Martin Welker
104
230,310
Wacker Neuson Wheel loader WL550 Operators Manual 1000268866
Brand: Wacker Neuson
Type of Machine: Wheel loader
Model: Wacker Neuson WL550 Wheel loader
Part Number: 1000268866
Publication Date: 2012
Number of Pages: 216 Pages
Table of Contents
1 Introduction
1.1 Operator’s Manual
1.2 Machine safety information
1.3 Brief description of the machine
1.4 Machine outside view
1.5 Legal regulations regarding machine operation
1.6 Fields of application and using a machine with an attachment
1.7 Type labels, warning and information labels, component numbers
1.8 Machine signs and labels (overview)
1.9 Description of machine signs and labels
2 Safety instructions
2.1 Signal Words Used in this Manual
2.2 Designated use
2.3 General conduct and safety instructions
2.4 Operator/technician qualifications and basic responsibilities
2.5 Safety instructions regarding operation
2.6 Applications with lifting gear
2.7 Trailers and attachments
2.8 Transporting and towing
2.9 Safety guidelines for maintenance
2.10 Special hazards
2.11 Safety guidelines while using internal combustion engines
3 Operation
3.1 Description of control elements
3.2 Inside of cab (overview)
3.3 Instrument panel, multifunctional lever and drive lever (overview)
3.4 Functional description: indicator lights
3.5 Putting the machine into operation
3.6 Checklist
3.7 Cab
3.8 Right-hand window emergency exit
3.9 Seat
3.10 Air-suspension seat
3.11 Seat belt (lap belt)
3.12 Fire extinguisher (option)
3.13 Engine cover lock
3.14 Battery master switch
3.15 Key-based drive interlock (option)
3.16 Drive interlock with code input (option)
3.17 Hydraulic oil preheating (option)
3.18 Fuel preheater (option)
3.19 Putting the diesel engine into operation
3.20 External starting aid (battery)
3.21 Initial steps for putting the machine into operation
3.22 Checking and synchronizing the steering system
3.23 Changing from 4 wheel to front axle steering (option)
3.24 Accelerator pedal
3.25 Manual throttle (option)
3.26 Low-speed control (option)
3.27 Brake/inching pedal
3.28 Parking brake
3.29 Starting machine travel
3.30 Differential lock (option)
3.31 Load stabilizer (option)
3.32 Backup warning system
3.33 Electric connection – front socket (option)
3.34 Rear window heating (option)
3.35 Machine lights
3.36 Signaling system
3.37 Rotating beacon (option)
3.38 Cab heating and ventilation
3.39 Auxiliary heating (option)
3.40 Air conditioning (option)
3.41 Front/rear wipers
3.42 Loader unit control lever (overview)
3.43 Operating and securing the 3rd control circuit
3.44 Pressure release on quick couplers (3rd control circuit)
3.45 Emergency lowering of loader unit in case of diesel engine breakdown
3.46 Equipping the machine with a standard bucket
3.47 Working with a bucket
3.48 Fitting pallet forks
3.49 Working with the pallet forks
3.50 Continuous operation of 3rd control circuit (option)
3.51 3rd control circuit
3.52 “Load holding control valve” safety feature (option)
3.53 Towing the machine
3.54 Crane handling the machine
3.55 Loading and transporting the machine on a transport vehicle
3.56 Long-term storage
3.57 Final decommissioning of machine
4 Troubleshooting
4.1 Engine malfunctions
4.2 Malfunctions in the air conditioning system (option)
5 Maintenance
5.1 Information on maintenance and service work
5.2 Safety strut for loader unit (option for Italian version)
5.3 Fuel system
5.4 Engine lubrication system
5.5 Washer system reservoir
5.6 Engine and hydraulics cooling system
5.7 Air filter
5.8 V-belt
5.9 Hydraulic system
5.10 Checking hydraulic pressure lines
5.11 Lubrication work on the axles
5.12 Lubrication work on the loader unit
5.13 Lubricating with the central lubrication system (option)
5.14 Maintenance of the brake system
5.15 Tires
5.16 Heating and ventilation system maintenance
5.17 Air conditioning (option): maintenance
5.18 Electrical system
5.19 Cleaning and maintenance work
5.20 Maintenance of attachments and of the work equipment
5.21 Maintenance work “Aggressive Media” (option)
5.22 Fluids and lubricants
5.23 Explanation of symbols on the maintenance label
5.24 Maintenance label
5.25 Maintenance plan
6 Specifications
6.1 Models and trade names (overview)
6.2 Frame
6.3 Engine
6.4 Drive
6.5 Front/rear axles
6.6 Brakes
6.7 Steering system
6.8 Work hydraulics
6.9 Electrical system
6.10 Tires
6.11 Weights
6.12 Noise levels
6.13 Coolant compound table
6.14 Vibrations, oscillation and acceleration value
6.15 DIN/EN – American measures
6.16 Tightening torques
6.17 Payloads and capacities
6.18 Dimensions with bucket
6.19 Dimensions with pallet forks
Index
