Hyundai
86
176,834
Wacker Neuson Track Excavator EZ26 Service and Repair Manual 1000507788
Brand: Wacker Neuson
Type of Machine: Track Excavator
Type of Manual: Service and Repair Manual, Electric and Hydraulic Diagrams
Model: Wacker Neuson EZ26 (E24) Track Excavator
Material Number: 1000507788
Publication Date: 2023
Number of Pages: 239 Pages
1 Safety
1.1 Safety symbols and signal words​
1.2 Safety and accident prevention regulations​
1.2.1 First-aid measures in the event of accidents​
1.2.2 Safety regulations for work on the vehicle​
1.2.3 Safety instructions for handling flammable liquids​
1.2.4 Safety instructions for handling oils and greases​
1.2.5 Safety instructions for working on the hydraulic system​
1.2.6 Safety instructions for working on tracks​
1.2.7 Safety instructions for working on the air conditioning system​
1.2.8 Safety instructions for welding work​
1.2.9 Safety instructions for working on the electrical system​
1.3 Qualification of personnel​
2 Preface
2.1 Notes about the document​
2.2 Abbreviations and explanations​
2.2.1 Key to the symbols​
2.2.2 Abbreviations​
2.2.3 Units of measurement​
2.2.4 Cable colors according to IEC 60757​
2.2.5 Glossary​
2.2.6 Direction indications​
2.3 Tightening torques​
2.3.1 General tightening torques​
2.3.2 Tightening torques for metric standard thread​
2.3.3 Tightening torques for metric fine pitch thread​
2.3.4 Tightening torques for air-conditioning screw connections​
2.3.5 Tightening torques for hydraulics and air-conditioning screw connections with sealing coneand O-ring DIN 3865​
2.3.6 Tightening torques for hydraulic fittings with cutting ring DIN 3861​
2.3.7 Tightening torques for hydraulic couplings SDS​
2.3.8 Tightening torques for hydraulic couplings SDE​
2.3.9 Tightening torques for hydraulic swivel fittings​
2.3.10 Tightening torques for banjo bolts DIN 7643​
2.3.11 Tightening torques for brake line fittings​
2.3.12 Tightening torques for worm drive clamps​
2.3.13 Tightening torques for spring-loaded worm drive clamps​
2.3.14 Type-related tightening torques​
2.4 Recovery​
3 Maintenance
3.1 Safety instructions for care and maintenance work​
3.2 Special tools​
3.3 Maintenance plan​
3.3.1 Maintenance label​
3.3.2 Daily maintenance​
3.3.3 Weekly maintenance​
3.3.4 Maintenance 500 operating hours​
3.3.5 Maintenance 1000 operating hours​
3.3.6 Maintenance 2000 operating hours​
3.3.7 Maintenance 3000 operating hours​
3.3.8 Reset maintenance counter​
3.4 Maintenance access covers​
3.5 Vehicle fluids​
3.5.1 Hydraulic oil types​
3.5.2 Engine oil types​
3.6 Lubricate vehicle and attachments​
3.6.1 Lubrication plan​
3.7 Cleaning and care​
3.7.1 Vehicle interior​
3.7.2 Vehicle exterior​
3.8 Check screw connections​
3.9 Engine maintenance​
3.9.1 Motor oil​
3.9.2 Fuel system​
3.9.3 V-belt​
3.9.4 Check and adjust valve clearance​
3.9.5 Check engine bearing​
3.9.6 Check and adjust engine speed​
3.9.7 Checking the alternator​
3.9.8 Air filter​
3.10 Servicing cooling​
3.10.1 Coolant​
3.10.2 Changing the radiator cap​
3.10.3 Check frost protection​
3.11 Servicing tracks​
3.11.1 Checking the bearing play of the wheels​
3.11.2 Tracks​
3.12 Electrical system maintenance​
3.12.1 Check electrical connections and plugs​
3.12.2 Checking the condition of the battery​
3.12.3 Checking the battery degassing hose​
3.12.4 Replace the battery​
3.13 Working hydraulics maintenance​
3.13.1 Working hydraulics​
3.13.2 Hydraulic oil​
3.13.3 Change filter​
3.13.4 Pressure control​
3.13.5 Test log​
3.13.6 Check accumulator​
3.13.7 Cylinder speed measurement​
3.13.8 Cylinder speeds​
3.13.9 Additional control circuit performance measurement​
3.13.10 Measuring the slewing ring play​
3.14 Cab maintenance​
3.14.1 Check and change cab air filter​
3.15 Servicing the drive system​
3.15.1 Changing the transmission oil of the drive system​
3.16 Maintenance of heating and air conditioning system​
3.16.1 Special safety instructions​
3.16.2 Change collective dryer​
3.16.3 Check and replace refrigerant and climate compressor oil​
3.16.4 Filling​
3.16.5 V-belt air conditioning system​
3.17 Servicing the Powertilt​
3.17.1 Check Powertilt axial play​
3.18 Service boom system​
3.18.1 Wear load hook and joint rod​
4 Engine
4.1 Overviews​
4.1.1 Engine compartment​
4.1.2 Fuel system​
4.1.3 Cooling system​
4.1.4 Air intake​
4.2 Components​
4.2.1 Engine Yanmar 3TNV80F-NPWN​
4.2.2 Starting motor​
4.2.3 Alternator​
4.2.4 Combination cooler​
4.2.5 Fuel filter​
4.2.6 Air filter​
4.3 Technical data​
4.3.1 Technical data​
4.3.2 Coolant compound table​
5 Drive system
5.1 Components​
5.1.1 Drive system​
5.2 Technical data​
5.2.1 Drive system​
5.2.2 Maximum speed​
5.2.3 Tractive force​
5.2.4 Technical data​
6 Vehicle frame
6.1 Overviews​
6.1.1 Fire extinguisher​
6.2 Technical data​
6.2.1 Vehicle​
6.2.2 Digging forces​
6.2.3 Wear limits​
6.2.4 Kinematics​
7 Hydraulics
7.1 Overviews​
7.1.1 Hydraulic system​
7.1.2 Cooling system​
7.2 Components​
7.2.1 Changeover valve​
7.2.2 Work pump T003​
7.2.3 Rotary drive T015​
7.2.4 Hydraulic oil tank L042​
7.2.5 Rotary union L017​
7.2.6 Pilot valve​
7.2.7 Hose break valve​
7.2.8 Lowering brake valve L005​
7.2.9 HSWS valve C017​
7.2.10 Pressure release valve additional control circuits​
7.2.11 Distribution block L048​
7.2.12 Control oil unit​
7.2.13 Mobile control block C001​
7.2.14 Joysticks left and right​
7.2.15 Accumulator​
7.2.16 Drive valve​
7.2.17 Multifunction block C061​
7.2.18 Service valve​
7.3 Technical data​
7.3.1 Work pump​
7.3.2 Rotary drive​
7.3.3 Mobile control unit​
7.3.4 Hydraulic oil tank​
7.3.5 HSWS valve​
7.4 Hydraulic circuit diagram​
7.4.1 Hydraulic circuit diagram standard​
7.4.2 Hydraulic circuit diagram options​
8 Electric
8.1 Overviews​
8.1.1 Sensors and switches​
8.1.2 Control devices​
8.1.3 Control elements and solenoid valves​
8.2 Components​
8.2.1 Battery master switch​
8.2.2 Control devices​
8.2.3 Sensors​
8.3 Technical data​
8.3.1 Electrical components​
8.3.2 Fuses and relays​
8.3.3 Lamps​
8.4 Cable harnesses​
8.4.1 Cab wiring harness​
8.4.2 Chassis wiring harness​
8.4.3 Wiring harness rotating beacon canopy​
8.4.4 Wiring harness headlight canopy​
8.4.5 Wiring harness headlight cab​
8.4.6 Cable overload (FRW3)​
8.4.7 Wiring harness air conditioner​
8.4.8 Adapter Cable Headlight​
8.5 Electrical circuit diagrams​
8.5.1 Electrical circuit diagram E24​
9 Heating and air conditioning system
9.1 Overviews​
9.1.1 Air conditioning system​
9.2 Components​
9.2.1 Climate compressor​
9.2.2 Climate condenser​
