Martin Welker
104
230,310
Wacker Neuson Roller RD 12 RD 12A Repair Manual 381722114
Brand: Wacker Neuson
Type of Machine: Roller
Type of Manual: Repair Manual, Electrical Diagram
Model: Wacker Neuson RD 12, RD 12A Roller
Part Number: 381722114
Publication Date: 2009
Number of Pages: 138 Pages
1 Safety Information
1.1 Operating Safety
1.2 Operator Safety while using Internal Combustion Engines
1.3 Service Safety
1.4 Label Locations
1.5 Safety and Operating Labels
2 Operation
2.1 Operation and Service Locations
2.2 Control Panel
2.3 Vibration
2.4 Water Spray System
2.5 Starting
2.6 Stopping/Parking
2.7 Auxiliary Battery Positive Terminal
3 Honda Engine Starting System
3.1 Checking the 20A Main Fuse
3.2 Checking Wiring to the Starter Solenoid & Anti-backfire Solenoid
3.3 Checking the Key Switch
3.4 Checking the Crank Relay
3.5 Checking the Neutral Switch
3.6 Checking the Neutral Relay
4 Wacker Neuson Engine Starting System
5 Drive System
6 Vibration System and Steering
7 Steering System
7.1 Checking the Steering System Hydraulic Pressure
7.2 Troubleshooting the Steering System
8 Spray System
8.1 Troubleshooting the Spray System
8.2 Checking Power to the Spray Bar Pump
8.3 Checking the Pump Timer Module
8.4 Checking the Spray System Switch
9 Disassembly & Assembly
9.1 Tools Required for Disassembly/Assembly Procedures
9.2 Information Regarding Replacement Parts
9.3 Information Regarding Reference Numbers ( )
9.4 Information Regarding Threadlocking Compounds
9.5 Removing the Articulating Joint
9.6 Installing the Articulating Joint
9.7 Removing the Rear Drum
9.8 Installing the Rear Drum
9.9 Removing the Brake and Brake Cable
9.10 Installing the Brake and Brake Cable
9.11 Removing Rear Drive Motor
9.12 Installing the Rear Drive Motor
9.13 Removing the Front Drum
9.14 Installing the Front Drum
9.15 Removing the Front Drive Motor
9.16 Installing the Front Drive Motor
9.17 Removing the Exciter
9.18 Installing the Exciter
9.19 Disassembling the Exciter Bearings
9.20 Assembling the Exciter Bearings
9.21 Removing the Control Cable and Control Lever
9.22 Installing the Control Cable and Control Lever
9.23 Removing the Exciter Pump
9.24 Installing the Exciter Pump
9.25 Removing the Drive Pump
9.26 Installing the Drive Pump
9.27 Removing the Engine
9.28 Installing the Engine
9.29 Removing the Steering Valve
9.30 Installing the Steering Valve
9.31 Removing the Hydraulic Tank
9.32 Installing the Hydraulic Tank
9.33 Removing the Fuel Tank
9.34 Installing the Fuel Tank
10 Schematics
10.1 Hydraulic Schematic
10.2 Hydraulic Schematic Components
10.3 Electrical Schematic Identification-RD 12A
10.4 Electrical Schematic “A”-RD 12A
10.5 Electrical Schematic “A” Components-RD 12A
10.6 Electrical Schematic “B”-RD 12A
10.7 Electrical Schematic “B” Components-RD 12A
10.8 Electrical Schematic-RD 12
10.9 Electrical Schematic Components-RD 12
11 Technical Data
11.1 Engine
11.2 Roller
11.3 Lubrication
11.4 Dimensions
11.5 Sound Measurements
11.6 Measurements of Operator Exposure to Vibration
11.7 Hydraulic Pressures
Sealants.pdf
Threadlockers and Sealants
Torque.pdf
Torque Values
Metric Fasteners (DIN)
Inch Fasteners (SAE)
