Wacker Neuson Roller RD 27-100 RD 27-120 Repair Manual 360770574
Brand: Wacker Neuson
Type of Machine: Roller
Type of Manual: Repair Manual, Hydraulic and Electrical Diagram
Model: Wacker Neuson RD 27-100 RD 27-120 Roller
Part Number: 360770574
Publication Date: 2009
Number of Pages: 178 Pages
Foreword
1 Safety Information
1.1 Signal Words Found in this Manual
1.2 Safety Guidelines for Operating the Machine
1.3 Safety Guidelines while Using Internal Combustion Engines
1.4 Guidelines for Service Safety
1.5 Label Locations
1.6 Safety and Warning Labels
1.7 Informational Labels
2 Operation
2.1 Operation & Maintenance Locations
2.2 Using the Forward/Reverse Lever
2.3 Using the Flow Divider (if equipped)
2.4 Using the Vibration System
2.5 Using the Parking Brakes
2.6 Warning Lights
2.7 Using the Lights and Horn
2.8 Preliminary Checks
2.9 Starting the Engine
2.10 Stopping the Engine
3 Troubleshooting the Engine Start System
3.1 Determining Where to Begin
3.2 Checking the Fuses
3.3 Checking the Wiring/Voltage to the Starter Solenoid
3.4 Checking the Key Switch
3.5 Checking the Start 2 Relay
Continued from the previous page.
4 Troubleshooting the Drive System
4.1 Drive System Overview
4.2 Determining Where to Begin
4.3 Checking the Interlock Relay
5 Troubleshooting the Vibration System
5.1 Determining Where to Begin
5.2 Checking the Vibration Fuse
5.3 Checking the Vibration ON/OFF Solenoid
6 Troubleshooting the Steering System
6.1 Determining Where to Begin
6.2 Diagnosing the Steering System
7 Troubleshooting the Water Spray System
7.1 Determining Where to Begin
7.2 Checking the Water Spray Fuse
7.3 Checking Power to the Spray Pump Motor
7.4 Checking the Spray Switch
7.5 Checking the Timer Module
8 Disassembly and Assembly
8.1 Tools Required for Disassembly/Assembly
8.2 Information Regarding Replacement Parts
8.3 Information Regarding Threadlocking Compounds
8.4 Removing and Installing the Steering Servo Valve
8.5 Removing and Installing a Drive Motor
8.6 Removing and Installing an Exciter Motor
8.7 Removing a Drum
8.8 Disassembling a Drum
8.9 Removing and Installing the Exciter Shaft Bearings
8.10 Removing and Installing Drum Shock Mounts
8.11 Assembling the Drum
8.12 Re-installing the Drum
8.13 Removing and Installing the Fuel Tank
8.14 Removing and Installing the Radiator
8.15 Removing and Installing the Steering Cylinder
8.16 Removing and Installing the Articulated Steering Joint
8.17 Articulated Steering Joint Exploded View
8.18 Articulated Steering Joint Components
8.19 Rebuilding the Articulated Steering Joint
8.21 Removing and Installing the Water Tank
8.20 Removing and Installing the Spray System Pump
8.22 Removing and Installing the Hydraulic Oil Cooler
8.23 Removing and Installing the Drive Pump
8.24 Removing and Installing the Steering Pump
8.25 Removing and Installing the Vibration Pump
8.26 Removing and Installing the Hydraulic Reservoir
8.27 Removing and Installing the Engine
8.28 Removing and Installing the Forward/Reverse Control (Joystick)
8.29 Removing and Installing the Hydraulic Manifold
9 Schematics
9.1 Electrical Schematics
9.2 Hydraulic Schematics
10 Technical Data
10.1 Engine
10.2 Roller
10.3 Lubrication
10.4 Sound Measurements
10.5 Measurements of Operator Exposure to Vibration
10.6 Dimensions
Sealants.pdf
Threadlockers and Sealants
Torque.pdf
Torque Values
Metric Fasteners (DIN)
Inch Fasteners (SAE)
Foreword
1.5 Label Locations
2 Operation
2.6 Warning Lights
8.7 Removing a Drum
9 Schematics
10 Technical Data
10.1 Engine
10.2 Roller
10.3 Lubrication
10.6 Dimensions
Sealants.pdf
Torque.pdf
Torque Values
- Wacker Neuson 803 Spare Parts List
- Wacker Neuson Skid Steer Loader Track ST31 Error Codes, Service, Operator's & Parts Manual EN ES FR
- Wacker Neuson Crawler Excavator 3503 Spare Parts List_1000189534
- Wacker Neuson Compact Excavator 2503 3503 3003 3703 Service Manual_1000081433
- Wacker Neuson Reversible Vibratory Plates DPU 6555 H Operator, Repair Manual & Spare Parts Catalog
- Wacker Neuson Crawler Excavator EZ17 Spare Parts List_1000298089
- Wacker Neuson Skid Steer Loader Track ST35 Error Codes, Service, Operator's & Parts Manual EN DE FR
- Wacker Neuson Wheel Loaders 550 5055 5055L Spare Parts List_1000274206
- Wacker Neuson Track Excavator 6003 Service Manual_1000129840
- Wacker Neuson Track Excavators 75Z3, 8003 Operators Manual_1000132136
- Wacker Neuson Track Excavators 50Z3 Service Manual 1000129833
- Wacker Neuson Wheel Loaders 750, 850 Service Manual_1000183988
- Wacker Neuson Track Excavators 1404 Service Manual_1000166693
- Wacker Neuson Walk-Behind Trowels CT 36-5A Parts Manual_0009438
- Wacker Neuson Kramer Wheel Loader 1150 Spare Parts Manual_100018445
