Martin Welker
104
230,310
Wacker Neuson Ramer BS50 BS700 DS70 DS 720 Repair Manual 91951874
Brand: Wacker Neuson
Type of Machine: Ramer
Type of Manual: Repair Manual
Model: Wacker Neuson Ramer
BS 50, BS 60, BS 70
BS 500, BS 600, BS 700
BS 65, BS 650
DS 70, DS 720
Part Number: 91951874
Publication Date: 2010
Number of Pages: 148 Pages
Foreword
1 Safety Information
2 Tools
3 Maintenance Schedules
4 Engine and Upper Machine Components
5 Ramming System
6 Crankcase
7 Oil Injection (if equipped)
8 Low Oil Shutdown (if equipped)
9 Troubleshooting
10 Technical Data
1.1 Signal Words Found in this Manual
1.2 Machine Description and Intended Use
1.3 Operating Safety
1.4 Operator Safety while using Internal Combustion Engines
1.5 Service Safety
2 Tools
2.1 Recommended Special Tools
2.2 Recommended Repair Tools
3.1 Periodic Maintenance Schedule (BS 50/60/70-2, BS 65)
3.2 Periodic Maintenance Schedule (BS 500/600/700/650)
3.3 Periodic Maintenance Schedule (BS 50/60/70-2i)
3.4 Periodic Maintenance Schedule (BS 500/600/700-oi)
3.5 Periodic Maintenance Schedule (DS 70)
3.6 Periodic Maintenance Schedule (DS 720)
4.1 Removing the Silencing Cover
4.2 Replacing the Throttle Control (2010 and later 2-stroke models)
4.3 Replacing the Throttle Control (2010 4-stroke models)
4.4 Throttle Control (pre-2010 models)
4.5 Replacing the Stop Switch (2010 and later 2-stroke models)
4.6 Replacing the Stop Switch (2010 and later 4-stroke models)
4.7 Replacing the Guide Handle (2010 and later 2-stroke models)
4.8 Replacing the Guide Handle (2010 and later 4-stroke models)
4.9 Replacing the Guide Handle (pre-2010 models)
4.10 Shock Mounts
4.11 Tillotson Carburetor (BS 500/600/700/650 only)
4.12 Fuel Lines (BS 50/60/70-2, BS 65)
4.13 Fuel Tank (BS Models)
4.14 Fuel Tank (DS Models)
4.15 Fuel Tank Cap
4.16 Muffler (pre-2009 BS Models)
4.17 Engine Cooling Fins
4.18 Muffler (DS Models)
4.19 Replacing the Carburetor (WM 80 engines)
4.20 Replacing the WM 80 Engine (2010 and later models)
4.21 Replacing the WM 80 Engine (pre-2010 models)
4.22 Replacing the Carburetor (WM 100 Engines)
4.23 Replacing the WM 100 Engine
4.24 Removing the WM 90 Engine
4.25 Engine (DS Models)
4.26 Clutch (2- and 4-stroke models)
4.27 Clutch (DS 720 only)
4.28 Clutch (DS 70 only)
5 Ramming System
5.1 Bellows
5.2 Replacing the Ramming Shoe
5.3 Spring System Cover Removal and Installation
5.4 Spring System
5.5 Inspecting the Spring System
5.6 Protective Pipe
5.7 Ramming System Lubrication (BS 500/600/700/650, DS 720)
5.8 Ramming System Lubrication (BS 50/60/70, BS 65, DS 70)
6 Crankcase
6.1 Crank Gear and Connecting Rod
6.2 Crank Gear, Connecting Rod, and Adjuster Assembly (BS 650/65 only)
6.3 Clutch Drum
7.1 Testing the Float Switch (2010 and later models)
7.2 Replacing the Float Switch (2010 and later models)
7.3 Float Switch Testing and Replacement (pre-2010 models)
7.4 Oil Line Check Valve
7.5 Testing/Replacing the Oil Pump
8.1 Testing the Low Oil Unit
9 Troubleshooting
9.1 Engine Hard to Start
9.2 Engine Does Not Start
9.3 Engine Does Not Accelerate or Runs Poorly
9.4 Engine Overheats
9.5 Rammer Does Not Tamp
9.6 Rammer Jumps Erratically
10 Technical Data
10.1 BS 50-
10.2 BS 50-
10.3 BS
10.4 BS 500S
10.5 BS 50-2i
10.6 BS 500-oi
10.7 BS 60/70-
10.8 BS 60-
10.9 BS 600/
10.10 BS 600S
10.11 BS 60/70-2i
10.12 BS 600/700-oi
10.13 BS 600/700 High Altitude
10.14 BS 65-V
10.15 BS
10.16 DS
10.17 DS
