Martin Welker
104
230,310
Wacker Neuson Excavator 50Z3 50Z3-2 6003 6003-2 Operating Manual 1000127717
Brand: Wacker Neuson
Type of Machine: Excavator
Type of Manual: Operating Manual
Model: Wacker Neuson 50Z3 50Z3-2 6003 6003-2 Excavator
Part Number: 1000127717
Publication Date: 2010
Number of Pages: 282 Pages
1 Introduction
1.1 Important information on the Operator’s Manual
1.2 Machine overview
1.3 Brief description
1.4 Fields of application, attachments
1.5 Regulations
1.6 EC declaration of conformity for all machines delivered before 29 December 2009
1.7 EC declaration of conformity for all machines delivered after 29 December 2009
1.8 Declaration of conformity for machines without CE mark on the type label
1.9 EC declaration of conformity for all machines delivered before 29 December 2009
1.10 EC declaration of conformity for all machines delivered after 29 December 2009
1.11 Declaration of conformity for machines without CE mark on the type label
1.12 Type labels and component numbers
1.13 Signs and symbols
1.14 Fire extinguisher
2 Safety instructions
2.1 Identification of warnings and dangers
2.2 Warranty
2.3 Disposal
2.4 Designated use and exemption from liability
2.5 General conduct and safety instructions
2.6 Selection and qualification of staff, basic responsibilities
2.7 Safety instructions regarding operation
2.8 Information on visibility
2.9 Cab and protective structures (from serial no. AJ02777)
2.10 Checks when reversing the machine
2.11 Trailer operation
2.12 Applications with lifting gear
2.13 Attachments
2.14 Safety instructions for maintenance
2.15 Warning of special hazards
2.16 Hammer operation
2.17 Transport and towing
3 Operation
3.1 Cab 50Z3/6003 (up to serial no. AH02781)
3.2 Cab 50Z3 2 / 6003 2 (from serial no. AJ02777)
3.3 Control elements 50Z3 (up to serial no. AH02781) / 6003 (up to serial no. AH00578)
3.4 Control elements 6003 (serial nos. AH00579 to AH02750)
3.5 Control elements 50Z3 2 / 6003 2 (from serial no.AJ02777)
3.6 Indicator lights and warning lights: overview
3.7 Putting into operation
3.8 Driving the machine
3.9 Automatic engine speed setting
3.10 Before starting the engine
3.11 Starting with the drive interlock – internal transponder (option) (from serial no. AJ02777)
3.12 Jump-starting the engine (supply battery)
3.13 Starting at low temperatures
3.14 When the engine has started
3.15 Special instructions for driving on public roads
3.16 Working on slopes
3.17 Stabiliser blade operation
3.18 Parking the machine
3.19 Light system
3.20 Cab heating and ventilation
3.21 Air conditioning (option)
3.22 Wiper/wash system
3.23 Seat (50Z3)
3.24 Seat (6003)
3.25 Seat (air suspension option)
3.26 Seat belt
3.27 Retracting lap belt (option)
3.28 Mirrors (option)
3.29 Emergency exit
3.30 Front window (up to serial no. AD06526)
3.31 Front window (from serial no. AD06527)
3.32 Opening and closing the side window
3.33 Mounting/removing the canopy shatter protection (option)
3.34 Door
3.35 Exit through the door (up to serial no. AH02764)
3.36 Exit through the door (from serial no. AJ02777)
3.37 Armrest adjustment (up to serial no. AH02764)
3.38 Armrest adjustment (from serial no. AJ02777)
3.39 Engine cover
3.40 Battery master switch
3.41 Tilting the cab
3.42 Towing the machine
3.43 Crane handling the machine
3.44 Loading and transporting the machine
3.45 Tying down the machine
3.46 Driving signal (option)
3.47 Working with the machine
3.48 Control levers/ISO controls: overview
3.49 Changeover valve for SAE/ISO controls (option)
3.50 Control lever with proportional controls (option): overview
3.51 Control lever if equipped with 3rd control circuit (option): overview
3.52 Tilting the upper carriage – Vertical Digging System (option)
3.53 Vario (6003 option)
3.54 Releasing the pressure on the work hydraulics
3.55 Re-equipping attachments
3.56 Quickhitch (option)
3.57 Hydraulic Easy Lock quickhitch (option)
3.58 Powertilt (option)
3.59 Connections for auxiliary hydraulics
3.60 Safe load indicator (option)
3.61 Safety feature “Hose burst valve” (option)
3.62 Applications with lifting gear
3.63 Work area assessment and preparation
3.64 Working with the machine
3.65 Grading
4 Troubleshooting
4.1 Troubleshooting the engine
4.2 Engine error codes
4.3 Malfunctions of the Powertilt unit
4.4 Troubleshooting the central lubrication system (option)
4.5 Proportional controls (option) diagnosis display
5 Maintenance
5.1 Introduction
5.2 Safety-relevant parts
5.3 Fuel system
5.4 Engine lubrication system
5.5 Engine and hydraulics cooling system
5.6 Air filter
5.7 Change cab air filter
5.8 Replacing the filter element of the air conditioning system (option)
5.9 Diesel particulate filter (option)
5.10 V-belt
5.11 Hydraulic system
5.12 Tracks
5.13 Travelling drive
5.14 Maintenance of attachments
5.15 Electrical system
5.16 General maintenance work
5.17 Overview of lubrication points
5.18 Central lubrication system (option)
5.19 Preparatory work before taking the machine out of service
5.20 Maintenance if the machine is out of service for a longer period of time
5.21 Fluids and lubricants
5.22 Maintenance plan (overview)
5.23 Maintenance label
6 Specifications
6.1 Chassis
6.2 Engine
6.3 Hydraulic system
6.4 Work hydraulics
6.5 Undercarriage and swivel unit
6.6 Stabiliser blade
6.7 Electrical system, model 50Z3
6.8 Electrical system, model 6003 (from serial no. AH0611)
6.9 ECU control unit (6003 from serial no. AH00611)
6.10 Noise levels
6.11 Vibration
6.12 Coolant compound table
6.13 Powertilt
6.14 Weight indications
6.15 Dimensions model 50Z3
6.16 Dimensions model 50Z3 VDS
6.17 Dimensions model 6003 standard boom, Vario (option)
6.18 Dimensions model 6003 triple articulation boom (option)
6.19 Lift capacity table 50Z3
6.20 Lift capacity table 50Z3 counterweight (option)
6.21 Lift capacity table 50Z3 long stick (option)
6.22 Lift capacity table 50Z3 long stick, counterweight (option)
6.23 Lift capacity table 50Z3 VDS short stick (option)
6.24 Lift capacity table 50Z3 VDS short stick, counterweight (option)
6.25 Lift capacity table 50Z3 VDS long stick (option)
6.26 Lift capacity table 50Z3 VDS long stick, counterweight (option)
6.27 Lift capacity table 6003
6.28 Lift capacity table 6003 counterweight (option)
6.29 Lift capacity table 6003 long stick (option)
6.30 Lift capacity table 6003 long stick, counterweight (option)
6.31 Lift capacity table 6003 long stick, triple articulation boom (option)
6.32 Lift capacity table 6003 long stick, triple articulation boom, counterweight (option)
6.33 Lift capacity table 6003 triple articulation boom (option)
6.34 Lift capacity table 6003 triple articulation boom, counterweight (option)
6.35 Lift capacity table 6003 Vario (option)
