3100 (989)
Liner 3000 (605)
Liner 2900 (988)
Liner 2800 (987)
Liner 2700 (986)
Liner 2600 (985)
Liner 1900-1800 (G18)
Liner 1750 (G01)
Liner 1650 (G00)
Liner 1700-1600 / Twin (G17)
Liner 1550 / Twin (398)
Liner 1500 (391)
Liner 1250 Profil (608)
Liner 880 (606)
Liner 800 (G16)
Liner 780 (604)
Liner 770 (397)
Liner 760 Hydr. 1990 (380)
Liner 750 Twin (609)
Liner 700 (G15)
Liner 680 (603)
Liner 660 Hydro (373)
Liner 650 Twin (607)
Liner 550 T (G14)
Liner 500 (G13)
Liner 470 S (602)
Liner 450 (G12)
Liner 430 S (392)
Liner 420 (G11)
Liner 390 S (600)
Liner 380 / 380 S (309)
Liner 370 (G10)
Liner 350 S (601)
Liner 330 S (370)
Liner 327 S (379)
UNIFARM
Unifarm CR 330 (475)
Unifarm CR 300 (474)
8. LOADER WAGONS
CARGOS
Cargos 9600-9400 (994)
Cargos 8500-8300 (991)
Cargos 760-740 (995)
QUANTUM
Quantum 5500 S (697)
Quantum 5500 P (698)
Quantum 4500 S (695)
Quantum 4500 P (696)
Quantum 3500 S (699)
Quantum 3500 P (610)
Quantum 3500 K (611)
Ladeaggr.Thorium S (616)
SPRINT
Sprint 5000 S (388)
Sprint 5000 P (389)
Sprint 4000 S (393)
Sprint 4000 P (308)
Sprint 445 U (376)
Sprint 445 S (366)
Sprint 445 P (375)
Sprint 445 K (377)
Sprint 440 U (360)
Sprint 440 S (347)
Sprint 440 P (350)
Sprint 440 K (324)
Sprint 434 K (390)
Sprint 335 S (367)
Sprint 335 P (374)
Sprint 334 K (384)
Sprint 330 U (359)
Sprint 330 S (348)
Sprint 330 P (346)
Sprint 330 K (323)
Sprint 324 K (378)
Sprint 320 K (363)
Sprint 300 T (365)
Sprint 300 K (362)
Sprint 300 G (300)
Sprint 280 K (327)
Sprint 260 P (349)
Sprint 260 K (322)
Sprint 230 T (364)
Sprint 230 (361)
9. TELEHANDLERS
SCORPION
Scorpion 1033 (K34)
Scorpion 960 (K38)
Scorpion 756 (K37)
Scorpion 746 (K35)
Scorpion 741 (K33)
Scorpion 736 (K32)
Scorpion 732 (K31)
Scorpion 635 (K30)
Scorpion 9055 (K27)
Scorpion 9040 (K05)
Scorpion 9040 (K15)
Scorpion 7055 (K26)
Scorpion 7050 (K25)
Scorpion 7045 / 7040 (K04)
Scorpion 7045 / 7040 (K14)
Scorpion 7044 (K24)
Scorpion 7035 (K23)
Scorpion 9040 (K05)
Scorpion 7030 (K02)
Scorpion 7030 (K12)
Scorpion 7030 (K22)
Scorpion 6040 (K03)
Scorpion 6035 (K21)
Scorpion 6030 CP (K10)
Scorpion 6030 (K01)
Scorpion 6030 (K11)
Scorpion 6030 (K20)
TARGO
Targo K70-K50 (512)
Targo K70 (515)
Targo K60 (514)
Targo K50 (513)
Targo C50-C40 (506)
Targo C50 (518)
Targo C40 (517)
RANGER
Ranger / Tele 945 GX (508)
Ranger 911 T (486)
Ranger 907 (484)
Voratzgeraete Ranger (849)
Teleskoplader 907 TS (485)
10. Wheel loaders
TORION
Torion 1914 (K59)
Torion 1812 (K58)
Torion 1511 (K57)
Torion 1410 (K56)
Torion 1177 (K55)
Torion 956 Sinus (K54)
Torion 644 Sinus (K53)
Torion 639 (K52)
Torion 537 Sinus (K51)
Torion 535 (K50)
11. EASY
STEERING SYSTEMS
Cam Pilot (B84)
Cam Pilot 50-40 (B94)
GPS Pilot - Hydraulic (B85)
GPS Pilot Cebis Mobile (B83)
GPS Pilot - Steer ready (B86)
GPS Pilot Flex (B87)
GPS Pilot S3 Terminal (B82)
GPS Pilot TS (B81)
YIELD MAPPING
CLAAS TELEMATICS
SENSORS
Crop Senson Isaria (B61)
FIELDNAV
12. MISCELLANEOUS
TRADE GOODS
Aqua Non Stop Comfort (X01)
CTIC
Master
Cleaner
720
4,200,103
#7
Date: 04.2021
