Martin Welker
104
230,792
Wacker Neuson Mobile Generator G 85 Repair Manual 330564592
Brand: Wacker Neuson
Type of Machine: Mobile Generator
Type of Manual: Repair Manual
Model: Wacker Neuson G 85, Mobile Generator
Part Number: 330564592
Publication Date: 2009
Number of Pages: 130 Pages
Mobile Generator
1 Safety Information
1.1 Operating Safety
1.2 Service Safety
1.3 Operator Safety while using Internal Combustion Engines
1.4 Towing Safety
1.5 Reporting Trailer Safety Defects
2 Theory of Operation
2.1 Basic Schematic
2.2 Introduction
2.3 Terminology
3 Electrical Testing Techniques
3.1 Checking Continuity
3.2 Checking Resistance
3.3 Checking Voltage
3.4 Probing ECM Plugs and Pins
4 ECM Background Information
4.1 ECM Handling Precaution
4.2 Normal Boot-up Sequence
4.3 Display Variables and Values
4.4 ECM Display Screens-Start Switch in Remote Position
4.5 Additional Variables Monitored by the ECM
4.6 Voltage Display Errors
4.7 ECM Automatic Engine Shutdown Conditions
4.8 ECM Circuit Boards
4.9 Control Wiring Numbering & Colors
4.10 Removing and Installing the ECM
5 ECM/Sensor Troubleshooting
6 John Deere Engines With ECU
6.1 John Deere Engines With ECU Background
6.2 Locations of Engine Electrical Components
6.3 Engine Electrical Components
7 Engine Starting Troubleshooting
8 Output Voltage Troubleshooting
9 Disassembly/Assembly Procedures
9.1 Tools
9.2 Ordering Parts
9.3 Reference Numbers ( )
9.4 Weight Block
9.5 Removing the Roof
9.6 Preparing Unit for Generator Removal
9.7 Replacing the Generator
9.8 Removing the AVR
9.9 Installing the AVR
9.10 Removing the Engine
9.11 Installing the Engine
9.12 Replacing the Fuel Tank
9.13 Replacing the Emergency Stop Switch (older)
9.14 Replacing the Emergency Stop Switch (newer)
9.15 Replacing the Diodes
9.16 Replacing the Voltage Selector Switch (VSS)
9.17 G 50, G 70, G 85 VSS Wiring
10 Technical Data
10.1 Engine Data
10.2 Generator Data
10.3 Trailer and Skid Data
10.4 Dimensions
10.5 Engine Wiring Diagram-John Deere with ECU
10.6 ECU Wiring Diagram
10.7 ECU Harness Connector
10.8 Generator Wiring Diagram
1.2 Service Safety
1.4 Towing Safety
2.1 Basic Schematic
2.2 Introduction
2.3 Terminology
Continue
Replace the fuse with one of the same size and rating.
Continue
Check the function of the main circuit breaker. The shunt of the main circuit breaker is most likely the cause of a fuse failure. See section 5.10 Checking the Main Circuit Breaker.
The fuses are OK.
Continued from the previous page.
Continue
Continue
Check the function of the main circuit breaker. The shunt of the main circuit breaker is most likely the cause of a fuse failure. See Section 7.7 Checking the Main Circuit Breaker.
The fuses are OK.
Go to step 6.
Continue
Continue
Charge the battery.
Continue
Repair or replace wire #53.
Continue
Repair or replace wire #15.
The ECM is OK.
The ECM has failed. Call Wacker Neuson Service.
Continue
The emergency stop switch has failed; replace it.
The emergency stop switch is not the problem.
Continue
Repair or replace the red wire.
Continue
Repair or replace wire #422.
Continue
Repair or replace wire #050D or wire #14.
The starter relay is OK.
The starter relay has failed; replace it.
Continue
Repair or replace the large red wire.
Continue
Repair or replace small red wire.
Continue
Repair or replace red wire #11.
Continue
Repair or replace grey wire #65.
Continue
Repair or replace wire #14.
The intake heater relay is OK.
The intake heater relay has failed; replace it.
Continue
The main circuit breaker has failed; replace it.
Continue
Continue.
_____; _____; _____
The main circuit breaker is functioning properly.
Continue
The emergency stop switch is OK.
Continue
The lug door switch has failed; replace it.
Reconnect the blue and blue/white wires; then continue.
Continue
The lug door switch is OK.
Continue
Continue
Continue
_____; _____; _____
Continue
The voltage adjusting rheostat has failed; replace it.
The voltage adjusting rheostat is OK.
Continue
Remove the vent cover from the generator and check the generator for damage.
Auxiliary winding is OK.
Continue
Continue
Remove the vent cover from the generator and check the generator for damage; then continue.
The excitor stator is OK.
The exciter stator has failed.
Continue
Continue
The sensing wires are OK.
The excitation system is functioning properly.
Check the exciter rotor winding. See Checking the Exciter Rotor Winding.
The main stator windings and the voltage selector switch are OK.
Replace all diodes.
Replace all diodes.
The main rotor winding has failed.
The main rotor winding is OK.
The main rotor winding has failed. Call Wacker Neuson Service.
The exciter rotor windings are OK.
The exciter rotor has failed. Call Wacker Neuson
_____; _____; _____
The main stator windings are OK. If there is a difference between the readings taken here and those taken at the lugs, the VSS has failed; replace it.
The main stator windings have failed. Call Wacker Neuson
9.1 Tools
9.2 Ordering Parts
9.4 Weight Block
10 Technical Data
10.1 Engine Data
10.2 Generator Data
10.4 Dimensions
Sealants.pdf
Threadlockers and Sealants
Torque.pdf
Torque Values
Metric Fasteners (DIN)
Inch Fasteners (SAE)
