Wacker Neuson Excavator 50Z3 6003 Operating Manual 1000127717
Brand: Wacker Neuson
Type of Machine: Excavator
Type of Manual: Operating Manual
Model: Wacker Neuson 50Z3 6003 Excavator
Part Number: 1000127717
Publication Date: 2010
Number of Pages: 198 Pages
Important information on this Operator's Manual
Machine overview
Brief description
Fields of application, attachments
Regulations
EC declaration of conformity version 50Z³ up to serial number AH00578
EC declaration of conformity version 50Z³ from serial number AH00579
EC declaration of conformity version 6003 up to serial number AH00578
EC declaration of conformity version 6003 from serial number AH00579
Type labels and component numbers
Other signs and symbols
Fire extinguisher
Identification of warnings and dangers
Warranty
Designated use and exemption from liability
General conduct and safety instructions
Safety instructions regarding operation
Safety instructions for maintenance
Warning of special hazards
50Z3 cab
6003 cab
50Z3 controls
6003 controls
Putting into operation
Driving the excavator
Driving on slopes
Stabiliser blade operation
Parking the machine
Light system
Cab heating and ventilation
Washer system
Air conditioning (option)
Seat adjustment
Seat belt
Emergency exit
Front window
Door
Engine cover
Battery master switch
Tilting the cab
Exit through the door
Adjusting the left-hand side armrest
Towing the track excavator
Crane handling the machine
Loading and transporting the machine
Tying down the machine
Working with the machine
Control levers/ISO controls: overview
Changeover valve for SAE/ISO controls (option)
Control lever with proportional controls (option): overview
Control lever if equipped with 3rd control circuit (option): overview
Vario (option)
Releasing the pressure on the work hydraulics
Re-equipping attachments
Powertilt (option)
Connections for auxiliary hydraulics
Grading
Working alongside trenches
Safe load indicator (option)
Engine trouble
Engine error codes
Malfunctions of the Powertilt unit
Introduction
Fuel system
Engine lubrication system
Engine and hydraulics cooling system
Air filter
V-belt
Hydraulic system
Pilot valve
Tracks
Travelling drive
Electrical system
General maintenance work
Maintenance if the machine is out of service for a longer period of time
Fluids and lubricants
Maintenance plan (overview)
Maintenance label
Hydraulic system
Undercarriage and swivel unit
Stabiliser blade
Work hydraulics
Electrical system
Noise levels
Vibration
Coolant compound table
Powertilt
Dimensions model 50Z³
Dimensions model 6003
Lift capacity table 50Z³
Lift capacity table 50Z³ counterweight (option)
Lift capacity table 50Z³ long stick (option)
Lift capacity table 50Z³ long stick, counterweight (option)
Lift capacity table 6003
Lift capacity table 6003 counterweight (option)
Lift capacity table 6003 long stick (option)
Lift capacity table 6003 long stick, counterweight (option)
Lift capacity table 6003 long stick, triple articulation boom (option)
Lift capacity table 6003 long stick, triple articulation boom, counterweight (option)
Lift capacity table 6003 triple articulation boom (option)
Lift capacity table 6003 triple articulation boom, counterweight (option)
Lift capacity table 6003 Vario (option)
1 Introduction
1.1 Important information on this Operator's Manual
1.2 Machine overview
1.3 Brief description
Travelling drive
Work hydraulics
Cooling system
Cab (ROPS, TOPS and FOPS)
1.4 Fields of application, attachments
Use: attachment
1.5 Regulations
1.6 EC declaration of conformity version 50Z³ up to serial number AH
1.7 EC declaration of conformity version 50Z³ from serial number AH
1.8 EC declaration of conformity version 6003 up to serial number AH
1.9 EC declaration of conformity version 6003 from serial number AH
1.10 Type labels and component numbers
1.11 Other signs and symbols
...on the outside of the machine
...inside the cab
1.12 Fire extinguisher
2 Safety instructions
2.1 Identification of warnings and dangers
2.2 Warranty
2.3 Designated use and exemption from liability
2.4 General conduct and safety instructions
Organisational measures
Selection and qualification of staff, basic responsibilities
2.5 Safety instructions regarding operation
Normal operation
Applications with lifting gear
Trailers and attachments
Transport
2.6 Safety instructions for maintenance
2.7 Warning of special hazards
Electric energy
Gas, dust, steam, smoke
Hydraulics
Noise
Oil, grease and other chemical substances
Battery
Tracks
3 Operation
3.1 50Z3 cab
3.2 6003 cab
Up to serial number AH
From serial number AH
3.3 50Z3 controls
3.4 6003 controls
3.5 Putting into operation
Safety instructions
Putting the machine into operation for the first time
Running-in period
Check lists
Start-up checklist
Operation checklist
Parking checklist
3.6 Driving the excavator
Preheating start switch
Throttle
Automatic revs setting (option)
Telltales and warning lights: overview
Before starting the engine
Starting the engine: general
Procedure
Starting at low temperatures
When the engine has started
Engine warm-up
Moving off
Drive levers
High speed
Hydraulic brake
Mechanical brake
3.7 Driving on slopes
Driving on slopes
3.8 Stabiliser blade operation
3.9 Parking the machine
Parking the machine on slopes
3.10 Light system
Working light
Roof lights (option)
Interior light
Rotating beacon (option)
3.11 Cab heating and ventilation
Summer/winter operation (up to serial number AD04650)
Heating controls (from serial number AD04651)
3.12 Washer system
Tank for washer system
3.13 Air conditioning (option)
Recirculated air mode
3.14 Seat adjustment
Weight adjustment
Height adjustment
Horizontal adjustment
Backrest adjustment
3.15 Seat belt
3.16 Emergency exit
3.17 Front window
3.18 Door
3.19 Engine cover
3.20 Battery master switch
3.21 Tilting the cab
3.22 Exit through the door
3.23 Adjusting the left-hand side armrest
3.24 Towing the track excavator
Towing
3.25 Crane handling the machine
3.26 Loading and transporting the machine
3.27 Tying down the machine
Jump-starting the engine (supply battery)
Special instructions for driving on public roads
3.28 Working with the machine
General safety instructions
3.29 Control levers/ISO controls: overview
Left-hand side control lever
Boom swivel controls/triple articulation boom (option)
Right-hand side control lever
Lowering the boom with the engine stopped
Releasing pressure
Rotating the upper carriage
Swivel unit brake
3.30 Changeover valve for SAE/ISO controls (option)
Directional valve position
Directional valve
3.31 Control lever with proportional controls (option): overview
Function
Measures to be taken in case of malfunctions
Changeover between auxiliary hydraulics and boom swivel
Switching status display on/off for auxiliary hydraulics/boom swivel
Operating the boom/auxiliary hydraulics
Hammer operation
Adjusting control response:
Characteristic curves – status display
Releasing pressure
Swivel unit brake
3.32 Control lever if equipped with 3rd control circuit (option): overview
Lowering the boom with the engine switched off
Releasing pressure
Swivel unit brake
3.33 Vario (option)
Vario operation
Driving across slopes with the Vario feature
Danger area of the Vario feature
Working with the Vario feature
Improved reach with the Vario feature
3.34 Releasing the pressure on the work hydraulics
Releasing pressure
Pressure release with proportional controls (option)
3.35 Re-equipping attachments
Specific safety instructions
Removing a bucket
Mounting a bucket
Quickhitch (option)
Hydraulic quickhitch (option)
Maintenance
Operation
3.36 Powertilt (option)
Re-equipping
Mounting the Powertilt unit
Removing the Powertilt unit
Port
Operation
Right-hand side control lever (Powertilt)
Enabling the 3rd control circuit
3.37 Connections for auxiliary hydraulics
Grab couplings
“Hose burst valve” safety feature (option)
Working with the standard bucket
Inadmissible work
Excavator work position
Bucket position when digging
Excavating trenches
Loading
Grading
Excavating trenches sideways
3.38 Grading
Grading
3.39 Working alongside trenches
Stabiliser blade at rear
3.40 Safe load indicator (option)
4 Troubleshooting
4.1 Engine trouble
4.2 Engine error codes
4.3 Malfunctions of the Powertilt unit
5 Maintenance
5.1 Introduction
5.2 Fuel system
Refuelling
Fuel-filling pump (option)
Stationary fuel pumps
Diesel fuel specification
Bleeding the fuel system
Fuel prefilter with water separator
5.3 Engine lubrication system
Checking the oil level
Filling up engine oil
5.4 Engine and hydraulics cooling system
Checking/filling up coolant
5.5 Air filter
Replacing the filter
5.6 V-belt
Checking V-belt tension
Retightening the V-belt
Checking the V-belt of the air conditioning system
Tightening the V-belt of the air conditioning system
5.7 Hydraulic system
Checking the hydraulic oil level
Filling up hydraulic oil
Important information for the use of biodegradable oil
5.8 Pilot valve
Checking hydraulic pressure lines
5.9 Tracks
Checking track tension
Setting the tracks
5.10 Travelling drive
Checking the oil level and filling up oil
Draining oil
Maintenance of attachments
5.11 Electrical system
Service and maintenance work at regular intervals
Instructions concerning specific components
Battery
5.12 General maintenance work
Cleaning
General instructions for all areas of the machine
Inside the cab
Exterior of the machine
Engine compartment
Screw connections and attachments
Pivots and hinges
Powertilt (option)
5.13 Maintenance if the machine is out of service for a longer period of time
Preparatory work before taking the machine out of service
Putting the machine into operation again
5.14 Fluids and lubricants
Additional oil change and filter replacement (hydraulics)
5.15 Maintenance plan (overview)
5.16 Maintenance label
Explanation of symbols on the maintenance label
6 Specifications
6.1 Chassis
6.2 Engine
6.3 Hydraulic system
6.4 Undercarriage and swivel unit
6.5 Stabiliser blade
6.6 Work hydraulics
6.7 Electrical system
Fuse box in instrument panel
Main fuse box with relays underneath the cab
Relays
6.8 Noise levels
6.9 Vibration
6.10 Coolant compound table
6.11 Powertilt
6.12 Dimensions model 50Z³
6.13 Dimensions model
6.14 Lift capacity table 50Z³
6.15 Lift capacity table 50Z³ counterweight (option)
6.16 Lift capacity table 50Z³ long stick (option)
6.17 Lift capacity table 50Z³ long stick, counterweight (option)
6.18 Lift capacity table
6.19 Lift capacity table 6003 counterweight (option)
6.20 Lift capacity table 6003 long stick (option)
6.21 Lift capacity table 6003 long stick, counterweight (option)
6.22 Lift capacity table 6003 long stick, triple articulation boom (option)
6.23 Lift capacity table 6003 long stick, triple articulation boom, counterweight (option)
6.24 Lift capacity table 6003 triple articulation boom (option)
6.25 Lift capacity table 6003 triple articulation boom, counterweight (option)
6.26 Lift capacity table 6003 Vario (option)
Machine overview
Brief description
Regulations
Fire extinguisher
Warranty
50Z3 cab
6003 cab
50Z3 controls
6003 controls
Driving on slopes
Parking the machine
Light system
Washer system
Seat adjustment
Seat belt
Emergency exit
Front window
Door
Engine cover
Tilting the cab
Vario (option)
Powertilt (option)
Grading
Engine trouble
Engine error codes
Introduction
Fuel system
Air filter
V-belt
Hydraulic system
Pilot valve
Tracks
Travelling drive
Electrical system
Maintenance label
Hydraulic system
Stabiliser blade
Work hydraulics
Electrical system
Noise levels
Vibration
Powertilt
1 Introduction
Travelling drive
Work hydraulics
Cooling system
Use: attachment
1.5 Regulations
...inside the cab
2.2 Warranty
Normal operation
Transport
Electric energy
Hydraulics
Noise
Battery
Tracks
3 Operation
3.1 50Z3 cab
3.2 6003 cab
3.3 50Z3 controls
3.4 6003 controls
Safety instructions
Running-in period
Check lists
Start-up checklist
Operation checklist
Parking checklist
Throttle
Procedure
Engine warm-up
Moving off
Drive levers
High speed
Hydraulic brake
Mechanical brake
Driving on slopes
3.10 Light system
Working light
Interior light
3.12 Washer system
Weight adjustment
Height adjustment
Backrest adjustment
3.15 Seat belt
3.16 Emergency exit
3.17 Front window
3.18 Door
3.19 Engine cover
Towing
Releasing pressure
Swivel unit brake
Directional valve
Function
Hammer operation
Releasing pressure
Swivel unit brake
Releasing pressure
Swivel unit brake
3.33 Vario (option)
Vario operation
Releasing pressure
Removing a bucket
Mounting a bucket
Quickhitch (option)
Maintenance
Operation
Re-equipping
Port
Operation
Grab couplings
Inadmissible work
Excavating trenches
Loading
Grading
3.38 Grading
Grading
4 Troubleshooting
4.1 Engine trouble
5 Maintenance
5.1 Introduction
5.2 Fuel system
Refuelling
5.5 Air filter
5.6 V-belt
5.8 Pilot valve
5.9 Tracks
Setting the tracks
Draining oil
Battery
Cleaning
Inside the cab
Engine compartment
Pivots and hinges
Powertilt (option)
6 Specifications
6.1 Chassis
6.2 Engine
6.6 Work hydraulics
Relays
6.8 Noise levels
6.9 Vibration
6.11 Powertilt
- Wacker Neuson 803 Spare Parts List
- Wacker Neuson Skid Steer Loader Track ST31 Error Codes, Service, Operator's & Parts Manual EN ES FR
- Wacker Neuson Crawler Excavator 3503 Spare Parts List_1000189534
- Wacker Neuson Compact Excavator 2503 3503 3003 3703 Service Manual_1000081433
- Wacker Neuson Reversible Vibratory Plates DPU 6555 H Operator, Repair Manual & Spare Parts Catalog
- Wacker Neuson Crawler Excavator EZ17 Spare Parts List_1000298089
- Wacker Neuson Skid Steer Loader Track ST35 Error Codes, Service, Operator's & Parts Manual EN DE FR
- Wacker Neuson Wheel Loaders 550 5055 5055L Spare Parts List_1000274206
- Wacker Neuson Track Excavator 6003 Service Manual_1000129840
- Wacker Neuson Track Excavators 75Z3, 8003 Operators Manual_1000132136
- Wacker Neuson Track Excavators 50Z3 Service Manual 1000129833
- Wacker Neuson Wheel Loaders 750, 850 Service Manual_1000183988
- Wacker Neuson Track Excavators 1404 Service Manual_1000166693
- Wacker Neuson Walk-Behind Trowels CT 36-5A Parts Manual_0009438
- Wacker Neuson Kramer Wheel Loader 1150 Spare Parts Manual_100018445
