Wacker Neuson Excavator 1404 Service Manual and Diagram 1000166693
Brand: Wacker Neuson
Type of Machine: Excavator
Type of Manual: Service Manual, Electrical and Hydraulic Diagram
Model: Wacker Neuson 1404 Excavator
Part Number: 1000166693
Publication Date: 2006
Number of Pages: 162 Pages
1 Operation
1.1 Important information on this service manual
1.2 Identification of warnings and dangers
1.3 Designated use and exemption from liability
1.4 Type labels and component numbers
1.5 Machine overview
1.6 Cab overview
1.7 Cab overview: legend
1.8 Instrument panel overview
1.9 Instrument panel overview: legend
1.10 Engine compartment: overview
1.11 Chassis overview
1.12 Removing the cab
2 Specifications
2.1 Chassis
2.2 Engine
2.3 Hydraulic system
2.4 Undercarriage and swivel unit
2.5 Stabiliser blade
2.6 Electric system
2.7 Noise levels
2.8 Vibration
2.9 Coolant compound table
2.10 Model-specific tightening torques
2.11 General tightening torques
2.12 Dimensions model 1404
2.13 Lift capacity table 1404 RD
2.14 Lift capacity table 1404 RD with long stick (option)
2.15 Lift capacity table 1404 RD with cab (option) and telescopic undercarriage (option)
2.16 Lift capacity table 1404 RD with cab (option), long stick (option) and telescopic undercarriage (option)
2.17 Kinematics
2.18 Attachments
3 Maintenance
3.1 Fluids and lubricants
3.2 Maintenance label
3.3 Maintenance plan (overview)
3.4 Service package
3.5 Introduction
3.6 Fuel system
3.7 Engine lubrication system
3.8 Engine cooling system
3.9 Air filter
3.10 V-belt
3.11 Pressure check
3.12 Test report
3.13 Hydraulic system
3.14 Pilot control filter (from serial number AF01441)
3.15 Travelling drive
3.16 Chains
3.17 Lubrication work
3.18 Electric system
3.19 General maintenance work
4 Engine
4.1 3TNV76-SNS2 engine overview
4.2 Fuel system
4.3 Checking and adjusting valve tip clearance
4.4 Tightening order for cylinder head bolts
4.5 Checking the injection nozzles
4.6 Checking the nozzle jet
4.7 Injection time
4.8 Adjusting engine revs
4.9 Compression
4.10 Checking the coolant thermostat
4.11 Checking the thermal switch
4.12 Oil pressure switch
4.13 Checking the coolant circuit
4.14 Engine trouble
5 Hydraulic system
5.1 Gear pump AZPS-11-014RRR20MB
5.2 Main valve block SX 10
5.3 Auxiliary hydraulics connections
5.4 Pilot valves
5.5 Travelling drive
5.6 Swivel unit
5.7 Swivel joint
5.8 Mechanical controls
5.9 Breather filter
5.10 Troubleshooting in the hydraulic system
5.11 Hydraulics diagram A4
5.12 Hydraulics diagram: legend
5.13 Hydraulics diagram 1404 RD
5.14 Main valve block diagram 1404 RD
6 Electric system
6.1 Ohm's Law (current, voltage, resistance); power
6.2 Measuring equipment, measuring methods
6.3 Cable colour coding
6.4 Relays
6.5 Electric system
6.6 Instrument panel overview
6.7 Dynamo and governor
6.8 Starter
6.9 Wiring diagram A4 1404 RD: legend
6.10 Wiring diagram A4 1404 RD
6.11 Engine wiring harness 1404 RD: legend
6.12 Engine wiring harness A4 1404 RD
6.13 Seat console wiring harness A4 1404 RD: legend
6.14 Seat console wiring harness A4 1404 RD
6.15 Alternator wiring harness (option) A4 1404 RD
6.16 Wiring diagram A3 1404 RD: legend
6.17 Wiring diagram A3 1404 RD
6.18 Engine wiring harness A3 1404 RD: legend
6.19 Engine wiring harness A3 1404 RD
6.20 Seat console wiring harness A3 1404 RD: legend
6.21 Seat console and alternator wiring harness (option) A3 1404 RD
7 Options
7.1 Long stick
7.2 Drive interlock (antitheft protection)
1 Operation
1.6 Cab overview
2 Specifications
2.1 Chassis
2.2 Engine
2.6 Electric system
2.7 Noise levels
2.8 Vibration
2.17 Kinematics
2.18 Attachments
3 Maintenance
3.4 Service package
3.5 Introduction
3.6 Fuel system
3.9 Air filter
3.10 V-belt
3.11 Pressure check
3.12 Test report
3.16 Chains
4 Engine
4.2 Fuel system
4.7 Injection time
4.9 Compression
4.14 Engine trouble
5 Hydraulic system
5.4 Pilot valves
5.6 Swivel unit
5.7 Swivel joint
5.9 Breather filter
6 Electric system
6.4 Relays
6.5 Electric system
6.8 Starter
7 Options
7.1 Long stick
- Wacker Neuson 803 Spare Parts List
- Wacker Neuson Skid Steer Loader Track ST31 Error Codes, Service, Operator's & Parts Manual EN ES FR
- Wacker Neuson Crawler Excavator 3503 Spare Parts List_1000189534
- Wacker Neuson Compact Excavator 2503 3503 3003 3703 Service Manual_1000081433
- Wacker Neuson Reversible Vibratory Plates DPU 6555 H Operator, Repair Manual & Spare Parts Catalog
- Wacker Neuson Crawler Excavator EZ17 Spare Parts List_1000298089
- Wacker Neuson Skid Steer Loader Track ST35 Error Codes, Service, Operator's & Parts Manual EN DE FR
- Wacker Neuson Wheel Loaders 550 5055 5055L Spare Parts List_1000274206
- Wacker Neuson Track Excavator 6003 Service Manual_1000129840
- Wacker Neuson Track Excavators 75Z3, 8003 Operators Manual_1000132136
- Wacker Neuson Track Excavators 50Z3 Service Manual 1000129833
- Wacker Neuson Wheel Loaders 750, 850 Service Manual_1000183988
- Wacker Neuson Track Excavators 1404 Service Manual_1000166693
- Wacker Neuson Walk-Behind Trowels CT 36-5A Parts Manual_0009438
- Wacker Neuson Kramer Wheel Loader 1150 Spare Parts Manual_100018445
