Martin Welker
104
230,310
Wacker Neuson Excavators 50Z3 Service Manual and Diagram 1000129833
Brand: Wacker Neuson
Type of Machine: Excavator
Type of Manual: Service Manual, Electrical and Hydraulic Diagram
Model: Wacker Neuson s 50Z3 Excavator
Part Number: Wacker Neuson Excavators 50Z3 Service Manual and Diagram 1000129833
Publication Date: 2005
Number of Pages: 262 Pages
1 Operation
1.1 Important information on this service manual
1.2 Identification of warnings and dangers
1.3 Designated use and exemption from liability
1.4 Type labels and component numbers
1.5 Machine: overview
1.6 Cab overview
1.7 Cab (legend)
1.8 Instrument panel up to serial no. AC02877: overview
1.9 Instrument panel up to serial no. AC02877: legend
1.10 Instrument panel from serial no. AC02893 to serial no. AD07125: overview
1.11 Instrument panel from serial no. AC02893 to serial no. AD07125: legend
1.12 Control elements 50Z3 (from serial no. AH00579)
1.13 Engine compartment up to serial no. AD07125: overview
1.14 Engine compartment (from serial no. AH00579): overview
1.15 Chassis overview
1.16 Tilting the cab
1.17 Summer/winter operation
1.18 Turning the auxiliary hydraulics/boom swivel pedal around
2 Specifications
2.1 Chassis
2.2 Engine
2.3 Hydraulic system
2.4 Undercarriage and swivel unit
2.5 Stabiliser blade
2.6 Electric system
2.7 Noise levels
2.8 Vibration
2.9 Coolant compound table
2.10 Model-specific tightening torques
2.11 General tightening torques
2.12 Dimensions model 50Z3
2.13 Lift capacity table 50Z3
2.14 Lift capacity table 50Z3 with long stick
2.15 Lift capacity table 50Z3 with counterweight
2.16 Lift capacity table 50Z3 with long stick and counterweight
2.17 Kinematics
2.18 Attachments
3 Maintenance
3.1 Fluids and lubricants
3.2 Maintenance label
3.3 Maintenance plan (overview)
3.4 Service package
3.5 Introduction
3.6 Fuel system
3.7 Engine lubrication system
3.8 Cooling system
3.9 Air filter
3.10 V-belt
3.11 Pressure check
3.12 Test report
3.13 Hydraulic system
3.14 Travelling drive
3.15 Chains
3.16 Lubrication work
3.17 Electric system
3.18 Cab
3.19 General maintenance work
4 Engine
4.1 Engine 4TNV88-PNS (up to serial no. AD07125): overview
4.2 Fuel system
4.3 Checking and adjusting valve clearance
4.4 Tightening order for cylinder head bolts
4.5 Checking the injection nozzles
4.6 Checking the nozzle jet
4.7 Injection time
4.8 Adjusting engine revs
4.9 Compression
4.10 Checking the coolant thermostat
4.11 Checking the thermal switch
4.12 Oil pressure switch
4.13 Checking the coolant circuit
4.14 Engine 4TNV88-PNS (from serial no. AH00579): overview
4.15 Fuel system
4.16 Removing the valve cover
4.17 Checking and adjusting valve clearance
4.18 Tightening order for cylinder head bolts
4.19 Checking the injection nozzles
4.20 Checking the nozzle jet
4.21 Injection time
4.22 Adjusting engine revs
4.23 Compression
4.24 Checking the coolant thermostat
4.25 Checking the thermal switch
4.26 Oil pressure switch
4.27 Checking the coolant circuit
4.28 Engine trouble
SHB_50z3_EN_1000129833_Teil2.pdf
5 Hydraulic system
6 Electric system
7 Options
